Is sawin32 daemon/server and in log file I have:
"DEBUG" 3484 "2010-06-17 15:32:49.039" "Creating session 2" "TCPIP" 3484 "2010-06-17 15:32:49.039" "Connecting to localhost..." "DEBUG" 844 "2010-06-17 15:32:50.133" "Sending message to SpamAssassin. Session 2, File: C:\Program Files\hMailServer\Temp\{B7DA159E-6FA7-411B-8526-888E527BBC52}.tmp" "DEBUG" 844 "2010-06-17 15:33:20.133" "The client has timed out. Session: 2" "DEBUG" 844 "2010-06-17 15:33:20.133" "Closing TCP/IP socket" "ERROR" 580 "2010-06-17 15:33:20.133" "Severity: 3 (Medium), Code: HM5157, Source: SpamAssassinClient::OnReadError, Description: There was a communication error with SpamAssassin. hMailServer tried to retrieve data from SpamAssassin but the connection to SpamAssassin was lost. The WinSock error code is 995. Enable debug logging to retrieve more information regarding this problem. The problem could be that SpamAssassin is malfunctioning." "DEBUG" 580 "2010-06-17 15:33:20.179" "The read operation failed. Bytes transferred: 0 Remote IP: , Session: 2, Code: 995, Message: Operazione di I/O terminata a causa dell'uscita dal thread oppure della richiesta di un'applicazione" "DEBUG" 3484 "2010-06-17 15:33:20.179" "Ending session 2"
and then:
"ERROR" 3624 "2010-06-17 15:26:50.999" "Severity: 3 (Medium), Code: HM5157, Source: SpamAssassinClient::OnReadError, Description: There was a communication error with SpamAssassin. hMailServer tried to retrieve data from SpamAssassin but the connection to SpamAssassin was lost. The WinSock error code is 995. Enable debug logging to retrieve more information regarding this problem. The problem could be that SpamAssassin is malfunctioning." "ERROR" 580 "2010-06-17 15:33:20.133" "Severity: 3 (Medium), Code: HM5157, Source: SpamAssassinClient::OnReadError, Description: There was a communication error with SpamAssassin. hMailServer tried to retrieve data from SpamAssassin but the connection to SpamAssassin was lost. The WinSock error code is 995. Enable debug logging to retrieve more information regarding this problem. The problem could be that SpamAssassin is malfunctioning."
In sawin config I have:
783 = localhost:783
this's correct ? My hmailserver installation is on Microsoft Windows 2008 Server Standard Edition 32bit.
Thanks.
- Salvatore.
