How to set up DKIM on HMS for domain with multiple names
ABPT2251
Post by ABPT2251 » 2018-09-20 09:15
I have been running hms for quite some time and have implemented DKIM for my domain. However my domain has a number of 'names' for which DKIM is not working.
I would appreciate some guidance on how to implement DKIM for the other names my domain goes under.
Regards
Norman
Re: How to set up DKIM on HMS for domain with multiple names
Post by mattg » 2018-09-20 10:35
You can't
DKIM only works for domains, not domain names (aliases)
ABPT2251
Post by ABPT2251 » 2018-09-22 10:09
Thanks Matt. Mmmm thought so.
So, I have a number of alias domain names but in hms I have set accounts only to one domain and they receive mail from the different domains. How may I achieve this and use DKIM?
Regards
Norman
Post by jimimaseye » 2018-09-22 10:25
Out of interest what happens if you apply the public dkim record of the master domain to the dns of the alias domains (as shown in stage 2 here )?
Post by mattg » 2018-09-22 23:45
ABPT2251 wrote:
2018-09-22 10:09
Create all domains as real domains, and use message forwarding to keep messages on a single domain
Why would you need to do this?
ABPT2251
Post by ABPT2251 » 2018-09-28 10:20
Hi Jimimaseye,
I did try using the master DKIM for the alias domains and the DKIM fails.
Hi Mattg,
I suppose that you may be correct but it seems very redundant.
We have a number of domains which are variations of our public name eg abc.com.au alphabetacam.com abc.com nad are used in email. However any email to John@... needs to be sent to John whatever the domain variation used. I hope that this makes some sense. Maybe we need to rationalise this.
Thank for your help.
Post by jimimaseye » 2018-09-28 14:29
And John must reply under the same domain to which he was first addressed? Or can he reply as the master domain?
ABPT2251
Post by ABPT2251 » 2018-10-05 15:56
My apologies for taking so long.
John can reply from one domain. So, I guess that's the one I Dkim!
Post by jimimaseye » 2018-10-05 19:05
Exactly. The main domain.
ABPT2251
Post by ABPT2251 » 2018-10-05 22:32
Thank you Jimimaseye for your patient responses.
