Error 554
gtsolid
Error 554
Post by gtsolid » 2017-11-16 13:33
Hi
i installed W10 on my PC and installed Outlook. when i try to configure i receive the attached error.
i think it's a problem of credentials. What should i check?
Re: Error 554
Post by jimimaseye » 2017-11-16 14:00
run this and post the results: viewtopic.php?f=20&t=30914
Also enable SMTP and APPLICATION logging (only), retry to send, and then post the log file results.
gtsolid
Re: Error 554
Post by gtsolid » 2017-11-16 14:05
i would to place your file from my PC to hmailserverPC but i receive this error. surely there is an error
gtsolid
Re: Error 554
Post by gtsolid » 2017-11-16 15:42
in fact, when your program tries to write results, i receive this:
Re: Error 554
Post by jimimaseye » 2017-11-16 17:20
This all suggets that you have problems with your server. Disk space? Write permissions?
Go to the server itself and run the script from the server. Look at the storage on the server and its permissions and availability.
gtsolid
Re: Error 554
Post by gtsolid » 2017-11-16 18:23
The server was full of hmail log, some of these weigh about 500MB. Is it normal?
Re: Error 554
Post by jimimaseye » 2017-11-16 19:38
Not normally. It depends on what logging you have and if there are any problems.
Thats why you need to run the script so we can take a look at your setup.
Re: Error 554
Post by mattg » 2017-11-16 23:52
It is safe to delete / compress hmailserver that are not from this month, main log not from today.
They compress very well, as they are full of white space
by not logging IMAP (I have some very large accounts) my logs are rarely above 5 MB uncompressed
If you allow messages stored on your server for large POP3 accounts, or you POP3 external download from large accounts and leave messages on third party server, you should NOT log POP3 routinely either
gtsolid
Re: Error 554
Post by gtsolid » 2017-11-20 16:56
Here the report:
[code]2017-11-20 Hmailserver: 5.6.4-B2283
DOMAINS
"Domain1.com" - pex.it Enabled: True
Enabled: False Max size: 0 Enabled: False
Max message size: 0 Plus addressing: False
Max size of accounts: 0
Greylisting: False
"Domain2.com" - texxxxxxx.net Enabled: True
Greylisting: False
"Domain3.com" - vmxxxxx.net Enabled: True
Greylisting: False
IP RANGES
Allow connections Other
SMTP: True Antispam : True !! 'Spam tests' not enabled !!
POP3: True Antivirus: True !! ANTIVIRUS NOT CONFIGURED !!
IMAP: True SSL/TLS: False
AUTOBANNED Local Addresses:
No entries
AUTOBAN
Autoban Enabled: False
INCOMING RELAYS
No entries
MIRRORING Disabled
PROTOCOLS
SMTP
No. Connections: 0 No Retries: 4 Mins: 60 Plain Text: False Bind:
Host: EXTERNAL.TLD Empty sender: True Batch recipients: 100
Max Msg Size: 20480 Relay:- Incorrect endings: True Use STARTTLS: True
Loop limit: 5
Recipient hosts: 15
Routes:
No routes defined.
POP3
No. Connections: 0
IMAP
IMAP Quota: True
IMAP Idle: True
IMAP ACL: True
Delim: "."
ANTISPAM
Spam Mark: 5 Use SPF: False Use Spamassassin: False
Add X-HmailServer-Spam: True Check HELO host: False
Add X-HmailServer-Reason: True Check MX records: False
Add X-HmailServer-Subject: False Verify DKIM: False
DNSBL ENTRIES:
No 'enabled' entries
SURBL ENTRIES:
GREYLISTING:
Greylisting: False
WHITELISTING
No entries
Block Attachments: False
SSL/TLS
SSL 3.0 : False
TLS 1.0 : True
TLS 1.1 : True
SslCipherList :
RC4-SHA - HIGH - !aNULL
!eNULL - !EXPORT - !DES
!3DES - !MD5 - !PSK;
TCPIP PORTS Connection Sec
0.0.0.0 / 25 / SMTP - None
0.0.0.0 / 110 / POP3 - None
0.0.0.0 / 143 / IMAP - None
0.0.0.0 / 587 / SMTP - None
LOGGING Logging Enabled: True
Paths:-
Current: C:\Program Files (x86)\hMailServer\Logs\hmailserver_2017-11-20.log
Error: C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2017-11-20.log - !! ERRORS PRESENT !!
APPLICATION - True
SMTP - True
POP3 - .
IMAP - .
TCPIP - .
DEBUG - .
AWSTATS - .
SYSTEM TESTS
Database type: MSSQL Compact
HMAILSERVER.INI
Type= MSSQLCE
Username=
Port= 0
Server=
Internal= 1
[/code]
Generated by HMSSettingsDiagnostics v1.84, Hmailserver Forum.
Re: Error 554
Post by jimimaseye » 2017-11-20 17:18
Have you looked at this: ERROR_hmailserver_2017-11-20.log - !! ERRORS PRESENT !! ?
gtsolid
Re: Error 554
Post by gtsolid » 2017-11-21 15:10
here the message
"ERROR"	2628	"2017-11-20 14:06:08.629"	"Severity: 3 (Medium), Code: HM4403, Source: Message::GetHeader, Description: Could not read the message header, since the file was not available. File: C:\Program Files (x86)\hMailServer\Data\vms-tvd.net\vironda\A7\{A7E4DB7F-799E-4B21-9282-2CE4EDCFEE02}.eml"
"ERROR"	2628	"2017-11-20 14:06:08.644"	"Severity: 3 (Medium), Code: HM4403, Source: Message::GetHeader, Description: Could not read the message header, since the file was not available. File: C:\Program Files (x86)\hMailServer\Data\vms-tvd.net\vironda\45\{45C0B4BC-9C26-4919-BBC3-5026EBFFBF4E}.eml"
"ERROR"	2628	"2017-11-20 14:06:08.644"	"Severity: 3 (Medium), Code: HM4403, Source: Message::GetHeader, Description: Could not read the message header, since the file was not available. File: C:\Program Files (x86)\hMailServer\Data\vms-tvd.net\vironda\68\{6859AB6C-875B-4FD1-A008-4D3634B34AE7}.eml"
Re: Error 554
Post by jimimaseye » 2017-11-21 15:21
Sounds like you may have ahad a disk full situation or a disk problem. Or you have been manually deleting message files out of the data directory.
In any case, it means that you have physical files missing.
I suggest you determine the cause for these missing files then clear up your database: viewtopic.php?f=20&t=27646
