Severity: 3 (Medium), Code: HM4403, Source: Message
bfsistemi
Post by bfsistemi » 2015-04-23 22:19
hi everybody
hmailserver latest release and external mysql.
1 domain
30 accounts
imap
It's works good for two years
After move it in a new server I have in the log many errors like this:
"ERROR" 5160 "2015-04-23 21:54:32.001" "Severity: 3 (Medium), Code: HM4403, Source: Message::GetHeader, Description: Could not read the message header, since the file was not available. File: C:\Program Files\hMailServer\Data\pp.com\xxxxxxxx\"
"ERROR" 7512 "2015-04-23 21:54:34.982" "Severity: 3 (Medium), Code: HM5136, Source: TCPConnection::AsyncReadCompleted, Description: An error occured while parsing data. Data length: 54, Data: 25 UID fetch 52246,52279 (UID RFC822.SIZE BODY.PEEK[]). Remote IP: 192.168.1.199"
"ERROR" 7512 "2015-04-23 21:54:34.984" "Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'IOCPQueueWorkerTask'"
"ERROR" 7512 "2015-04-23 21:54:36.184" "Severity: 1 (Critical), Code: HM5519, Source: StackLogger::Log, Description: An error has been detected. A mini dump has been written to C:\Program Files\hMailServer\Logs\minidump_2015-04-23 215434_{1B126DC2-9EB1-49C6-8B4E-7A727EC8F7BC}.dmp"
"ERROR" 3416 "2015-04-23 21:54:36.988" "Severity: 3 (Medium), Code: HM4403, Source: Message::GetHeader, Description: Could not read the message header, since the file was not available. File: C:\Program Files\hMailServer\Data\pp.com\xxxxxxxx\"
"ERROR" 7708 "2015-04-23 21:54:39.622" "Severity: 1 (Critical), Code: HM5519, Source: StackLogger::Log, Description: An error has been detected. A mini dump has been written to C:\Program Files\hMailServer\Logs\minidump_2015-04-23 215439_{9EE473A5-3FFD-4ED4-867A-DB49D5F88682}.dmp"
"ERROR" 2800 "2015-04-23 21:55:05.123" "Severity: 3 (Medium), Code: HM5136, Source: TCPConnection::AsyncReadCompleted, Description: An error occured while parsing data. Data length: 818, Data: iunc UID FETCH 30:104,106:137,139:247,249:257,259:277,279:283,288:296,298:317,319:375,377:420,424:428,430:4821,4823:12585,12587:12613,12615:12619,12621:12633,12635:12664,12666:13072,13074:13932,13935:16221,16223:17994,17996:18313,18315:18344,18346:18352,18355:18471,18473:18693,18695:18858,18860:18889,18891:18898,18903:19040,19048:19095,19097,19099:19101,19103:19107,19110:19111,19113:19114,19118:19119,19121:19123,19125:19127,19131,19134:19136,19139,19141:19143,19145,19151:19152,19154:19159,19161,19163:19165,19171:19177,19179:19180,19182:19190,19194:19196,19200,19203:19204,19206:19207,19210:19212,19214:19216,19218:19227,19229:19237,19242,19244,19246:19253,19255:19261,19269,19271:19275,19280,19286,19290,19292,19294:19304,19307:19308,19315,19322:19330,19334,19336 (UID FLAGS RFC822.SIZE BODY.PEEK[]
INTERNALDATE).
if I use outlook 2013 like mail clients (imap) hundreds of emails are duplicated automatically...very old mail will be resent...big problems.
if I use Thunderibird thousands of email users are formed in folders. Mail from "post mastere can delivery the mail"
if I use a webmail (roundcube) no problem
can you help me?
thnx
bfsistemi
Re: Severity: 3 (Medium), Code: HM4403, Source: Message
Post by bfsistemi » 2015-04-23 22:48
this is my diagnostic
Test: Collect server details
hMailServer version: hMailServer 5.6.3-B2249
Database type: MySQL
Test: Test IPv6
Test: Test outbound port
SMTP relayer is in use.
Trying to connect to host relay3.ascotlc.it...
Trying to connect to TCP/IP address 80.86.144.243 on port 25.
Received: 220 relay3.ascotlc.it ESMTP Postfix (Ubuntu).
Connected successfully.
Test: Test backup directory
ERROR: Backup directory C:\Users\mail\Desktop\cfg is not writable.
Test: Test MX records
Trying to resolve MX records for pp.com...
Host name found: pp.com
Test: Test local connect
Connecting to TCP/IP address in MX records for local domain domain pp.com...
Trying to connect to host pp.com...
Trying to connect to TCP/IP address 108.175.149.76 on port 25.
Received: 220-trout.arvixe.com ESMTP Exim 4.82 #2 Thu, 23 Apr 2015 13:42:59 -0700 .
ERROR: Messages exists which are located outside of the data directory C:\Program Files\hMailServer\Data.
Post by jimimaseye » 2015-04-23 23:04
Post by mattg » 2015-04-23 23:46
bfsistemi wrote:Test: Test message file locations
The new data store is in a different location than the original.
bfsistemi wrote:After move it in a new server
How did you do this?
bfsistemi
Post by bfsistemi » 2015-04-24 06:12
thanks for your reply
The new data store is the same!
c:\programi files\hmailserver\data.
the only difference is that before I work with w7 32bit and now with 64bit.
I replace pc for more performance and more disk space.
It's normal that in the new pc the mail are stored in the mysql without "C:\Program Files\hMailServer\Data"?
Must i remove with a sql update that from old mail?
tnx.
fabio
bfsistemi
Post by bfsistemi » 2015-04-24 06:16
jimimaseye wrote:viewtopic.php?t=27414
Have a read.
I read now, sorry but I dont understund the solution. (my english is not good)
I remove antivirus and problem is not solved.
How can resolve the memory problem?
tnx!
Post by mattg » 2015-04-24 06:22
bfsistemi wrote:It's normal that in the new pc the mail are stored in the mysql without "C:\Program Files\hMailServer\Data"?
depends
what does your hMailserver.ini say?
Also, default install for hMailserver on a 64 bit system (in English) is
C:/Program Files (x86)/hmailserver/
bfsistemi
Post by bfsistemi » 2015-04-24 06:32
depends
hi...tnx for reply. this:
ProgramFolder=C:\Program Files\hMailServer
DatabaseFolder=
DataFolder=C:\Program Files\hMailServer\Data
LogFolder=C:\Program Files\hMailServer\Logs
TempFolder=C:\Program Files\hMailServer\Temp
EventFolder=C:\Program Files\hMailServer\Events
[GUILanguages]
Type=MYSQL
Username=root
Password=
Port=3306
Server=localhost
Database=mysql55
Internal=0
[Security]
AdministratorPassword=
bfsistemi
Post by bfsistemi » 2015-04-24 06:46
bfsistemi wrote: How did you do this?
dump mysql
install hmail server same version in the new machine
copy data folder
restore ini file
restore mysql
(https://www.hmailserver.com/documentati ... _newserver)
all works perferctly with webmail (roundmail)
the problems are when I use outlook or thunderbird.
In some clients with outlook, the inbox duplicate (many many copies) the mails
In some cleints when I start thunderbird, start a creation of houndred mail of 1kb like this:
Subject: Message undeliverable
Date: date e time is in real time
The mail server could not deliver the message to you since the file C:\Program Files\hMailServer\Data\pp.com\username\F4\{F4ADE149-7794-4767-8EAC-099DD538317E}.eml does not exist on the server.
The file may have been deleted by anti virus software running on the server.
hMailServer
So inbox of thunderbird is full of this messages after the normal mail.
I must close TB for stop the loop of generation
I not have antivirus.
can you help me?
Post by mattg » 2015-04-24 08:29
bfsistemi wrote:all works perferctly with webmail (roundmail)
That doesn't make sense.
Is the file that thunderbird reports missing, is it in the data folder or not?
bfsistemi
Post by bfsistemi » 2015-04-24 08:59
I try to explane..
I open thunderbird...
thunderbird start generate houndred of mile like this:
C:\Program Files\hMailServer\Data\pp.com\....\FA\{FA250899-0DFA-4F7E-84E4-98E622799ED0}
the content of this mail is:
Date: Thu, 23 Apr 2015 20:20:48 +0200
The mail server could not deliver the message to you since the file C:\Program Files\hMailServer\Data\pp.com\....\FA\{FA250899-0DFA-4F7E-84E4-98E622799ED0}.eml does not exist on the server.
hMailServer
look that the name of eml is the same!
"{FA250899-0DFA-4F7E-84E4-98E622799ED0}.eml does not exist on the server." not have sense...it's the name of file that said that not exist!
bfsistemi
Post by bfsistemi » 2015-04-24 09:05
http://it.tinypic.com/r/2r2vj8g/8
the file that says to miss is the file itself
bfsistemi
Post by bfsistemi » 2015-04-24 09:17
incredible the numbers of error now:
please help me
"ERROR" 8080 "2015-04-24 06:06:22.774" "Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run
"ERROR" 2312 "2015-04-24 06:06:27.251" "Severity: 3 (Medium), Code: HM5136, Source: TCPConnection::AsyncReadCompleted,
"ERROR" 7548 "2015-04-24 06:06:50.277" "Severity: 3 (Medium), Code: HM5136, Source: TCPConnection::AsyncReadCompleted, Description: An error
"ERROR" 760 "2015-04-24 06:07:06.470" "Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::
"ERROR" 760 "2015-04-24 06:07:06.798" "Severity: 1 (Critical), Code: HM5519, Source: StackLogger
"ERROR" 5000 "2015-04-24 06:17:31.056" "Severity: 3 (Medium), Code: HM5136, Source: TCPConnection::
"ERROR" 4004 "2015-04-24 06:17:37.406" "Severity: 2 (High), Code: HM4208, Source: ExceptionHandler:
"ERROR" 7372 "2015-04-24 06:46:49.930" "Severity: 2 (High), Code: HM5032, Source: DALConnection::Execute,
"ERROR" 4668 "2015-04-24 08:05:03.692" "Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run,
"ERROR" 4668 "2015-04-24 08:05:03.848" "Severity: 1 (Critical), Code: HM5519, Source: StackLogger::Log,
"ERROR" 8040 "2015-04-24 08:05:27.701" "Severity: 3 (Medium), Code: HM5136, Source: TCPConnection::A
"ERROR" 7120 "2015-04-24 08:05:59.415" "Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'IOCPQueueWorkerTask'"
"ERROR" 5372 "2015-04-24 08:11:24.396" "Severity: 3 (Medium), Code: HM5136, Source: TCPConnection::AsyncReadCompleted, Description: An error occured while parsing data. Data length: 818, Data: 6tpe UID FETCH 30:104,106:137,139:247,249:257,259:277,279:283,288:296,2
and many many many other
Post by jimimaseye » 2015-04-24 10:13
Poster:
there are 2 things that stand out to me:
1, in italian I know that the italian OS have the program files as PROGRAMMI or PROGRAMMI (x86) and yet you are referring to your installation being in PROGRAM FILES (english version). Are you running on english version OS?
2, as matt says the install of Hmailserver will always put its setup in the X86 version of the program files, and yet you are quoting it being in the x64. I also have the install on a 64bit Server and I confirm this is the case.
Now earlier in your post you referred to
bfsistemi wrote:The new data store is the same!
which simply doesnt fit with anything. So was it a typing error? Given your old server was 32bit only perhaps it didnt have 2 versions of the program directory (hence its quoted as 'program files' which causes the crossover to a 64bit platform a problem)
So, I suspect there is some error in your migration. I would do the migration again.
Did you install the SAME version of HMS on to the new server as you had on the old one? (You SHOULD have!)
MySQL DUMP your old SQL database to file.
Install HMS on the new server again. Do NOT copy the old INI file.
Copy the data folder structure from old server to new server but place it in the structure as the NEW hmailserver.ini file is pointing to.
Restore MYSQL database from the dump file
Post by mattg » 2015-04-24 10:14
Yes, if hMailserver expects that file and it isn't there, that message will be created by hMailserver.
Post by mattg » 2015-04-24 10:17
If you are still having issues after doing what jimimaseye says then....
jimimaseye wrote:restore MYSQL database from the dump file
PM this MySQL dump file to me so that I can see it please...
bfsistemi
Post by bfsistemi » 2015-04-24 10:30
jimimaseye wrote:Poster:
tnx for reply
1)my os is in italian
if the path of the email is not correct, you will not see any email. Instead I see perfectly all the mails on both windows live email, both of webmail.
I have problems with thunderbird starts to generate emails from 1k (but i see all the old mail), while outlook duplicates, triplicates etc inbox. Does not make sense. Receiving and sending webmail from work. Receiving and sending email from Windows Live works
2)the path is c:\program files\hmailserver\data in old and new pc
if the path of the file eml was wrong not see any mail ... right?
look this
http://www.hosting.universalsite.org/im ... 3A020D.jpg
this mail i read without problems in webmail/outlook/tb etc.
if the path to the folder date was wrong not display in any program.
tnx
Post by jimimaseye » 2015-04-24 10:48
doesnt outlook store the emails in a local PST folder (which would go towards explaining duplication)? and did you simply point the old outlook clients to the new server? And have you checked the thunderbird server configuration?
