RvdH DNSResolver + Powershell
Post by palinka » 2020-01-15 02:18
Trying to figure out how to call the DNS Resolver from powershell. I'm not getting far. Here's what I have so far.
$IP = '221.120.216.98'
$IPS = $IP.Split("\.")
$RevIPS = $IPS[3]+"."+$IPS[2]+"."+$IPS[1]+"."+$IPS[0]
$DNS = New-Object -ComObject DNSLibrary.DNSResolver
$PTR = $DNS.PTR("$RevIPS")
Write-Host $PTR
All I get is a blank result with no error.
By switching around a couple of things like this:
$PTR = New-Object -ComObject DNSLibrary.DNSResolver.PTR("$RevIPS")
I get error:
New-Object : A positional parameter cannot be found that accepts argument
'98.216.120.221'.
At C:\scripts\hmailserver\PTRTests\testpsptr.ps1:5 char:8
+ $PTR = New-Object -ComObject DNSLibrary.DNSResolver.PTR("$RevIPS")
    + CategoryInfo          : InvalidArgument: (:) [New-Object], ParameterBinding
   Exception
    + FullyQualifiedErrorId : PositionalParameterNotFound,Microsoft.PowerShell.Co
   mmands.NewObjectCommand
Any ideas to get me going?
Re: RvdH DNSResolver + Powershell
Post by Dravion » 2020-01-15 06:52
The ip addfess is unexpected at the position.
Check Argument order.
Post by palinka » 2020-01-15 11:37
Dravion wrote:
2020-01-15 06:52
That's the problem I'm having. I don't know the argument order nor the correct syntax.
Post by RvdH » 2020-01-15 12:25
Do not reverse the IP, you are trying to make a PTR lookup :!:
$PTR = $DNS.PTR("$IP")
Write-Host $PTR
lhr63.pie.net.pk
Post by palinka » 2020-01-15 14:34
2020-01-15 12:25
Write-Host $PTR
lhr63.pie.net.pk
Thank you! I knew it was something dumb like that. I should have tried it myself before even posting. No wonder I wasn't getting an error. :oops:
