winmail.dat convert generate error
DanneG
Post by DanneG » 2017-12-12 13:31
Hi!
I try to use a script I found in the forum to convert winmail.dat files. The files are saved to disk but when trying to load the files back into the mail, I get an error message.
Can anyone see why?
"ERROR" 3032 "2017-12-12 00:04:04.425" "Script Error: Source: hMailServer COM library - Error: 800403E9 - Description: Failed to attach file. - Line: 119 Column: 8 - Code: (null)"
Line 119 is:
Call oMessage.Attachments.Add(obFile.Path)
Here is the code:
	Const g_sTempPath = "D:\temp"
	Const g_sTnefPath = """C:\Program\Winmail Opener\wmopener.exe"""
	Const g_sCmdPath = "c:\WINDOWS\system32\cmd.exe"
	ExtractTNEFAttachments(oMessage)
Sub ExtractTNEFAttachments(oMessage)
' Iterates over all attachments and checks where
' there's a TNEF-attachment we should decode.
Dim obAttachments
Set obAttachments = oMessage.Attachments
For i = 1 to obAttachments.Count
dim obAttachment
set obAttachment = obAttachments.Item(i-1)
' DebugLog.Log "Attachment Filename: " & obAttachment.FileName, null
If trim(LCase(obAttachment.FileName)) = "winmail.dat" OR trim(LCase(obAttachment.FileName)) = "win.dat" Then
Call ExtractTNEF(oMessage, obAttachment)
Sub ExtractTNEF(oMessage, obAttachment)
' Extracts the TNEF attachments from a winmail.dat
' Generate a random string. Used for directory name.
Dim obUtilities
Set obUtilities = CreateObject("hMailServer.Utilities")
Dim sGUID
sGUID = obUtilities.GenerateGUID
Set obUtilities = Nothing
' Generate GUID-based temporary directory name
Dim sOutPath
sOutPath = g_sTempPath & "\" & sGUID
' Create the directory
Dim obFS
Set obFS = CreateObject("Scripting.FileSystemObject")
Call obFS.CreateFolder(sOutPath)
' Extract the file to a temporary directory.
Dim sAttachmentFile
sAttachmentFile = sOutPath & "\winmail.dat"
Call obAttachment.SaveAs(sAttachmentFile)
' Create an output directory for the extracted
' attachments.
Dim sAttachmentsDirctory
sAttachmentsDirctory = sOutPath & "\output"
Call obFS.CreateFolder(sAttachmentsDirctory)
' Run tnef-decoder.
Dim sCommandLine
sCommandLine = g_sTnefPath & " " & sAttachmentFile & " " & sAttachmentsDirctory
Call RunCommand(sCommandLine)
' Check the output directory for extracted files
Dim obFiles
Set obFiles = obFS.GetFolder(sAttachmentsDirctory).Files
      ' Go through the output directory, and see if theres
      ' any extracted ifles
      Dim obFile
      For Each obFile in obFiles
        ' Add this as an attachment to the message,
        ' if it's not named winmail.dat. No point
        ' in adding itself...
If obFiles.Count > 0 Then
' Delete the original attachment.
obAttachment.Delete
' Since the message has been modified, we need to save it.
Set obFiles = Nothing
' Delete the temporary folder
Call obFS.DeleteFolder(sOutPath)
Function RunCommand(sCommand)
' Runs a command
Dim obShell
Set obShell = CreateObject("WScript.Shell")
' Run the command
obShell.Run sCommand, 0, True
Set obShell = Nothing
Re: winmail.dat convert generate error
Post by mattg » 2017-12-13 00:23
I suspect that it has to do with the D Drive path for the temp directory
IS D a mapped drive or a local drive? Can you use a temp directory from the C drive
DanneG
Post by DanneG » 2017-12-13 09:30
D is local drive, changed to c:\tmp and the same result.
I can see the output folder on C:\tmp\{081A271F-4D05-4E16-B114-47249DB5E874} and all the files in the winmail.dat in the directory
Post by jimimaseye » 2017-12-13 09:33
Have you installed this? Where did you get this from?
(What is the original thread of the script?)
DanneG
Post by DanneG » 2017-12-13 09:42
Yes the program is installed and working (http://winmail-opener.software.informer.com/1.5/)
The script is saving and extracting the winmail.dat file without problem.
the problem occurs when it´s loading the extracted files into the mail.
estradis
Post by estradis » 2017-12-13 12:03
DanneG wrote:Hi!
Can anyone see why?
Line 119 is:
Here is the code:
I guess, your "calls" are the problem. You don't need them inside your script.
You should replace with
ExtractTNEF oMessage, obAttachment
The brackets must not be used when no result is returned.
Hope that helps
DanneG
Post by DanneG » 2017-12-13 12:25
I think this script orginal is for Hmailser 4..
Perhaps i need to use other functions?
I Still get:
"ERROR"	2652	"2017-12-13 11:21:36.457"	"Script Error: Source: hMailServer COM library - Error: 800403E9 - Description: Failed to attach file. - Line: 119 Column: 8 - Code: (null)"
Line 119 is:
My code:
	Const g_sTempPath = "C:\tmp"
Dim obAttachments
dim obAttachment
Dim obUtilities
Dim sGUID
Dim sOutPath
Dim obFS
Dim sAttachmentFile
' attachments.
' Run tnef-decoder.
Dim sCommandLine
Dim obFiles
      Dim obFile
obAttachment.Delete
' Runs a command
Dim obShell
' Run the command
estradis
Post by estradis » 2017-12-13 13:03
DanneG wrote:I think this script orginal is for Hmailser 4..
I Still get:
Line 119 is:
My code:
      Dim obFile
' Guess that "DebugLog.Log" is your way to log outputs?
' If yes, try this:
' DebugLog.Log "objFile.Path= *" & objFile.Path & "*", null
Have you already tried to output the value of objFile.Path, immediately before output?
PS: I wrote the message above because I experienced a lot of such problems in vbscript using unnecessary calls or brackets.
