hmailserver on windows 10
blackjack
Post by blackjack » 2020-01-22 12:27
hello everyone,
so I have installed virtual machine with windows 10.
is it possible to make it as server for sending and (especially) receiving emails
or I need windows server 2016 with dns manager?
I have created free domain in infinity free but in free version it can't give me access to imap so I can't connect to Outlook or Thunderbird and receive messages
I would really appreciate any your help to understand what is my problem - wrong OS version or I can organize server on windows 10 but I just don't know how to do it.
Re: hmailserver on windows 10
Post by mattg » 2020-01-22 12:30
Yes hmailserver works on Windows 10
Run this and post the results please
viewtopic.php?f=20&t=30914
blackjack
Post by blackjack » 2020-01-22 13:54
2020-01-22   Hmailserver: 5.6.7-B2425
DOMAINS
   "Domain1.com" - kaxxxxxx.epxxx.com             Enabled: True
      |- "Alias1.com" - kaxxxxxx
                   Max size of accounts:    0
        Greylisting:     False
IP RANGES
     POP3:  False                              Antivirus:   True !! ANTIVIRUS NOT CONFIGURED !!
     External To Local    -  True              External To Local    -  True
     External To External -  True              External To External - False
     External To Local    -  True           !! External To Local    -  True !!
       !! EXTERNAL INBOUND ON SUB IP RANGES OR EXTERNAL DOWNLOADS ONLY !!
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
                  !! POINTS TO LOCAL DOMAIN !! Disc. on invalid:  False  Delivered-To hdr: False
                     Port:  25                                           Loop limit:           5
                     Req Auth: False                                     Recipient hosts:     15
                     Con. Sec.: None
  Routes:
     No routes defined.
POP3
 !! Service Not Enabled !!
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
DNSBL ENTRIES:
   No 'enabled' entries
SURBL ENTRIES:
GREYLISTING:
  Greylisting:  False
WHITELISTING
   No entries
  Block Attachments: False
SSL CERTIFICATES
   No entries
SSL/TLS
             SSL 3.0 :  False
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
  Paths:-
    Error:    C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2020-01-22.log
SYSTEM TESTS
Database type: MSSQL Compact
HMAILSERVER.INI
Type=              MSSQLCE
Username=
Port=              0
Server=
Internal=          1
blackjack
Post by blackjack » 2020-01-22 14:52
so I found that I didn't change hosts file and some sht xd
now it's working fine, but it's only local.
what should I do to make it work outside my lan network?
Post by palinka » 2020-01-22 15:12
Relay: !! POINTS TO LOCAL DOMAIN !!
Delete the relay.
Post by jimimaseye » 2020-01-22 22:50
and
Nothing coming in, and PLENTY of spam going out.....for free!!!
blackjack
Post by blackjack » 2020-01-23 13:39
2020-01-22 22:50
and
what do you mean? did I block something?
Virinum
Post by Virinum » 2020-01-23 14:37
Currently your settings are saying:
Someone wants to send you an email: You first need to authenticate
Someone wants to send an mail from your server: Here you go
It has to be the other way round. Everyone (external) should be allowed to send you (local) an email. But no one should be allowed to send an email from your server without authentication.
blackjack
Post by blackjack » 2020-01-23 14:39
Virinum wrote:
2020-01-23 14:37
well, sounds pretty clear, thank you
blackjack
Post by blackjack » 2020-01-23 16:28
2020-01-22 15:12
Delete the relay.
It needs to be like "Relay:-
(none entered) "
right?
Post by palinka » 2020-01-23 18:01
blackjack wrote:
2020-01-23 16:28
2020-01-22 15:12
Delete the relay.
(none entered) "
right?
Correct. Unless port 25 outgoing is blocked. Then you will need an outside relay service.
Post by mattg » 2020-01-28 02:00
Once fixed test by doing some open relay tests, OR repost the updated settings
https://www.hmailserver.com/documentati ... elay_tests
