charleso
- Normal user
Post
by charleso » 2019-06-20 01:06
Please each time i do a windows update on my 2016 windows server, every 2-3 months , i run into one sql server connection error on Hmailserver on another.
This is the latest error:
ADO [DBNETLIB][ConnectionRead (recv()).]General network error.
Please is there anything i can do to fix this. my mail server has been down for hours.
Thanks.
- Moderator
Post
by mattg » 2019-06-20 02:01
Is your SQL server on another machine?
Which database do you use?
Please show the contents of your hmailserver.ini file with passwords removed
charleso
- Normal user
Post
by charleso » 2019-06-20 02:19
IT's all on the same machine.
SQL Server 2017 standard
ProgramFolder=C:\Program Files (x86)\hMailServer
DatabaseFolder=C:\Program Files (x86)\hMailServer\Database
DataFolder=C:\Program Files (x86)\hMailServer\Data
LogFolder=C:\Program Files (x86)\hMailServer\Logs
TempFolder=C:\Program Files (x86)\hMailServer\Temp
EventFolder=C:\Program Files (x86)\hMailServer\Events
[GUILanguages]
[Security]
AdministratorPassword=XXX
Type=MSSQL
Username=sa
Password=XXX
Port=0
Server=.
Database=mailserver
Internal=0
[Settings]
DisableAUTHList=25
This is the config i have been using for several months. It's just after today's windows update which included Security Update for SQL Server 2017 (KB4494351), that this error started on restarting the machine
charleso
- Normal user
Post
by charleso » 2019-06-20 09:32
SOLVED:
simply upgraded to a newer version of HmailServer
charleso
- Normal user
Post
by charleso » 2019-06-20 10:35
wow, now i restart and get this:
Please any help?
- Moderator
Post
by jimimaseye » 2019-06-20 12:02
Perhaps you should review the detail behind the windows update KB4494351 (that caused you the problem). Maybe there are new features/securities in place that you need to work through. Also, check the database is available (port, name, etc). After all, Hmailserver is merely trying to connect to a database that you have told it to and something is stopping it from doing so. (Is it there? Available? TLS required?)
charleso
- Normal user
Post
by charleso » 2019-06-20 12:13
jimimaseye wrote: ↑2019-06-20 12:02
The SQL server works fine, i can even access it remotely. Other applications accessing the same sql server have no issues, just hMailServer fails ... even after successfully upgrading to the laters version this morning
- Moderator
Post
by jimimaseye » 2019-06-20 12:18
charleso wrote: ↑2019-06-20 12:13
Upgrading HMS will not make a difference. You have a configuration issue that has been introduced by that last Windows Update. HMS will only try to connect according to how it, and the machine it runs on, has been configured.
charleso
- Normal user
Post
by charleso » 2019-06-20 12:20
I installed the updated hmailserver this morning, and it all worked fine.
I restarted the server , and now i have this issue.
I have not changed any configs.
- Senior user
Post
by Dravion » 2019-06-20 12:28
The Database is not ready or reachable as hMailServer
at this point time. Durnibg Setup, make sure you selected the MSSQL Service as Dependency.
- Moderator
Post
by jimimaseye » 2019-06-20 12:30
charleso wrote: ↑2019-06-20 12:20
....and you didnt change HMS either.
But you HAVE changed the machine setup (by doing a reboot). Services stop and should restart (but maybe dont). Dependancies change. As Dravion says, check the service dependancies.
charleso
- Normal user
Post
by charleso » 2019-06-20 12:36
steps:
1) restarted the server
2) ensure MSSQLSERVER service is running
3) ensure i can connect / access the sql server remotely from my laptop
4) then i remote into the server and try to start hMailServer Asministrator
I then get the error:
- Moderator
Post
by jimimaseye » 2019-06-20 12:51
Dravion wrote: ↑2019-06-20 12:28
Run "DBSetup".......
charleso
- Normal user
Post
by charleso » 2019-06-20 13:00
jimimaseye wrote: ↑2019-06-20 12:51
WOW it works now. God Bless!
... but let me restart the server and see if the problem comes again
charleso
- Normal user
Post
by charleso » 2019-06-20 13:16
Restarted successfully!. Thanks again
