Post new topic Reply to topic  [ 2 posts ]
Author Message
 Post subject: Multiple SMTP servers
PostPosted: 2010-11-09 05:43
Starting a new discussion from an existing tread per mattg.
Previous thread:
http://www.hmailserver.com/forum/viewtopic.php?f=7&t=13849&p=118192#p118192
Quote:
Yes you can use both on same server, but not the same port. Only one program can use port 25 on a single computer.
In your instance i would set up another computer (perhaps even a VM) with IIS SMTP or hmailserver installed, and use it for your mass mail out.
DooM wrote:
Quote:
I use two servers both with hmail on to send out mass email and keep regular mail flowing.
Thanks mattg and DooM. I want to make sure all mail goes out from one public IP which my PTR points to. Can I use multiple boxes with their own instance of hmailserver and direct all traffic out of the one server? I currently have two mail servers but only use one. I'd like to use them both but I'd prefer not to set up a new PTR going to the other mail server. I'll do that if I have to but is there a better way to do that?
Thank you.
Top
 Profile
 Post subject: Re: Multiple SMTP servers
PostPosted: 2010-11-09 05:59
If both machines are on the same LAN, there is no issue is there?
If not the smae LAN you will only need to modify your SPF.
A PTR record is not necessary for a mailserver, but if you have one then yes you could setup another PTR for the other IP address
'to direct all traffic out of one server', isn't that what you want to avoid?
_________________
Documentation
Top
 Profile
Who is online
Users browsing this forum: meadowsjared and 3 guests
Search for:
