Post new topic Reply to topic  [ 6 posts ]
Author Message
 Post subject: 550.5.7.1 Unable to relay
PostPosted: 2011-07-13 07:15
Hi everyone,
I am using hMailServer 5.3.3-B1879
I am using VPS, windows 2008
port 25 is open
I've tried it using telnet to hmailserver 25, it gave this result :
Quote:
220 mail.hmailserver.com ESMTP
HELO
501 HELO Invalid domain address.
Diagnostic show result like this :
Quote:
Test: Collect server details
hMailServer version: hMailServer 5.3.3-B1879
Database type: MySQL
Test: Test IPv6
Test: Test outbound port
Trying to connect to TCP/IP address 83.169.11.240 on port 25.
Connected successfully.
Test: Test MX records
Trying to resolve MX records for hsn.co.id...
Host name found: mail.hsn.co.id
Test: Test local connect
Connecting to TCP/IP address in MX records for local domain domain hsn.co.id...
Trying to connect to host mail.hsn.co.id...
Trying to connect to TCP/IP address 117.102.250.55 on port 25.
Then, I tried to send and receive some email.
It work fine when receive email from internal and external server like Yahoo & Google
It also work when sending message to Yahoo, not not likely with Google.
It said :
Quote:
Sent: Wed, 13 Jul 2011 10:34:59 +0700
Subject: Re: email from gmail (1st)
xxx@gmail.com
Error Type: SMTP
Remote server (117.102.248.7) issued an error.
hMailServer sent: RCPT TO:<xxx@gmail.com>
Remote server replied: 550 5.7.1 Unable to relay
Can anyone help me?
Thanks in advance.
Agie
Top
 Profile
 Post subject: Re: 550.5.7.1 Unable to relay
PostPosted: 2011-07-13 10:13
Have you put anything in your SMTP relay section or do you have any routes setup?
_________________
Top
 Profile
PostPosted: 2011-07-13 10:29
No, DooM.
I put nothing on SMTP relay. Here are my setting
Top
 Profile
PostPosted: 2011-07-13 12:03
And the second part i asked?
_________________
Top
 Profile
PostPosted: 2011-07-13 12:15
Ah, yes.... I'm sorry.
No, I dont have any routes setup.
Plus these are some part from the logging file.
Quote:
"SMTPC" 2812 7994 "2011-07-13 14:57:51.615" "117.102.248.7" "RECEIVED: 220 mx.push.mobi Microsoft ESMTP MAIL Service ready at Wed, 13 Jul 2011 14:57:55 +0700"
"SMTPC" 2812 7994 "2011-07-13 14:57:51.616" "117.102.248.7" "SENT: HELO mail.hsn.co.id"
"SMTPC" 3592 7994 "2011-07-13 14:57:51.619" "117.102.248.7" "RECEIVED: 250 mx.push.mobi Hello [117.102.250.55]"
"SMTPC" 3592 7994 "2011-07-13 14:57:51.619" "117.102.248.7" "SENT: MAIL FROM:<xxx@hsn.co.id>"
"SMTPC" 3104 7994 "2011-07-13 14:57:51.624" "117.102.248.7" "RECEIVED: 250 2.1.0 Sender OK"
"SMTPC" 3104 7994 "2011-07-13 14:57:51.625" "117.102.248.7" "SENT: RCPT TO:<xxx@gmail.com>"
"SMTPC" 2812 7994 "2011-07-13 14:57:56.661" "117.102.248.7" "RECEIVED: 550 5.7.1 Unable to relay"
"SMTPC" 2812 7994 "2011-07-13 14:57:56.661" "117.102.248.7" "SENT: QUIT"
"SMTPC" 3592 7994 "2011-07-13 14:57:56.665" "117.102.248.7" "RECEIVED: 221 2.0.0 Service closing transmission channel"
"SMTPC" 2732 7995 "2011-07-13 14:58:53.945" "77.238.177.9" "RECEIVED: 220 mta1016.mail.ird.yahoo.com ESMTP YSmtp service ready"
"SMTPC" 2732 7995 "2011-07-13 14:58:53.945" "77.238.177.9" "SENT: HELO mail.hsn.co.id"
"SMTPC" 2812 7995 "2011-07-13 14:58:54.249" "77.238.177.9" "RECEIVED: 250 mta1016.mail.ird.yahoo.com"
"SMTPC" 2812 7995 "2011-07-13 14:58:54.249" "77.238.177.9" "SENT: MAIL FROM:<>"
"SMTPC" 3304 7995 "2011-07-13 14:58:55.036" "77.238.177.9" "RECEIVED: 250 null sender <> ok"
"SMTPC" 3304 7995 "2011-07-13 14:58:55.036" "77.238.177.9" "SENT: RCPT TO:<xxx@yahoo.co.uk>"
"SMTPC" 3160 7995 "2011-07-13 14:58:55.337" "77.238.177.9" "RECEIVED: 250 recipient <xxx@yahoo.co.uk> ok"
"SMTPC" 3160 7995 "2011-07-13 14:58:55.338" "77.238.177.9" "SENT: DATA"
"SMTPC" 5100 7995 "2011-07-13 14:58:55.637" "77.238.177.9" "RECEIVED: 354 go ahead"
"SMTPC" 5100 7995 "2011-07-13 14:58:55.638" "77.238.177.9" "SENT: [nl]."
"SMTPC" 2732 7995 "2011-07-13 14:58:57.058" "77.238.177.9" "RECEIVED: 250 ok dirdel"
"SMTPC" 2732 7995 "2011-07-13 14:58:57.058" "77.238.177.9" "SENT: QUIT"
regards,
Agie
Top
 Profile
PostPosted: 2011-07-13 12:36
I checked your domain and your MX record came back as
Code:
mail.hsn.co.id   0.0.0.0
Fix that and it should probably work. I am guessing gmail thinks 0.0.0.0 is itself
_________________
Top
 Profile
Who is online
Users browsing this forum: No registered users and 3 guests
Search for:
