Powershell Script to disable user based on the number of e-mail sent.
pauloroberto
Post by pauloroberto » 2018-06-15 21:21
Hello people,
Here's a new Powershell script to disable accounts based on the number of e-mails sent, this could help to avoid lost credentials abused by spammers.
Requeriments:
This script: viewtopic.php?t=32836
At least Powershell V3
PS: SorenR gave me a tip to use AWStat, if you transform AWStat log on CSV (comma) with "From" and "To" values, it should work too.
Script criado por Paulo Roberto (pauloroberto [arroba] conectadores [ponto] com [ponto] br)
Disable accounts based on the number of e-mails sent
$password="Your Super secret hmail password"
#maximum number of e-mails sent by some account, please change this
[int]$Maximum=10
$hmail=New-Object -ComObject hMailServer.Application
$hmail.Authenticate('Administrator',"$password")
#CSV from previus script
$Planilha="D:\Folder to save\Log-$(get-date -Format yyyyMMdd).csv"
#If you want, a new CSV containing the e-mail addresses and number of e-mails sent.
$Control="D:\Folder to save\Control-$(get-date -Format yyyyMMdd).csv"
"`"Email`",`"Numero`"" | Out-File $Control
$dominios=$hmail.Domains
[array]$NomeDominio=@()
for ($i = 0; $i -lt ($dominios.Count); $i++)
    $NomeDominio+=($dominios[$i]).name
[array]$Tabela=@()
Import-Csv $Planilha | ForEach-Object `
    $item=$_
    foreach ($nome in $NomeDominio)
        if ($item.from -like "*$nome")
            [array]$para=($item.to).Split(",")
            if ($Tabela | where {$_.Email -like "$($item.from)"})
                $atual=($Tabela | where {$_.Email -like "$($item.from)"})
                $atual=$atual.Vezes + $para.Count
                ($Tabela | where {$_.Email -like "$($item.from)"}).vezes=$atual
            else
                $object = New-Object -TypeName PSObject
                $object | Add-Member -Name 'Email' -MemberType Noteproperty -Value "$($item.De)"
                $object | Add-Member -Name 'Vezes' -MemberType Noteproperty -Value $para.Count
                $Tabela+=$object
$Tabela | Export-Csv -NoTypeInformation $Control
# The following will disable the accounts
$agressores=$tabela | where {$_.vezes -gt "$maximum"}
foreach ($conta in $agressores)
    $Dominio=($conta.email -split "@")[1]
    for ($i = 0; $i -lt ($hmail.Domains).Count; $i++)
        if (($hmail.Domains)[$i].Name -like "$Dominio")
            $ObjetoDominio=($hmail.Domains)[$i]
    for ($i = 0; $i -lt ($ObjetoDominio.Accounts).Count; $i++)
        if (($ObjetoDominio.Accounts)[$i].Address -like "$($conta.email)")
            $ObjetoConta=$ObjetoDominio.Accounts[$i]
    $ObjetoConta.Active=$false
    $ObjetoConta.Save()
#As an example, I'm creating a credential with text, please, don't do this on a production enviroment.
$user="email@domain"
$password = convertto-securestring -String "YOUR SUPER SECRET PASSWORD" -AsPlainText -Force
$credential=New-Object -TypeName System.Management.Automation.PSCredential -ArgumentList ($user, $password)
#Send you a message
Send-MailMessage -Body "Due to maximum limit reached, the following accounts were disabled:`n$($agressores)"  -From your@email -To Your@email -Subject "Your Subject" -SmtpServer Hmail.address -port 587 -Credential $credential
You could use a schedule task to run the script automatically, sure you need to save the password in a better way (not plain text).
Hope this helps someone.
Re: Powershell Script to disable user based on the number of e-mail sent.
Post by SorenR » 2018-06-15 23:36
Something like this ??
viewtopic.php?f=20&t=28269
The script is pasted into EventHandlers.vbs so it's real-time ...
pauloroberto
Post by pauloroberto » 2018-06-16 01:54
Understood...
pauloroberto
Post by pauloroberto » 2018-06-16 01:56
Hey man, how do I delete the post?
Post by SorenR » 2018-06-16 08:34
pauloroberto wrote:
2018-06-16 01:56
You don't.
But it is no problem. Some day, someone may need inspiration on how to use hMailServer with PowerShell and they can see how you did it.
Post by palinka » 2020-03-04 14:32
2018-06-16 08:34
pauloroberto wrote:
2018-06-16 01:56
You don't.
That day has come. :mrgreen:
