Post new topic Reply to topic  [ 2 posts ]
Author Message
 Post subject: Whitemail usage details
PostPosted: 2007-09-03 03:29
The "Description" and "Lower and Upper IP" sections seem pretty self-explanatory. However, the "E-mail address" has presented some difficulty and probably needs some clarification...
The manual states;
Quote:
E-mail address
The e-mail address which should be white-listed. It is possible to use wildcards in this field. For example, you may whitelist all email from the domain example.com, by specifying the address *@example.com
1. Are multiple * allowed in each entry?
2. Are ? allowable as single character wildcards?
3. Does the example, "*@example.com", whitelist ALL email from the domain example.com (e.g. implied "*@*example.com) ... or just "all-the-mailboxes" for example.com ?
3a. If the former is the case, is the"@" optional?
3b. Is "admin@*example.com" valid for admin@mail1.example.com, admin@mail2.example.com AND admin@example.com
4. What field from the email message header is used to create the 'matching' text for this entry?
Top
 Profile
 Post subject:
PostPosted: 2007-09-03 19:01
1) Yes
2) Yes
3) It works as a normal wildcard. *@example.com whitelists all email from the domain example.com, not from someotherdomain.example.com.
3b) Yes
4) If the message is delivered to hMailServer using SMTP, the FROM envelope address is used (not any of the MIME headers). If the message is downloaded from an external POP3 account, the From MIME header is used.
Top
 Profile
Who is online
Search for:
