Using STARTTLS for message delivery
VinceO
Post by VinceO » 2019-08-02 15:40
I am new to hMailerServer and am using hMailServer 5.6.7-B2425. I am trying to send mail to a server that is complaining "This sender must issue a STARTTLS command first".
I'm not sure what steps I missed. Any assistance would be greatly appreciated.
SMTP Setting:
Here is the log:
"DEBUG" 5780 "2019-08-01 18:43:03.905" "Creating session 25"
"TCPIP" 5780 "2019-08-01 18:43:03.908" "TCP - 10.150.170.98 connected to 10.150.170.98:25."
"DEBUG" 5780 "2019-08-01 18:43:03.912" "TCP connection started for session 23"
"SMTPD" 5780 23 "2019-08-01 18:43:03.913" "10.150.170.98" "SENT: 220 smtp2.xyxcompany.com ESMTP"
"SMTPD" 5780 23 "2019-08-01 18:43:03.914" "10.150.170.98" "RECEIVED: EHLO SERVER"
"SMTPD" 5780 23 "2019-08-01 18:43:03.915" "10.150.170.98" "SENT: 250-smtp2.xyzcompany.com[nl]250-SIZE 20480000[nl]250-STARTTLS[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD" 5780 23 "2019-08-01 18:43:03.916" "10.150.170.98" "RECEIVED: MAIL FROM:<Support@xyzcompany.com>"
"DEBUG" 5780 "2019-08-01 18:43:03.920" "Total spam score: 0"
"SMTPD" 5780 23 "2019-08-01 18:43:03.929" "10.150.170.98" "SENT: 250 OK"
"SMTPD" 4292 23 "2019-08-01 18:43:03.930" "10.150.170.98" "RECEIVED: RCPT TO:<Jane.Publiclino@abccompany.com>"
"SMTPD" 4292 23 "2019-08-01 18:43:03.941" "10.150.170.98" "SENT: 250 OK"
"SMTPD" 14128 23 "2019-08-01 18:43:03.942" "10.150.170.98" "RECEIVED: DATA"
"SMTPD" 14128 23 "2019-08-01 18:43:03.945" "10.150.170.98" "SENT: 354 OK, send."
"DEBUG" 11544 "2019-08-01 18:43:03.948" "Adding task AsynchronousTask to work queue Asynchronous task queue"
"DEBUG" 9832 "2019-08-01 18:43:03.948" "Executing task AsynchronousTask in work queue Asynchronous task queue"
"DEBUG" 9832 "2019-08-01 18:43:03.954" "Total spam score: 0"
"DEBUG" 9832 "2019-08-01 18:43:03.955" "Saving message: {839024B2-89B2-428E-8DEF-24A2F2EE29A6}.eml"
"DEBUG" 9832 "2019-08-01 18:43:03.990" "Requesting SMTPDeliveryManager to start message delivery"
"SMTPD" 9832 23 "2019-08-01 18:43:03.991" "10.150.170.98" "SENT: 250 Queued (0.000 seconds)"
"DEBUG" 9944 "2019-08-01 18:43:04.006" "Adding task DeliveryTask to work queue SMTP delivery queue"
"DEBUG" 20772 "2019-08-01 18:43:04.007" "Executing task DeliveryTask in work queue SMTP delivery queue"
"DEBUG" 20772 "2019-08-01 18:43:04.013" "Delivering message..."
"APPLICATION" 20772 "2019-08-01 18:43:04.014" "SMTPDeliverer - Message 21924: Delivering message from Support@xyzcompany.com to Jane.Publiclino@abccompany.com. File: G:\Program Files (x86)\hMailServer\Data\{839024B2-89B2-428E-8DEF-24A2F2EE29A6}.eml"
"DEBUG" 20772 "2019-08-01 18:43:04.024" "Applying rules"
"DEBUG" 20772 "2019-08-01 18:43:04.028" "Performing local delivery"
"DEBUG" 20772 "2019-08-01 18:43:04.029" "Local delivery completed"
"TCPIP" 20772 "2019-08-01 18:43:04.031" "DNS MX lookup: abccompany.com"
"TCPIP" 20772 "2019-08-01 18:43:04.727" "DNS - MX Result: 8 IP addresses were found."
"DEBUG" 20772 "2019-08-01 18:43:04.728" "Starting external delivery process. Server: esa-omf-101.abccompany.com (99.99.99.99), Port: 25, Security: 2, User name: "
"DEBUG" 20772 "2019-08-01 18:43:04.729" "Creating session 26"
"TCPIP" 20772 "2019-08-01 18:43:04.730" "Connecting to 99.99.99.99:25..."
"DEBUG" 7484 "2019-08-01 18:43:04.761" "TCP connection started for session 26"
"SMTPC" 7484 26 "2019-08-01 18:43:05.005" "99.99.99.99" "RECEIVED: 220 ********************************"
"SMTPC" 7484 26 "2019-08-01 18:43:05.006" "99.99.99.99" "SENT: EHLO smtp2.xyzcompany.com"
"SMTPC" 18080 26 "2019-08-01 18:43:05.106" "99.99.99.99" "RECEIVED: 250-esa-omf-101.abccompany.com[nl]250-8BITMIME[nl]250-SIZE 41943040[nl]250 XXXXXXXA"
"SMTPC" 18080 26 "2019-08-01 18:43:05.107" "99.99.99.99" "SENT: MAIL FROM:<Support@xyzcompany.com>"
"SMTPC" 13560 26 "2019-08-01 18:43:05.218" "99.99.99.99" "RECEIVED: 530 #5.7.0 This sender must issue a STARTTLS command first"
"SMTPC" 13560 26 "2019-08-01 18:43:05.219" "99.99.99.99" "SENT: QUIT"
"SMTPC" 5780 26 "2019-08-01 18:43:05.251" "99.99.99.99" "RECEIVED: 221 esa-omf-101.abccompany.com"
"DEBUG" 5780 "2019-08-01 18:43:05.252" "Ending session 26"
"DEBUG" 20772 "2019-08-01 18:43:05.252" "External delivery process completed"
"DEBUG" 20772 "2019-08-01 18:43:05.253" "Summarizing delivery result"
"DEBUG" 20772 "2019-08-01 18:43:05.256" "AWStats::LogDeliveryFailure"
"DEBUG" 20772 "2019-08-01 18:43:05.257" "AWStats::LogDeliveryFailure"
"DEBUG" 20772 "2019-08-01 18:43:05.259" "Summarized delivery results"
"DEBUG" 20772 "2019-08-01 18:43:05.260" "SD::SubmitErrorLog_"
"DEBUG" 20772 "2019-08-01 18:43:05.268" "Saving message: {C0CD323F-843A-4C74-BF4D-58A6ECE1FDB7}.eml"
"DEBUG" 20772 "2019-08-01 18:43:05.275" "SD::~SubmitErrorLog_"
"DEBUG" 20772 "2019-08-01 18:43:05.276" "Deleting message"
"DEBUG" 20772 "2019-08-01 18:43:05.278" "Deleting message file."
"APPLICATION" 20772 "2019-08-01 18:43:05.280" "SMTPDeliverer - Message 21924: Message delivery thread completed."
Re: Using STARTTLS for message delivery
Post by palinka » 2019-08-02 15:51
Im pretty sure (not 100% but like 99.73%) that you need a certificate in order to use tls of any kind. Do you have a working certificate installed?
VinceO
Post by VinceO » 2019-08-02 16:04
Thanks for the reply
I created a Self-Signed Certificate and added it.
Not sure where to select it for use.
Post by palinka » 2019-08-02 16:11
VinceO wrote:
2019-08-02 16:04
Settings > Advanced > TCP/IP Ports > 0.0.0.0 / 25 / SMTP > Connection Security = STARTTLS (optional) and choose your certificate from the drop down list.
