- Senior user
Post
by katip » 2017-04-30 23:17
Hi SA gurus,
has anyone tried to store and read/check bayes in mySQL?
i created db and tables, imported current flat db, .cf entries are all ok, even sa-learn works, service startup is clean w/o error. however SA doesn't check bayes as if use_bayes is 0
IMO there must be something with
bayes_sql_override_username but don't have any idea what username this should be. SYSTEM, unknown, .spamassasin, systemprofile, <name of the service>... tried all but no avail. IOW, who is spamd in system?
or JAM version doesn't support this?? thanks for any clue.
- Senior user
Post
by SorenR » 2017-05-01 00:28
katip wrote:Hi SA gurus,
Frankly, there is no real incentive in having Bayes data in a DB, sure you can do stuff from Roundcube webmail but at the end of the day, hMailServer do not support differentiated user profiles - it all goes into the same user "unknown"
But just for the challenge... Hmm... Tomorrow
- Senior user
Post
by katip » 2017-05-01 16:21
katip wrote:however SA doesn't check bayes as if use_bayes is 0
weirdest things accompany my SA beginner endeavors. i started spamd service with -D hoping to find something useful. suddenly i saw that bayes has started to check
restarted without -D and it keeps checking!!
BTW, yes, sql user which spamd refers to is
"unknown"!
i'm thinking to post a HOW-TO about SA-bayes /w mySQL. keeping bayes in SQL may sound useless as HMS SA implementation is global. but i anticipate some speed, particularly with sa-learn. besides IMHO it's always a good idea to maintain a DB instead of a flat file when something is looked up in ten (even hundred) thousands of items. we'll see..
- Senior user
Post
by SorenR » 2017-05-01 16:52
It was pretty easy to get going... Even managed to import my "old" Bayes DB...
https://www.beris.nl/blog/2011/06/23/migrating-spamassassin-from-db-files-to-mysql/
## START ## Stuff that goes into local.cf
use_bayes 1 (Default: 1)
bayes_auto_learn 0 (Default: 1) ==> 0 since I use SA-LEARN exclusively
bayes_auto_expire 1 (Default: 1)
bayes_store_module Mail::SpamAssassin::BayesStore::MySQL
# MySQL driver, databasename = sa_bayes, Host = 127.0.0.1, Port = 3306
bayes_sql_dsn DBI:mysql:sa_bayes:127.0.0.1:3306
# YES, I have used this username and password ;-)
bayes_sql_username sa_user
bayes_sql_password sa_user_password
# Not sure what to think of this but hey, it's better than "unknown" ;-)
bayes_sql_override_username vscan
## END ##
# Get from CPAN...
.\lib\Mail\SpamAssassin\BayesStore\MySQL.pm
.\lib\Mail\SpamAssassin\BayesStore\SQL.pm
.\lib\Mail\SpamAssassin\Plugin\Bayes.pm
#Create MySQL tables (SA version 3.4.0).
CREATE TABLE bayes_expire (
id int(11) NOT NULL default '0',
runtime int(11) NOT NULL default '0',
KEY bayes_expire_idx1 (id)
) ENGINE=InnoDB;
CREATE TABLE bayes_global_vars (
variable varchar(30) NOT NULL default '',
value varchar(200) NOT NULL default '',
PRIMARY KEY (variable)
) ENGINE=InnoDB;
INSERT INTO bayes_global_vars VALUES ('VERSION','3');
CREATE TABLE bayes_seen (
msgid varchar(200) binary NOT NULL default '',
flag char(1) NOT NULL default '',
PRIMARY KEY (id,msgid)
) ENGINE=InnoDB;
CREATE TABLE bayes_token (
token binary(5) NOT NULL default '',
spam_count int(11) NOT NULL default '0',
ham_count int(11) NOT NULL default '0',
atime int(11) NOT NULL default '0',
PRIMARY KEY (id, token),
INDEX bayes_token_idx1 (id, atime)
) ENGINE=InnoDB;
CREATE TABLE bayes_vars (
id int(11) NOT NULL AUTO_INCREMENT,
username varchar(200) NOT NULL default '',
token_count int(11) NOT NULL default '0',
last_expire int(11) NOT NULL default '0',
last_atime_delta int(11) NOT NULL default '0',
last_expire_reduce int(11) NOT NULL default '0',
oldest_token_age int(11) NOT NULL default '2147483647',
newest_token_age int(11) NOT NULL default '0',
PRIMARY KEY (id),
UNIQUE bayes_vars_idx1 (username)
) ENGINE=InnoDB;
- Senior user
Post
by SorenR » 2017-05-01 17:18
Did the suggested test...
C:\SpamAssassin>wget http://spamassassin.apache.org/gtube/gtube.txt
--2017-05-01 17:08:46-- http://spamassassin.apache.org/gtube/gtube.txt
Resolving spamassassin.apache.org... 140.211.11.105, 88.198.26.2
Connecting to spamassassin.apache.org|140.211.11.105|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 799 [text/plain]
Saving to: `gtube.txt'
100%[======================================>] 799 --.-K/s in 0s
2017-05-01 17:08:46 (61.7 MB/s) - `gtube.txt' saved [799/799]
C:\SpamAssassin>sa-learn.exe -D --spam gtube.txt
maj 1 17:09:22.317 [3432] dbg: logger: adding facilities: all
maj 1 17:09:22.318 [3432] dbg: logger: logging level is DBG
maj 1 17:09:22.318 [3432] dbg: generic: SpamAssassin version 3.4.0
maj 1 17:09:22.318 [3432] dbg: generic: Perl 5.008009, PREFIX=., DEF_RULES_DIR=.\share\spamassassin, LOCAL_RULES_DIR=.\etc\spamassassin, LOCAL_STATE_DIR=C:\Perl\site/var/spamassassin
maj 1 17:09:22.318 [3432] dbg: config: timing enabled
maj 1 17:09:22.321 [3432] dbg: config: score set 0 chosen.
maj 1 17:09:22.327 [3432] dbg: util: running in taint mode? no
maj 1 17:09:22.327 [3432] dbg: util: defining getpwuid() wrapper using 'unknown' as username
maj 1 17:09:22.331 [3432] dbg: config: using ".\etc\spamassassin" for site rules pre files
maj 1 17:09:22.332 [3432] dbg: config: read file .\etc\spamassassin/init.pre
maj 1 17:09:22.332 [3432] dbg: config: read file .\etc\spamassassin/v310.pre
maj 1 17:09:22.333 [3432] dbg: config: read file .\etc\spamassassin/v312.pre
maj 1 17:09:22.333 [3432] dbg: config: read file .\etc\spamassassin/v320.pre
maj 1 17:09:22.334 [3432] dbg: config: read file .\etc\spamassassin/v330.pre
maj 1 17:09:22.334 [3432] dbg: config: read file .\etc\spamassassin/v340.pre
maj 1 17:09:22.334 [3432] dbg: config: using ".\share\spamassassin" for sys rules pre files
maj 1 17:09:22.335 [3432] dbg: config: using ".\share\spamassassin" for default rules dir
maj 1 17:09:22.335 [3432] dbg: config: using ".\etc\spamassassin" for site rules dir
maj 1 17:09:22.336 [3432] dbg: config: read file .\etc\spamassassin/ClamAV.cf
maj 1 17:09:22.338 [3432] dbg: config: read file .\etc\spamassassin/KAM.cf
maj 1 17:09:22.339 [3432] dbg: config: read file .\etc\spamassassin/botnet.cf
maj 1 17:09:22.339 [3432] dbg: config: read file .\etc\spamassassin/bwlist.cf
maj 1 17:09:22.340 [3432] dbg: config: read file .\etc\spamassassin/contact.cf
maj 1 17:09:22.340 [3432] dbg: config: read file .\etc\spamassassin/local.cf
maj 1 17:09:22.340 [3432] dbg: config: read file .\etc\spamassassin/rulestats.cf
maj 1 17:09:22.353 [3432] dbg: plugin: loading Mail::SpamAssassin::Plugin::URIDNSBL from @INC
maj 1 17:09:22.364 [3432] dbg: plugin: loading Mail::SpamAssassin::Plugin::Hashcash from @INC
maj 1 17:09:22.415 [3432] dbg: plugin: loading Mail::SpamAssassin::Plugin::SPFfrom @INC
maj 1 17:09:22.463 [3432] dbg: plugin: loading Mail::SpamAssassin::Plugin::Pyzor from @INC
maj 1 17:09:22.508 [3432] dbg: pyzor: network tests on, attempting Pyzor
maj 1 17:09:22.528 [3432] dbg: plugin: loading Mail::SpamAssassin::Plugin::Razor2 from @INC
maj 1 17:09:22.648 [3432] dbg: razor2: razor2 is available, version 2.84
maj 1 17:09:22.669 [3432] dbg: plugin: loading Mail::SpamAssassin::Plugin::SpamCop from @INC
maj 1 17:09:22.736 [3432] dbg: reporter: network tests on, attempting SpamCop
maj 1 17:09:22.756 [3432] dbg: plugin: loading Mail::SpamAssassin::Plugin::AutoLearnThreshold from @INC
maj 1 17:09:22.803 [3432] dbg: plugin: loading Mail::SpamAssassin::Plugin::WhiteListSubject from @INC
maj 1 17:09:22.833 [3432] dbg: plugin: loading Mail::SpamAssassin::Plugin::MIMEHeader from @INC
maj 1 17:09:22.876 [3432] dbg: plugin: loading Mail::SpamAssassin::Plugin::ReplaceTags from @INC
maj 1 17:09:22.920 [3432] dbg: plugin: loading Mail::SpamAssassin::Plugin::DKIM from @INC
maj 1 17:09:22.969 [3432] dbg: plugin: loading Mail::SpamAssassin::Plugin::Check from @INC
maj 1 17:09:23.026 [3432] dbg: plugin: loading Mail::SpamAssassin::Plugin::HTTPSMismatch from @INC
maj 1 17:09:23.072 [3432] dbg: plugin: loading Mail::SpamAssassin::Plugin::URIDetail from @INC
maj 1 17:09:23.121 [3432] dbg: plugin: loading Mail::SpamAssassin::Plugin::Bayes from @INC
maj 1 17:09:23.175 [3432] dbg: plugin: loading Mail::SpamAssassin::Plugin::BodyEval from @INC
maj 1 17:09:23.223 [3432] dbg: plugin: loading Mail::SpamAssassin::Plugin::DNSEval from @INC
maj 1 17:09:23.267 [3432] dbg: plugin: loading Mail::SpamAssassin::Plugin::HTMLEval from @INC
maj 1 17:09:23.311 [3432] dbg: plugin: loading Mail::SpamAssassin::Plugin::HeaderEval from @INC
maj 1 17:09:23.364 [3432] dbg: plugin: loading Mail::SpamAssassin::Plugin::MIMEEval from @INC
maj 1 17:09:23.415 [3432] dbg: plugin: loading Mail::SpamAssassin::Plugin::RelayEval from @INC
maj 1 17:09:23.459 [3432] dbg: plugin: loading Mail::SpamAssassin::Plugin::URIEval from @INC
maj 1 17:09:23.501 [3432] dbg: plugin: loading Mail::SpamAssassin::Plugin::WLBLEval from @INC
maj 1 17:09:23.551 [3432] dbg: plugin: loading Mail::SpamAssassin::Plugin::VBounce from @INC
maj 1 17:09:23.594 [3432] dbg: plugin: loading Mail::SpamAssassin::Plugin::ImageInfo from @INC
maj 1 17:09:23.643 [3432] dbg: plugin: loading Mail::SpamAssassin::Plugin::FreeMail from @INC
maj 1 17:09:23.690 [3432] dbg: plugin: loading Mail::SpamAssassin::Plugin::AskDNS from @INC
maj 1 17:09:23.736 [3432] dbg: config: fixed relative path: .\etc\spamassassin/clamav.pm
maj 1 17:09:23.777 [3432] dbg: plugin: loading ClamAV from C:\SpamAssassin\etc\spamassassin\clamav.pm
maj 1 17:09:24.114 [3432] dbg: plugin: loading Mail::SpamAssassin::Plugin::Botnet from @INC
maj 1 17:09:24.162 [3432] dbg: Botnet: version 0.9
maj 1 17:09:24.183 [3432] dbg: plugin: Mail::SpamAssassin::Plugin::FreeMail=HASH(0x3162af4) implements 'parse_config', priority 0
maj 1 17:09:24.225 [3432] dbg: plugin: Mail::SpamAssassin::Plugin::Botnet=HASH(0x326aec4) implements 'parse_config', priority 0
maj 1 17:09:24.267 [3432] dbg: Botnet: setting botnet_pass_auth to 0
maj 1 17:09:24.288 [3432] dbg: Botnet: setting botnet_pass_trusted to public
maj 1 17:09:24.309 [3432] dbg: Botnet: adding ^127\.0\.0\.1$ to botnet_skip_ip
maj 1 17:09:24.330 [3432] dbg: Botnet: adding ^10\..*$ to botnet_skip_ip
maj 1 17:09:24.351 [3432] dbg: Botnet: adding ^172\.1[6789]\..*$ to botnet_skip_ip
maj 1 17:09:24.391 [3432] dbg: Botnet: adding ^172\.2[0-9]\..*$ to botnet_skip_ip
maj 1 17:09:24.432 [3432] dbg: Botnet: adding ^172\.3[01]\..*$ to botnet_skip_ip
maj 1 17:09:24.472 [3432] dbg: Botnet: adding ^192\.168\..*$ to botnet_skip_ip
maj 1 17:09:24.493 [3432] dbg: Botnet: adding ^128\.223\.98\.16$ to botnet_pass_ip
maj 1 17:09:24.533 [3432] dbg: Botnet: adding (\.|\A)amazon\.com$ to botnet_pass_domains
maj 1 17:09:24.575 [3432] dbg: Botnet: adding (\.|\A)apple\.com$ to botnet_pass_domains
maj 1 17:09:24.614 [3432] dbg: Botnet: adding (\.|\A)ebay\.com$ to botnet_pass_domains
maj 1 17:09:24.656 [3432] dbg: Botnet: adding (\b|\d).*dsl.*(\b|\d) to botnet_clientwords
maj 1 17:09:24.697 [3432] dbg: Botnet: adding (\b|\d)cable(\b|\d) to botnet_clientwords
maj 1 17:09:24.738 [3432] dbg: Botnet: adding (\b|\d)catv(\b|\d) to botnet_clientwords
maj 1 17:09:24.780 [3432] dbg: Botnet: adding (\b|\d)ddns(\b|\d) to botnet_clientwords
maj 1 17:09:24.820 [3432] dbg: Botnet: adding (\b|\d)dhcp(\b|\d) to botnet_clientwords
maj 1 17:09:24.861 [3432] dbg: Botnet: adding (\b|\d)dial(-?up)?(\b|\d) to botnet_clientwords
maj 1 17:09:24.903 [3432] dbg: Botnet: adding (\b|\d)dip(\b|\d) to botnet_clientwords
maj 1 17:09:24.944 [3432] dbg: Botnet: adding (\b|\d)docsis(\b|\d) to botnet_clientwords
maj 1 17:09:24.985 [3432] dbg: Botnet: adding (\b|\d)dyn(amic)?(ip)?(\b|\d) tobotnet_clientwords
maj 1 17:09:25.025 [3432] dbg: Botnet: adding (\b|\d)modem(\b|\d) to botnet_clientwords
maj 1 17:09:25.067 [3432] dbg: Botnet: adding (\b|\d)ppp(oe)?(\b|\d) to botnet_clientwords
maj 1 17:09:25.108 [3432] dbg: Botnet: adding (\b|\d)res(net|ident(ial)?)?(\b|\d) to botnet_clientwords
maj 1 17:09:25.146 [3432] dbg: Botnet: adding (\b|\d)bredband(\b|\d) to botnet_clientwords
maj 1 17:09:25.187 [3432] dbg: Botnet: adding (\b|\d)client(\b|\d) to botnet_clientwords
maj 1 17:09:25.229 [3432] dbg: Botnet: adding (\b|\d)fixed(\b|\d) to botnet_clientwords
maj 1 17:09:25.270 [3432] dbg: Botnet: adding (\b|\d)ip(\b|\d) to botnet_clientwords
maj 1 17:09:25.312 [3432] dbg: Botnet: adding (\b|\d)pool(\b|\d) to botnet_clientwords
maj 1 17:09:25.353 [3432] dbg: Botnet: adding (\b|\d)static(\b|\d) to botnet_clientwords