Anyway, I stand by my suggestion. There are inconsistencies not least of you having these errors. My advice is to reinstall, with the procedure outlined in order to conform to the default file and folder locations - and I suspect this will solve your problems. It shouldnt take you longer than a few minutes as you already have the hmail data folder on the disk which you can simply copyout and place to the new location.
bfsistemi
Post by bfsistemi » 2015-04-24 11:06
jimimaseye wrote:doesnt outlook store the emails in a local PST folder (which would go towards explaining duplication)? and did you simply point the old outlook clients to the new server? And have you checked the thunderbird server configuration?
in outlook i tryed remove pst
in thunderbird setup is ok
to remove any doubt, I can move the folder data in "c:\data" and then with an "update replace" in mysql db trasform
from c:\program files\hmail server\data to c:\data\
and edit the file hmailserver.ini?
but this explains all the errors of memory that I posted?
bfsistemi
Post by bfsistemi » 2015-04-24 11:28
there is a way to verify that the mysql database is updated for the corresponding version of hmailserver?
tnx
Post by mattg » 2015-04-24 11:44
There is a table called 'hm_dbversion' with a single value.
This gets updated with each update.
bfsistemi
Post by bfsistemi » 2015-04-24 13:51
mattg wrote:There is a table called 'hm_dbversion' with a single value.
tnx for your reply and for your time
in hmailserver I see
version: 5.6.3-B2249
Database version:5601
in mysql:
select * from hm_dbversion result: 5601
It's ok?
tnx
bfsistemi
Post by bfsistemi » 2015-04-24 13:56
mattg wrote:If you are still having issues after doing what jimimaseye says then....
are 55MB zipped.
can I pass you with wetransfer?
or I can put it in a ftp zone
tnx a lot
fabio
Post by mattg » 2015-04-24 23:32
send me the ftp link via PM is fine
bfsistemi
Post by bfsistemi » 2015-04-25 13:12
mattg wrote:send me the ftp link via PM is fine
thankyou very much for your support!
tomorrow I upload the file and I will send you the link in PM
tnx
Fabio
Post by martin » 2015-04-25 13:21
Also can you send me the files named C:\Program Files\hMailServer\Logs\minidump at martin@hmailserver.com, so that i can have a look at them to see what triggered the error?
Martin
Martin Knafve
https://twitter.com/knafve
bfsistemi
Post by bfsistemi » 2015-04-26 09:30
I send you a pm with the links for database and errors zip
thanks
bfsistemi
Post by bfsistemi » 2015-04-26 09:33
martin wrote:Also can you send me the files named C:\Program Files\hMailServer\Logs\minidump at martin@hmailserver.com, so that i can have a look at them to see what triggered the error?
Martin
i send you all my errors in log folders
thankyou very much
bye
Fabio
bfsistemi
Post by bfsistemi » 2015-04-27 15:25
hi Matt
any suggestions?
tnx
Post by mattg » 2015-04-28 07:31
What tool do you use to 'manage' your database?
I use PHPMyAdmin and find it excellent.
If you load the hm_messages table and sort alphabetically, do you notice a heap of files without the data directory shown at the front.
These are files that have been saved since upgrade to 5.4.
If you can script, you can write a query that will remove the stored path for all messages (There are some examples on this forum)
Was the first computer set to language of English or Italian?
I suspect that the 'program files' vs 'programi files' is part of the issue
bfsistemi
Post by bfsistemi » 2015-04-28 08:42
mattg wrote:What tool do you use to 'manage' your database?
hi!
I use mysql workbench.
Yes, I update from 5.4 at latest release. and I noticed that after upgrading the messages are not the full path
Both PC was Italian
'programi files' was a typo (errror of tipyng in the post)
in both pc the path was "program files"
so you suggest an update query to remove the path of the file to all the mails?
this is ok? UPDATE hm_messages SET messagefilename=REPLACE(messagefilename, messagefilename, right(messagefilename,42));
tnx for your support
bye
Post by jimimaseye » 2015-04-28 08:49
That looks like the correct statement yes. Be sure to take a backup first. After wards you should also run the dds to ensure everything is included.
Post by jimimaseye » 2015-04-28 09:00
And don't forget you will need to copy the data files back in from your backup before running the dds. Because otherwise you will now have all the 'file not found' place holder emails replacing the genuine original emails.
run the SQL update commend.
copy over your .EML files again from your old server/backup overwriting existing files but keeping what is already there (new)
Run DDS. (this will ensure all inbound files that are now in the data directory will have been included)
then run this: viewtopic.php?f=20&t=27646 (this ensures your database doesnt refer to files that no longer exist)