Edit - some servers check certificates (most don't) so in some rare cases, you may still not be able to connect due to your self signed certificate.
LetsEncrypt is free, easy and can be completely automated. Why not give that a shot?
https://www.hmailserver.com/forum/viewt ... 21&t=32593
VinceO
Post by VinceO » 2019-08-02 17:57
Thanks for the continued assistance.
I created a 30 day certificate from COMODO Certificate Authority. (OpenSSL was used to generate the CSR).
I used https://www.sslchecker.com/matcher to verify the Private Key and Certificate matched.
I added the COMODO root and intermediate certificates to the Windows Certificate Store
I added the certificate to hMailServer and updated 0.0.0.0 / 25 / SMTP settings to use the new certificate.
I still see the "STARTTLS needs to be First" message when the hMailServer tries to deliver an email to a third-party mail server
Any additional thoughts would be appreciated.
mikedibella
Post by mikedibella » 2019-08-02 18:18
You don't need a certificate for outbound TLS.
Under Settings > Protocols > SMTP > Advanced, check Use STARTTLS if Available.
Under Settings > Protocols > SMTP > Delivery of email, if you are using a Relayer, set Connection security to STARTTLS (Optional) if the port is not encrypted (25 or 587).
Under Settings > Protocols > SMTP > Routes, for each Route defined, set Connection security to STARTTLS (Optional), if the port is not encrypted (25 or 587).
Post by palinka » 2019-08-02 18:25
The goes my 99.73% confidence level down the toilet. :mrgreen:
VinceO
Post by VinceO » 2019-08-02 18:37
Thanks for the assistance,
Settings > Protocols > SMTP > Advanced: STARTTLS if Available has been checked
We are not using Relayer and we have no Routes.
Here are the Diagnostics
[code]2019-08-02   Hmailserver: 5.6.7-B2425
DOMAINS
   "Domain1.com" - PJxxxxxxxxxxxxxxxx.com         Enabled: True
                   Max size of accounts:    0
        Greylisting:     False
IP RANGES
     POP3:   True !! Protocol DISABLED !!      Antivirus:   True !! ANTIVIRUS NOT CONFIGURED !!
     IMAP:   True !! Protocol DISABLED !!      SSL/TLS:    False
IP: 10.150.170.0 - 10.150.170.255     Priority: 10     Name: CyrusOne
     POP3:  False                              Antivirus:   True !! ANTIVIRUS NOT CONFIGURED !!
     External To External -  True              External To External - False
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
No. Connections:  0  No Retries:  4 Mins: 60   Plain Text:        False  Bind: 10.150.170.98
        Loop limit:           5
        Recipient hosts:     15
  Routes:
     No routes defined.
POP3
 !! Service Not Enabled !!
IMAP
ANTISPAM
DNSBL ENTRIES:
   No 'enabled' entries
SURBL ENTRIES:
GREYLISTING:
  Greylisting:  False
WHITELISTING
   No entries
  Block Attachments: False
SSL CERTIFICATES
   hMail-Self
       Certificate: G:\PEmail\P-Email-Certificater.crt
       Private key: G:\PEmail\serverde.key
   smtp2
       Certificate: G:\PEmail\COMODO\smtp2_support_com.crt
       Private key: G:\PEmail\COMODO\server2048de.key
SSL/TLS
             SSL 3.0 :  False
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
               0.0.0.0         / 25    / SMTP   -   StartTLS Optional   Cert: smtp2
  Paths:-
    Current:  G:\Program Files (x86)\hMailServer\Logs\hmailserver_2019-08-02.log
    Error:    G:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2019-08-02.log
    Event:    G:\Program Files (x86)\hMailServer\Logs\hmailserver_events.log - Not present
    Awstats:  G:\Program Files (x86)\hMailServer\Logs\hmailserver_awstats.log
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -      .
                        IMAP        -      .
                        TCPIP       -    True
                        DEBUG       -    True
                        AWSTATS     -    True
SYSTEM TESTS
Database type: MSSQL
Backup directory G:\RISC\hMailServer_Backup is writable.
HMAILSERVER.INI
Program folder:  G:\Program Files (x86)\hMailServer\
Database folder:
Data folder:     G:\Program Files (x86)\hMailServer\Data
Log folder:      G:\Program Files (x86)\hMailServer\Logs
Temp folder:     G:\Program Files (x86)\hMailServer\Temp
Event folder:    G:\Program Files (x86)\hMailServer\Events
Type=              MSSQL
Username=          hMailServer
PasswordEncryption=0
Port=              0
Server=            riscsqlcl2
Internal=          0
Generated by HMSSettingsDiagnostics v1.96, Hmailserver Forum.
[/code]
mikedibella
Post by mikedibella » 2019-08-02 20:03
Hypothesis: STARTTLS is failing the certification validation.
Try disabling Settings > Advanced > SSL/TLS > Verify remote server SSL/TLS certificate.
VinceO
Post by VinceO » 2019-08-02 20:35
Thanks for the idea,
I disabled Verify remote server SSL/TSL certificate.
We are still getting the following when delivering mail.
mikedibella
Post by mikedibella » 2019-08-02 20:56
Send a larger portion of the log. It seems like the remote server is expending authentication.
VinceO
Post by VinceO » 2019-08-02 21:35
I think this is everything from the log having to do with the message
"DEBUG"	5188	"2019-08-02 15:28:32.910"	"Creating session 9"
"TCPIP"	5188	"2019-08-02 15:28:32.912"	"TCP - 10.150.170.98 connected to 10.150.170.98:25."
"DEBUG"	5188	"2019-08-02 15:28:32.913"	"TCP connection started for session 7"
"SMTPD"	5188	7	"2019-08-02 15:28:32.914"	"10.150.170.98"	"SENT: 220 smtp2.pjmtrainingsupport.com ESMTP"
"SMTPD"	18116	7	"2019-08-02 15:28:32.915"	"10.150.170.98"	"RECEIVED: EHLO RIS-HOU-PROD-03"
"SMTPD"	18116	7	"2019-08-02 15:28:32.916"	"10.150.170.98"	"SENT: 250-smtp2.pjmtrainingsupport.com[nl]250-SIZE 20480000[nl]250-STARTTLS[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD"	21096	7	"2019-08-02 15:28:32.917"	"10.150.170.98"	"RECEIVED: MAIL FROM:<TrainingSupport@pjm.com>"
"DEBUG"	21096	"2019-08-02 15:28:32.919"	"Total spam score: 0"
"SMTPD"	21096	7	"2019-08-02 15:28:32.922"	"10.150.170.98"	"SENT: 250 OK"
"SMTPD"	5188	7	"2019-08-02 15:28:32.923"	"10.150.170.98"	"RECEIVED: RCPT TO:<Artw@constellation.com>"
"SMTPD"	5188	7	"2019-08-02 15:28:32.926"	"10.150.170.98"	"SENT: 250 OK"
"SMTPD"	18116	7	"2019-08-02 15:28:32.927"	"10.150.170.98"	"RECEIVED: DATA"
"SMTPD"	18116	7	"2019-08-02 15:28:32.929"	"10.150.170.98"	"SENT: 354 OK, send."
"DEBUG"	5188	"2019-08-02 15:28:32.932"	"Adding task AsynchronousTask to work queue Asynchronous task queue"
"DEBUG"	17152	"2019-08-02 15:28:32.933"	"Executing task AsynchronousTask in work queue Asynchronous task queue"
"DEBUG"	17152	"2019-08-02 15:28:32.934"	"Total spam score: 0"
"DEBUG"	17152	"2019-08-02 15:28:32.935"	"Saving message: {BB4927A0-2474-47C3-A1AB-A0A217B0CD23}.eml"
"DEBUG"	17152	"2019-08-02 15:28:32.941"	"Requesting SMTPDeliveryManager to start message delivery"
"SMTPD"	17152	7	"2019-08-02 15:28:32.942"	"10.150.170.98"	"SENT: 250 Queued (0.000 seconds)"
"DEBUG"	18880	"2019-08-02 15:28:32.952"	"Adding task DeliveryTask to work queue SMTP delivery queue"
"DEBUG"	22556	"2019-08-02 15:28:32.953"	"Executing task DeliveryTask in work queue SMTP delivery queue"
"DEBUG"	22556	"2019-08-02 15:28:32.954"	"Delivering message..."
"APPLICATION"	22556	"2019-08-02 15:28:32.955"	"SMTPDeliverer - Message 21936: Delivering message from TrainingSupport@pjm.com to Artw@constellation.com. File: G:\Program Files (x86)\hMailServer\Data\{BB4927A0-2474-47C3-A1AB-A0A217B0CD23}.eml"
"DEBUG"	22556	"2019-08-02 15:28:32.956"	"Applying rules"
"DEBUG"	22556	"2019-08-02 15:28:32.957"	"Performing local delivery"
"DEBUG"	22556	"2019-08-02 15:28:32.958"	"Local delivery completed"
"TCPIP"	22556	"2019-08-02 15:28:32.960"	"DNS MX lookup: constellation.com"
"TCPIP"	22556	"2019-08-02 15:28:33.618"	"DNS - MX Result: 8 IP addresses were found."
"DEBUG"	22556	"2019-08-02 15:28:33.619"	"Starting external delivery process. Server: esa-omf-101.exeloncorp.com (216.99.189.20), Port: 25, Security: 2, User name: "
"DEBUG"	22556	"2019-08-02 15:28:33.620"	"Creating session 10"
"TCPIP"	22556	"2019-08-02 15:28:33.621"	"Connecting to 216.99.189.20:25..."
"DEBUG"	19520	"2019-08-02 15:28:33.652"	"TCP connection started for session 10"
"SMTPC"	19520	10	"2019-08-02 15:28:33.758"	"216.99.189.20"	"RECEIVED: 220 ********************************"
"SMTPC"	19520	10	"2019-08-02 15:28:33.759"	"216.99.189.20"	"SENT: EHLO smtp2.pjmtrainingsupport.com"
"SMTPC"	22332	10	"2019-08-02 15:28:33.862"	"216.99.189.20"	"RECEIVED: 250-esa-omf-101.exeloncorp.com[nl]250-8BITMIME[nl]250-SIZE 41943040[nl]250 XXXXXXXA"
"SMTPC"	22332	10	"2019-08-02 15:28:33.863"	"216.99.189.20"	"SENT: MAIL FROM:<TrainingSupport@pjm.com>"
"SMTPC"	2200	10	"2019-08-02 15:28:33.895"	"216.99.189.20"	"RECEIVED: 530 #5.7.0 This sender must issue a STARTTLS command first"
"SMTPC"	2200	10	"2019-08-02 15:28:33.896"	"216.99.189.20"	"SENT: QUIT"
"SMTPC"	5188	10	"2019-08-02 15:28:33.926"	"216.99.189.20"	"RECEIVED: 221 esa-omf-101.exeloncorp.com"
"DEBUG"	5188	"2019-08-02 15:28:33.927"	"Ending session 10"
"DEBUG"	22556	"2019-08-02 15:28:33.928"	"External delivery process completed"
"DEBUG"	22556	"2019-08-02 15:28:33.929"	"Summarizing delivery result"
"DEBUG"	22556	"2019-08-02 15:28:33.931"	"AWStats::LogDeliveryFailure"
"DEBUG"	22556	"2019-08-02 15:28:33.932"	"AWStats::LogDeliveryFailure"
"DEBUG"	22556	"2019-08-02 15:28:33.934"	"Summarized delivery results"
"DEBUG"	22556	"2019-08-02 15:28:33.935"	"SD::SubmitErrorLog_"
"DEBUG"	22556	"2019-08-02 15:28:33.939"	"Saving message: {A52F3CF3-7484-4914-9676-2870553E746A}.eml"
"DEBUG"	22556	"2019-08-02 15:28:33.945"	"SD::~SubmitErrorLog_"
"DEBUG"	22556	"2019-08-02 15:28:33.946"	"Deleting message"
"DEBUG"	22556	"2019-08-02 15:28:33.948"	"Deleting message file."
"APPLICATION"	22556	"2019-08-02 15:28:33.949"	"SMTPDeliverer - Message 21936: Message delivery thread completed."
mikedibella
Post by mikedibella » 2019-08-03 00:08
The remote server is not RFC compliant. This is not advertising that it supports STARTTLS in response to the EHLO verb, so hMailServer thinks it does not. You can not fix this issue, the remote server's operator has to.
mikedibella
Post by mikedibella » 2019-08-03 00:41
220 esa-omf-101.exeloncorp.com ESMTP
EHLO xxx
250-8BITMIME
250-SIZE 20971520
250 STARTTLS
This is what I get when I query that SMTP host. I'm not sure why STARTTLS isn't showing in the logging you provided. Unless hMailServer sees STARTTLS in the EHLO response, it won't try to secure the connection.
Post by mattg » 2019-08-03 02:04
I'm guessing that the sender domain is actually hosted on that SMTP server, and that the FROM is seen as a local address on that machine, and the end server requires SSL/TLS for AUTH
VinceO
Post by VinceO » 2019-08-05 15:42
I asked support for the receiving mail server for their thoughts on the missing STARTTLS and RFC 3207.
Not sure I completely understand how to test the situation in mattg's Domain comment. The sender domain is different from the mail server domain, but I'll explore this.
Any other thoughts would be appreciated.
Post by mattg » 2019-08-06 00:48
This IS a misconfiguration
Either the receiving server is broken
OR
You are you using a domain on your server that you don't necessarily have rights to, and the recipient server is ALSO hosting the same domain
mikedibella
Post by mikedibella » 2019-08-06 04:24
I wonder if the remote server has been configured to require secure connections, but a certificate has not been properly configured or has expired and the server was restarted, resulting in a mismatch between the ELHO verb response and the MAIL verb response.
VinceO
Post by VinceO » 2019-08-07 20:26
MXToolbox suggests that all is well with the remote server
I own the domain that the local server is in and have created the appropriate SPF record.
The local server sends emails to 100's of other domains, however the remote server we are having issues with might be the only server that requires STARTTLS. In fact I see no instances in the logs where STARTTLS was found from any of the 100's of email servers that we interface with.
The sending server has no accounts and exists for accepting emails generated by a set of local applications and forward them remote email servers.
VinceO
Post by VinceO » 2019-08-07 22:38
Anyone with a server that requires STARTTLS interested in receiving a test note?
mikedibella
Post by mikedibella » 2019-08-07 22:47
I think you really need to focus on the discrepancy between what hMailServer is seeing as the EHLO response verses what mxtoolbox.com is reporting.
If you issue a telnet command from the hMailServer host to the remote host esa-omf-101.exeloncorp.com on port 25, and issue the EHLO verb, do you see STARTTLS in the response?
mikedibella
Post by mikedibella » 2019-08-07 23:06
Some anti-virus software may block email over secure connections becuase these emails are harder to scan. So it is conceivable that such an implementation might replace the STARTTLS keywork in the ELHO with something else, like the XXXXXXXA you are seeing.
Also could be this bug: https://www.cisco.com/c/en/us/support/d ... sa-00.html
Post by mattg » 2019-08-08 01:16
I've sent you a private message VinceO
I agree with mikedibella though
When I test that server, I get a StartTLS response.
I think you have Antivirus or an EDGE device that 'inspects' mail that gets in the way...
VinceO
Post by VinceO » 2019-08-13 00:50
Thanks for your assistance.
The firewall had ESMTP inspection enabled and TLS was not allowed.
Since we only have outgoing mail, we decided to disable ESMTP inspection.