maj 1 17:09:25.394 [3432] dbg: Botnet: adding (\b|\d)user(\b|\d) to botnet_clientwords
maj 1 17:09:25.436 [3432] dbg: Botnet: adding (\b|\d)e?mail(out)?(\b|\d) to botnet_serverwords
maj 1 17:09:25.477 [3432] dbg: Botnet: adding (\b|\d)mta(\b|\d) to botnet_serverwords
maj 1 17:09:25.518 [3432] dbg: Botnet: adding (\b|\d)mx(pool)?(\b|\d) to botnet_serverwords
maj 1 17:09:25.560 [3432] dbg: Botnet: adding (\b|\d)relay(\b|\d) to botnet_serverwords
maj 1 17:09:25.602 [3432] dbg: Botnet: adding (\b|\d)smtp(\b|\d) to botnet_serverwords
maj 1 17:09:25.643 [3432] dbg: Botnet: adding (\b|\d)exch(ange)?(\b|\d) to botnet_serverwords
maj 1 17:09:25.692 [3432] dbg: plugin: loading Mail::SpamAssassin::Plugin::Rulestats from @INC
maj 1 17:09:25.767 [3432] dbg: config: warning: no description set for KAM_RPTR_SUSPECT
maj 1 17:09:25.809 [3432] dbg: config: warning: no description set for KAM_RAPTOR
maj 1 17:09:25.852 [3432] dbg: config: warning: no description set for CBJ_GiveMeABreak
maj 1 17:09:25.893 [3432] dbg: config: warning: no description set for KAM_BADPDF2
maj 1 17:09:25.934 [3432] dbg: config: warning: no description set for KAM_RPTR_FAILED
maj 1 17:09:25.977 [3432] dbg: config: warning: no description set for KAM_RPTR_PASSED
maj 1 17:09:26.019 [3432] dbg: config: warning: no description set for KAM_IFRAME
maj 1 17:09:26.255 [3432] dbg: rules: CBJ_GiveMeABreak merged duplicates: KAM_IFRAME KAM_RAPTOR KAM_RPTR_FAILED KAM_RPTR_PASSED KAM_RPTR_SUSPECT
maj 1 17:09:26.297 [3432] dbg: config: finish parsing
maj 1 17:09:26.330 [3432] dbg: plugin: Mail::SpamAssassin::Plugin::ReplaceTags=HASH(0x2e11278) implements 'finish_parsing_end', priority 0
maj 1 17:09:26.370 [3432] dbg: plugin: Mail::SpamAssassin::Plugin::FreeMail=HASH(0x3162af4) implements 'finish_parsing_end', priority 0
maj 1 17:09:26.412 [3432] dbg: replacetags: replacing tags
maj 1 17:09:26.437 [3432] dbg: replacetags: done replacing tags
maj 1 17:09:26.458 [3432] dbg: FreeMail: no freemail_domains entries defined, disabling plugin
maj 1 17:09:26.500 [3432] dbg: plugin: Mail::SpamAssassin::Plugin::Bayes=HASH(0x2f248f8) implements 'learner_new', priority 0
maj 1 17:09:26.542 [3432] dbg: bayes: learner_new self=Mail::SpamAssassin::Plugin::Bayes=HASH(0x2f248f8), bayes_store_module=Mail::SpamAssassin::BayesStore::MySQL
maj 1 17:09:26.624 [3432] dbg: bayes: using username: vscan
maj 1 17:09:26.644 [3432] dbg: bayes: learner_new: got store=Mail::SpamAssassin::BayesStore::MySQL=HASH(0x2958934)
maj 1 17:09:26.686 [3432] dbg: plugin: Mail::SpamAssassin::Plugin::Bayes=HASH(0x2f248f8) implements 'learner_is_scan_available', priority 0
maj 1 17:09:26.754 [3432] dbg: bayes: database connection established
maj 1 17:09:26.771 [3432] dbg: bayes: found bayes db version 3
maj 1 17:09:26.791 [3432] dbg: bayes: Using userid: 2
maj 1 17:09:26.814 [3432] dbg: config: score set 3 chosen.
maj 1 17:09:26.834 [3432] dbg: dns: socket module for IPv6 support not available
maj 1 17:09:26.875 [3432] dbg: dns: EDNS, UDP payload size 4096
maj 1 17:09:26.897 [3432] dbg: dns: servers obtained from Net::DNS : [192.168.0.50]:53
maj 1 17:09:26.938 [3432] dbg: dns: nameservers set to 192.168.0.50
maj 1 17:09:26.960 [3432] dbg: dns: using socket module: IO::Socket::INET, forced IPv4
maj 1 17:09:27.000 [3432] dbg: dns: is Net::DNS::Resolver available? yes
maj 1 17:09:27.022 [3432] dbg: dns: Net::DNS version: 0.66
maj 1 17:09:27.043 [3432] dbg: sa-learn: spamtest initialized
maj 1 17:09:27.065 [3432] dbg: learn: initializing learner
maj 1 17:09:27.088 [3432] dbg: plugin: Mail::SpamAssassin::Plugin::Bayes=HASH(0x2f248f8) implements 'learner_sync', priority 0
maj 1 17:09:27.130 [3432] dbg: bayes: bayes journal sync starting
maj 1 17:09:27.152 [3432] dbg: bayes: bayes journal sync completed
maj 1 17:09:27.172 [3432] dbg: plugin: Mail::SpamAssassin::Plugin::Bayes=HASH(0x2f248f8) implements 'learner_expire_old_training', priority 0
maj 1 17:09:27.215 [3432] dbg: bayes: expiry starting
maj 1 17:09:27.238 [3432] dbg: bayes: expiry completed
maj 1 17:09:27.260 [3432] dbg: archive-iterator: _set_default_message_selection_opts After: Scanprob[1], want_date[0], cache[0], from_regex[^From \S+ ?(\S\S\S\S\S\S .\d .\d:\d\d:\d\d \d{4}|.\d-\d\d-\d{4}_\d\d:\d\d:\d\d_)]
maj 1 17:09:27.333 [3432] dbg: config: time limit 120.0 s
maj 1 17:09:27.355 [3432] dbg: message: main message type: text/plain
maj 1 17:09:27.377 [3432] dbg: learn: learning spam
maj 1 17:09:27.398 [3432] dbg: plugin: Mail::SpamAssassin::Plugin::Bayes=HASH(0x2f248f8) implements 'learn_message', priority 0
maj 1 17:09:27.439 [3432] dbg: check: pms new, time limit in 119.894 s
maj 1 17:09:27.461 [3432] dbg: metadata: X-Spam-Relays-Trusted:
maj 1 17:09:27.481 [3432] dbg: metadata: X-Spam-Relays-Untrusted:
maj 1 17:09:27.503 [3432] dbg: metadata: X-Spam-Relays-Internal:
maj 1 17:09:27.523 [3432] dbg: metadata: X-Spam-Relays-External:
maj 1 17:09:27.543 [3432] dbg: plugin: Mail::SpamAssassin::Plugin::AskDNS=HASH(0x3162ef0) implements 'extract_metadata', priority 0
maj 1 17:09:27.585 [3432] dbg: dns: clear_resolver
maj 1 17:09:27.606 [3432] dbg: dns: socket module for IPv6 support not available
maj 1 17:09:27.648 [3432] dbg: dns: EDNS, UDP payload size 4096
maj 1 17:09:27.668 [3432] dbg: dns: nameservers set to 192.168.0.50
maj 1 17:09:27.690 [3432] dbg: dns: using socket module: IO::Socket::INET, forced IPv4
maj 1 17:09:27.731 [3432] dbg: dns: is Net::DNS::Resolver available? yes
maj 1 17:09:27.752 [3432] dbg: dns: Net::DNS version: 0.66
maj 1 17:09:27.774 [3432] dbg: dns: dns_available set to yes in config file, skipping test
maj 1 17:09:27.814 [3432] dbg: check: tagrun - action 0 blocking on tags SENDERDOMAIN
maj 1 17:09:27.849 [3432] dbg: message: ---- MIME PARSER START ----
maj 1 17:09:27.870 [3432] dbg: message: parsing normal part
maj 1 17:09:27.891 [3432] dbg: message: storing a body to memory
maj 1 17:09:27.912 [3432] dbg: message: ---- MIME PARSER END ----
maj 1 17:09:27.934 [3432] dbg: message: decoding other encoding type (7bit), ignoring
maj 1 17:09:27.976 [3432] dbg: check: tagrun - tag SENDERDOMAIN is still blocking action 0
maj 1 17:09:28.039 [3432] dbg: bayes: seen (31dcbefd2524b07c65d551d282ce77902f3804c7@sa_generated) put
maj 1 17:09:28.081 [3432] dbg: bayes: learned '31dcbefd2524b07c65d551d282ce77902f3804c7@sa_generated', atime: 1058995800
Learned tokens from 1 message(s) (1 message(s) examined)
maj 1 17:09:28.144 [3432] dbg: plugin: Mail::SpamAssassin::Plugin::Bayes=HASH(0x2f248f8) implements 'learner_close', priority 0
C:\SpamAssassin>
- Senior user
Post
by katip » 2017-05-01 17:59
well done!
for me, "unknown" is good, indeed it's unknown
now i'm going to change our production setup. if all goes well also there, i'll post a HOW-TO.
happy Workers' Day btw...
