Copy oMessage to IMAP Folder
Post by katip » 2019-04-03 09:00
account rule calls a function where it tries to copy oMessage to an IMAP folder of another account.
Dim obDomain, obAccount, obFwdFolder
Set obDomain = obApp.Domains.ItemByName(strDomain)
Set obAccount = obDomain.Accounts.ItemByAddress(arrFwdAdd) '<-  copy message to this account's inbox
Set obFwdFolder = obAccount.IMAPFolders.ItemByName("Inbox")
oMessage.Copy(obFwdFolder.ID)
oMessage.Copy(obFwdFolder.ID) fails with "Script Error: Source: hMailServer COM library - Error: 800403E9 - Description: Unable to copy message."
app authenticate is with administrator account. so, no permission issue i think.
i found this : https://www.hmailserver.com/forum/viewt ... 52#p165620
@Soren, do you still think such copying is not possible? or is my case something irrelevant?
Re: Copy oMessage to IMAP Folder
Post by jimimaseye » 2019-04-03 09:06
You cannot do it.
It is stated in the documentation that you cannot copy emails between accounts - only folders within the same account (except for public accounts).
Post by katip » 2019-04-03 09:16
thanks, i haven't seen it.
any suggestion how to copy this message to another acccount (like forward in rules)?
i already do this by creating new message from current one and addRecipient etc..
but just looking for a more complete solution where message is copied "as is".
Post by mattg » 2019-04-03 10:09
You can probably just 'add receipient' and save the message early in the journey through your server, somewhere like 'OnAcceptMessage'
Post by katip » 2019-04-03 10:49
or better i mark it with a header such as "X-HMS-ToBeForwarded = Yes"
put a subsequent rule in account which reads this and if Yes forwards to x,y,z
let me try. thanks.
Post by katip » 2019-04-03 11:45
katip wrote:
2019-04-03 10:49
no, silly me, then i don't know which of x,y,z or all 3 should get a copy (function knows it!!).
setting X-HMS-ToBeForwarded = x,y,z may do the job but then i must write 3 rules for each of them (if X-HMS-ToBeForwarded contains x then forward to x etc...)
not feasible to maintain if x,y,z... change frequently (such as in our office).
Post by SorenR » 2019-04-03 13:56
katip wrote:
2019-04-03 09:00
Alternative would include something like this... IIRC you need to tamper with the header "Message-ID" for hMailServer to accept and index the message...
NB: Code is untested but passes Syntax Check :wink:
Call oApp.Authenticate("ADMIN", "PASSWORD")
Dim oFSO : Set oFSO = CreateObject("Scripting.FileSystemObject")
strFile = "C:\SomeDirectory\" & Mid(oMessage.filename, InStr(oMessage.filename, "{"))
Call oFSO.CopyFile(oMessage.filename, strFile, True)
Dim oDomain : Set oDomain = oApp.Domains.ItemByName("acme.inc")
Dim oAccount : Set oAccount = oDomain.Accounts.ItemByAddress("wile.e.coyote@acme.inc")
Call oApp.Utilities.ImportMessageFromFileToIMAPFolder(strFile, oAccount.ID, "Inbox.Spam")
Set oFSO = Nothing
Set oApp = Nothing
Post by katip » 2019-04-03 15:50
2019-04-03 13:56
thanks for clever suggestion. yes exactly, that Message-ID thing.
i adjusted your code and tried.
all runs perfectly. file written to temp dir with correct full name. no any errors at all. but action below silently fails somehow. no message arrives.
Call oApp.Utilities.ImportMessageFromFileToIMAPFolder(strFile, oAccount.ID, "Inbox")
even oEventLog.Write fires my own "...successfully forwarded... blah.." info from near end function.
all is fine but message don't show up in "Inbox". i checked it on file system too. nowhere except that copy in temp dir.
that would be a perfect solution for me, if it'd work.
//EDIT: Call oApp.Utilities.ImportMessageFromFile(strFile, oAccount.ID) don't work either, again silently.
Post by SorenR » 2019-04-03 16:10
katip wrote:
2019-04-03 15:50
2019-04-03 13:56
I have it test on my system right now. Header "Message-ID" must be altered in the file outside hMailServer database... I remember we had some some fun with it a couple of years ago but it was quite tricky IIRC.
I have not given up on this yet :mrgreen:
Post by SorenR » 2019-04-03 16:36
I knew I had it working at some point...
https://www.hmailserver.com/forum/viewt ... 15#p166615
Will continue experimenting :mrgreen:
Post by SorenR » 2019-04-03 17:03
Partial success ...
It appears to work... The header "Message-ID" is changed and file is read (and removed) from Data directory and the call to oApp.Utilities.ImportMessageFromFileToIMAPFolder() returns "True" ... Only ... I'm having trouble finding the imported message :roll:
I have switched off Performance/Indexing and cleared it since this is the only table where I have found "Message-ID", just to be on the safe side.
Sub OnDeliveryStart(oMessage)
   ' Give permission to access all hMailServer settings.
   ' Copy message file to external directory.
   Dim strFile, oFSO : Set oFSO = CreateObject("Scripting.FileSystemObject")
   strFile = "C:\hMailServer\Data\" & Mid(oMessage.filename, InStr(oMessage.filename, "{"))
   ' Change "Message-ID"
   Dim strOldText, strNewText
   With oFSO.OpenTextFile(strFile, 1)
      strOldText = .ReadAll
   strNewText = Replace(strOldText, "Message-ID: <", "Message-ID: <copy.")
   With oFSO.OpenTextFile(strFile, 2)
      .WriteLine strNewText
   ' Import message.
   Dim rc, oDomain : Set oDomain = oApp.Domains.ItemByName("acme.inc")
   rc = oApp.Utilities.ImportMessageFromFileToIMAPFolder(strFile, oAccount.ID, "INBOX")
   EventLog.Write( "rc = " & rc ) ' <-- Will return "True" if successful
   ' Clean up.
   Set oFSO = Nothing
   Set oApp = Nothing
Post by katip » 2019-04-03 18:55
2019-04-03 17:03
Partial success ...
yes, me too :?
1.
docus say :
ImportMessageFromFile(string sFilename, long iAccountID)
Imports a message from a file on disk for delivery or to a specific account.
i understand that import can be done from any location on disk, not necessarily from HMS\data directory.
anyway i tried also data directory. nothing changes.
2.
there is definitely no error. also debug + app log shows all clean.
3.
frankly spoken i don't understand this Message-ID issue. this is nowhere in any table on HMS database. or am i blind. you mean you see this somewhere in source code? it should stay in cache then? anyway i don't think this affects delivery, we have seen this on the other thread. seperate deliveries do coexist with identical Message-ID's.
ok, it's not a problem to rewrite it but i'm really confused now.
Post by SorenR » 2019-04-03 19:27
katip wrote:
2019-04-03 18:55
2019-04-03 17:03
Partial success ...
yes, me too :?
1.
docus say :
2.
3.
2: The function returns "True" if successful and "False" if fail.
3: Message-ID is indexed if "Performance" settings are used.
I'm looking at the source while doing this... There are about 15 ways this can fail and there are NO (!) error messages in the source - it only says "return false" :evil:
What is confusing is that it seems like it can also be used to "update" (?!?) existing message files... But why?
The internal function is shared between "ImportMessageFromFile" and "ImportMessageFromFileToIMAPFolder" and the first I have used before with no issues.
I think I may have to modify the source to include error messages - if I can figure out how :mrgreen:
Post by SorenR » 2019-04-03 19:46
Time for dinner break.
I'm going to go through the source so I may have some news tomorrow.
Post by katip » 2019-04-03 19:57
Thank you, have a nice evening.
we see tomorrow..
Post by SorenR » 2019-04-04 02:09
Well... Gave up... Started to poke around my old posts here and found this...
You can call it from e.g. OnAcceptMessage but I made an Account rule to call function "CopyMail".
It will clone the message, change Message-ID, add recipient and put it back in the queue.
Optionally you can add a custom header and have a rule check for it and "Move to Folder" ;-)
Sub CopyMail(oMessage)
   Dim sFile, sMessageFilename, sNewMessageFilename, sMessageID
      sNewMessageFilename = .Filename
      sMessageId = oMessage.HeaderValue("Message-ID")
      sMessageFilename = oMessage.Filename
         .CopyFile sMessageFilename, sNewMessageFilename, True
      .RefreshContent
'*    .From = "John Doe <info@mydomain.tld>"
'*    .FromAddress = "info@mydomain.tld"
      .AddRecipient "Wile E. Coyote", "wile.e.coyote@acme.inc" ' <--- NEW RECIPIENT HERE !!
      sMessageID = "<1." & Mid(sMessageID,2) & ">"
      .HeaderValue("Message-ID") = sMessageID
      .Save
Post by katip » 2019-04-04 09:06
2019-04-04 02:09
      .RefreshContent
      .Save
very nice!
lesson for me:
1. yes, in fact we need a new file name. i fell into trap by ignoring the fact that file names are unique and tried to import from same file name. HMS likely discarded it silently.
2. Message-ID is crucial, but how, i didn't understand. i tried both with original and &1.&original. the one with original failed again. so, Message-Id must be changed.
3. as Message-ID changes, my query on external table must check for both (messageid = strMessageId OR messageid =sMessageID) . otherwise dilemma :lol: but no problem, done!
thank you again! have a nice day..
