I agree this would be a nice feature to have integrated into the admin panel.
In the meantime, here's a script that offers most of the functionality above except for the only sending every day, week, etc. That wouldn't be hard to add, you'd just need to persist that a mail was sent somehow.
Code:
Dim DebugLog
'**************User Defined Constants***************************
'Log Directory Where Debug log is stored
Const conLogDir = "D:\Program Files\hMailServer\Logs\"
'Percentage of space remaining when warning messages get sent
Const conSpaceRemainingWarningAt = 0.05
'Email Address that warning emails appear to be from
Const conSpaceWarningFrom = "admin@pcyoudo.com"
Const conSpaceWarningSubject = "Email storage limit almost reached"
Const conSpaceWarningBody = "[address], \n\nYour mailbox size of [size] MB is within 5% of its maximum space allotment of [maxsize] MB. In order to avoid bounced messages, please consider reducing the size of your mailbox. \n\nThanks,\n\nAdministrator"
'If True, debug log is created to help debug
Const conDebug = False
'InitializeVariables: Initialize global variables
Sub InitializeVariables
'Create our debug logger
Set DebugLog = new DebugLogger
'Set whether it is enabled or not
DebugLog.IsEnabled = conDebug
' End Sub
' Sub OnAcceptMessage(oClient, oMessage)
' End Sub
'Initialize our global variables
InitializeVariables
DebugLog.LogWithTimestamp "Entering OnDeliverMessage", DebugLog.IncreaseIndent
DoMailboxSizeLimitWarning( oMessage )
DebugLog.Log "Exiting OnDeliverMessage. Result.Value = " & Result.Value, DebugLog.DecreaseIndent
'Cleanup our variables
DisposeVariables
' Mailbox Limit Approaching Functionality
Sub DoMailboxSizeLimitWarning( oMessage )
DebugLog.Log "Entering DoMailboxSizeLimitWarning", DebugLog.IncreaseIndent
Dim oAccount
Dim messageBody
Set oAccount = new Account
'Check to make sure the message we're checking against
'isn't a warning message. Otherwise we'll get stuck in an
'endless mail sending loop
If oMessage.Subject <> conSpaceWarningSubject Then
'Loop through all the mail recipients
For i = 0 To oMessage.Recipients.Count - 1
DebugLog.Log "Recipient: " & oMessage.Recipients(i).Address, null
'Check to see if recipient is local
If Recipients(i).IsLocalUser Then
'if so, let's load their account to get their mailbox info
oAccount.LoadAccountFromAddress( oMessage.Recipients(i).Address )
'Is the mailbox approaching the threshold specified?
If oAccount.IsMailboxWithinXPercentOfLimit(conSpaceRemainingWarningAt) Then
'Customize our warning message for this user
messageBody = conSpaceWarningBody
messageBody = Replace( messageBody, "\n", vbCRLF )
messageBody = Replace( messageBody, "[address]", oAccount.Address )
messageBody = Replace( messageBody, "[maxsize]", oAccount.MaxSize )
messageBody = Replace( messageBody, "[size]", oAccount.Size )
'Send warning message
DebugLog.Log "Sending Warning Message to " & oAccount.Address, null
SendMessage conSpaceWarningFrom, Array( oAccount.Address ), conSpaceWarningSubject, messageBody
Set oAccount = Nothing
DebugLog.Log "Exiting DoMailboxSizeLimitWarning", DebugLog.DecreaseIndent
'DisposeVariables: Clean up any variables we might have been using
Sub DisposeVariables
DebugLog.Dispose
Set DebugLog = Nothing
'***************************** Helper Classes ********************************
Class Account
Dim oAccount
Public Property Get Address
Address = oAccount.Address
End Property
Public Property Get MaxSize
MaxSize = oAccount.MaxSize
End Property
Public Property Get Size
Size = oAccount.Size
End Property
Function IsMailboxWithinXPercentOfLimit( dblPercent )
DebugLog.Log "Entering IsMailboxWithinXPercentOfLimit dblPercent: " & dblPercent, DebugLog.IncreaseIndent
DebugLog.Log "Current MB Size: " & Size & " Max MB Size: " & MaxSize & " Warning Size: " & MaxSize * dblPercent, null
If MaxSize = 0 Then DebugLog.Log "Account has no storage limit! Returning false", null
'Perform our calc, a MaxSize of 0 means there is no max size, so
'in that case we'll always return false
If( MaxSize > 0 And MaxSize * dblPercent < Size ) Then
IsMailboxWithinXPercentOfLimit = True
IsMailboxWithinXPercentOfLimit = False
DebugLog.Log "Exiting IsMailboxWithinXPercentOfLimit. Return value: " & IsMailboxWithinXPercentOfLimit, DebugLog.DecreaseIndent
Sub LoadAccountFromAddress( strAddress )
Dim oDomains
Dim oDomain
Dim oAccounts
Dim strDomain
DebugLog.Log "Entering LoadAccountFromAddress, strAddress = " & strAddress, DebugLog.IncreaseIndent
DebugLog.Log "Creating Domains Object", null
Set oDomains = CreateObject("hMailServer.Domains")
DebugLog.Log "Created Domains Object", null
strDomain = Right( strAddress, Len( strAddress ) - InStr(strAddress, "@") )
DebugLog.Log "Domain from address is: " & strDomain, null
Set oDomain = oDomains.ItemByName( strDomain )
DebugLog.Log "Creating Accounts Object", null
Set oAccounts = oDomain.Accounts
DebugLog.Log "Created Accounts Object", null
DebugLog.Log "Getting Account: " & strAddress, null
' Enable error handling
On Error Resume Next
Set oAccount = oAccounts.ItemByAddress(strAddress)
DebugLog.LogError
' Reset error handling
On Error Goto 0
DebugLog.Log "Got Account: " & oAccount.Address, null
Set oAccounts = Nothing
Set oDomains = Nothing
Set oDomain = Nothing
DebugLog.Log "Exiting LoadAccountFromAddress", DebugLog.DecreaseIndent
End Class
Function SendMessage( strFrom, arrRecipients, strSubject, strBody )
DebugLog.Log "Entering SendMessage strFrom = " & strFrom & " arrRecipients = " &_
Join(arrRecipients," : ") & " strSubject = " & strSubject & " strBody = " & strBody, DebugLog.IncreaseIndent
Dim oMessage
oMessage.From = strFrom
oMessage.Subject = strSubject
Dim arrRecipientParts
For Each recipient in arrRecipients
arrRecipientParts = Split( recipient, "," )
If( UBound( arrRecipientParts ) > 1 ) Then
oMessage.AddRecipient arrRecipientParts(0), arrRecipientParts(1)
oMessage.AddRecipient "", arrRecipientParts(0)
oMessage.Body = strBody
Set oMessage = Nothing
DebugLog.Log "Exiting SendMessage", DebugLog.DecreaseIndent
'DebugLogger: A class to log debug messages. Logging only works
' if IsEnabled = true, otherwise all logging calls are ignored
Class DebugLogger
Private m_intIndent
Private m_blnIsEnabled
Public Property Get IsEnabled
IsEnabled = m_blnIsEnabled
End Property
Public Property Let IsEnabled(ByVal blnValue)
m_blnIsEnabled = blnValue
End Property
Public Property Get DecreaseIndent
DecreaseIndent = -1
End Property
Public Property Get IncreaseIndent
IncreaseIndent = 1
End Property
Private Property Get LogDir
LogDir = conLogDir
End Property
Private Property Get Indent
If m_intIndent = "" Then
m_intIndent = 0
Indent = m_intIndent
End Property
Private Property Let Indent(ByVal intValue)
m_intIndent = intValue
End Property
Sub Dispose
Private Sub IncIndent
Indent = Indent + 1
Private Sub DecIndent
If Indent > 0 Then
Indent = Indent - 1
Sub LogError
If Err.number <> 0 Then
' Object couldn't be created
' Log error
Log "**Error: Description: " & Err.Description & " Severity: " & apgSeverityError & " Number: " & Err.Number, null
Sub LogWithTimestamp( strString, intIndentType )
Log Date & " " & Time & " " & strString, intIndentType
Sub Log( strString, intIndentType )
If IsEnabled Then
'We decrease indent immediately
If intIndentType = DecreaseIndent Then
DecIndent
SET oFs = CreateObject("Scripting.FileSystemObject")
SET oFil = ofs.OpenTextFile( LogDir & "Debug.log", 8, True)
For i = 0 To Indent
oFil.write(" ")
oFil.WriteLine( strString )
oFil.Close
SET oFil = Nothing
SET oFs = Nothing
'We increase indent after
If intIndentType = IncreaseIndent Then
IncIndent
End Class
'Logger: Logging class to log whatever to a log file
' Copied/Modified from mnadig's post
' (http://www.hmailserver.com/forum/viewtopic.php?t=1798)
Class Logger
LogDir = conLogDir
End Property
Sub WriteLog( strString )
SET oFil = ofs.OpenTextFile( LogDir & "Events.log", 8, True)
oFil.writeline( strString)
oFil.close
SET oFil = Nothing
SET oFs = Nothing
End Class
