net_io_connectionclosed!
wayi
Post by wayi » 2019-06-03 12:10
I am attempting to test outgoing mail task in my application without have an SMTP Server. I have installed and configured hMailServer as described. When I attempt to send an email, I get ...
[Send Mail Task] Error: An error occurred with the following error message: "Failure sending mail. System.IO.IOException: Unable to read data from the transport connection: net_io_connectionclosed.".
The only thing I wasn't sure of was one thing in the configuration details. I used all the defaults as instructed, but where it calls for updating the host file, it didn't specify the IP address, so the line I added was
127.0.0.1 localhost.com
Re: net_io_connectionclosed!
Post by mattg » 2019-06-03 14:57
Please enable all logging, try to send again and post all of the logs created
ALSO run this and post the results run this and post the results: https://www.hmailserver.com/forum/viewt ... 20&t=30914
(You normally shouldn't need to edit the hosts files except in a VERY specific circumstance)
Post by palinka » 2019-06-03 17:45
wayi wrote:
2019-06-03 12:10
localhost.com IS NOT localhost!
