Parsing Public Suffix List in VBS
Post by palinka » 2020-05-09 20:02
I'm trying to parse the public suffix list here: https://publicsuffix.org/list/public_suffix_list.dat
First I created a powershell script to download the list and output it into a regex string like this:
PubSufRegEx = "^ac$|^com\.ac$|^edu\.ac$|^gov\.ac$|^net\.ac$|^mil\.ac$|^org\.ac$|...REST OF LIST ABRIDGED...|^ad$"
This part works. The string is outputted to public_suffix_list.vbs and then in my VBS test function, I include the file.
The problem I'm having is getting the correct result. I'm split the domain into pieces then test each part against the regex string. This is the part that doesn't work. It seems to match anything. However, if I remove the "function" business and just run the code, then it does work. I'm obviously missing something stupid that I just can't put my finger on.
Here's my vbs test script:
Option Explicit
Function Include(sInstFile)
   Dim f, s, oFSO
   On Error Resume Next
   If oFSO.FileExists(sInstFile) Then
      Set f = oFSO.OpenTextFile(sInstFile)
      s = f.ReadAll
      f.Close
      ExecuteGlobal s
   On Error Goto 0
      .Pattern = strRegEx
      .Global = False
      .MultiLine = True
      .IgnoreCase = True
		.Pattern = strRegEx
		.Global = bGlobal
		.MultiLine = True
		.IgnoreCase = True
Function CheckDomain(strDomain)
	Dim strRegEx, PubSufRegEx, Match, Matches
	Dim TLDTopLevel, TLDSecondLevel, TLDThirdLevel, TLDFourthLevel, TLDFifthLevel, Domain
	Include("C:\scripts\hmailserver\FWBan\PublicSuffix\public_suffix_list.vbs")
	strRegEx = "[A-Za-z]+$"
	Set Matches = oLookup(strRegEx, strDomain, False)
	For Each Match In Matches
	   TLDTopLevel = LCase(Match.Value)
	strRegEx = "[A-Za-z0-9-]+\.[a-z]+$"
	   TLDSecondLevel = LCase((Split(Match.Value, "."))(0))
	strRegEx = "[A-Za-z0-9-]+\.[A-Za-z0-9-]+\.[a-z]+$"
	   TLDThirdLevel = LCase((Split(Match.Value, "."))(0))
	strRegEx = "[A-Za-z0-9-]+\.[A-Za-z0-9-]+\.[A-Za-z0-9-]+\.[a-z]+$"
	   TLDFourthLevel = LCase((Split(Match.Value, "."))(0))
	strRegEx = "[A-Za-z0-9-]+\.[A-Za-z0-9-]+\.[A-Za-z0-9-]+\.[A-Za-z0-9-]+\.[a-z]+$"
	   TLDFifthLevel = LCase((Split(Match.Value, "."))(0))
	If Lookup(PubSufRegEx, TLDTopLevel) Then
		Domain = TLDSecondLevel & "." & TLDTopLevel
	If Lookup(PubSufRegEx, (TLDSecondLevel & "." & TLDTopLevel)) Then
		Domain = TLDThirdLevel & "." & TLDSecondLevel & "." & TLDTopLevel
	If Lookup(PubSufRegEx, (TLDThirdLevel & "." & TLDSecondLevel & "." & TLDTopLevel)) Then
		Domain = TLDFourthLevel & "." & TLDThirdLevel & "." & TLDSecondLevel & "." & TLDTopLevel
	If Lookup(PubSufRegEx, (TLDFourthLevel & "." & TLDThirdLevel & "." & TLDSecondLevel & "." & TLDTopLevel)) Then
		Domain = TLDFifthLevel & "." & TLDFourthLevel & "." & TLDThirdLevel & "." & TLDSecondLevel & "." & TLDTopLevel
	CheckDomain = Domain
	Dim strDomain, DomainName
	' strDomain = "pool-72-76-221-125.nwrknj.fios.verizon.net"
	' strDomain = "msnbot-207-46-13-192.search.msn.com"
	' strDomain = "SKNcd-03p13-20.ppp11.odn.ad.jp"
	' strDomain = "v150-95-128-207.a079.g.TyO1.STATIC.cnode.io"
	' strDomain = "230.19.7.186.f.dyn.claro.net.do"
	' strDomain = "hotelbrisamaral.static.gvt.net.br"
	strDomain = "6thLevel.5thLevel.hotelbrisamaral.rs.gov.br"
WScript.Echo CheckDomain(strDomain)
And here is my powershell (working):
.SYNOPSIS
.DESCRIPTION
.FUNCTIONALITY
.NOTES
.EXAMPLE
<#  Set script variables  #>
$URL = "https://publicsuffix.org/list/public_suffix_list.dat"
$PubSufFile = "$PSScriptRoot\public_suffix_list.dat"
$CondensedDatList = "$PSScriptRoot\public_suffix_list.vbs"
<#  Download latest Public Suffix data  #>
$LastDownloadTime = (Get-Item $PubSufFile).LastWriteTime
$HoursSinceLastDownload = [int](New-Timespan $LastDownloadTime).TotalHours
If ($HoursSinceLastDownload -gt 23){
	Try {
		Start-BitsTransfer -Source $URL -Destination $PubSufFile -ErrorAction Stop
	Catch {
		Write-Host "Error downloading Public Suffix List: `n$Error[0]"
		Exit
<#  Read data file and output list  #>
 Get-Content $PubSufFile | Where {((-not([string]::IsNullOrEmpty($_))) -and ($_ -notmatch "^//|^\*|^\!"))} | ForEach {
	Write-Output "^$_$"
} | Out-File $CondensedDatList
<#  Convert list to RegEx pattern  #>
(Get-Content -Path $CondensedDatList) -Replace '$','|' | Set-Content -NoNewline -Path $CondensedDatList
(Get-Content -Path $CondensedDatList) -Replace '\.','\.' | Set-Content -NoNewline -Path $CondensedDatList
(Get-Content -Path $CondensedDatList) -Replace '^','PubSufRegEx = "' | Set-Content -NoNewline -Path $CondensedDatList
(Get-Content -Path $CondensedDatList) -Replace '\|$','' | Set-Content -NoNewline -Path $CondensedDatList
(Get-Content -Path $CondensedDatList) -Replace '$','"' | Set-Content -NoNewline -Path $CondensedDatList
Re: Parsing Public Suffix List in VBS
Post by palinka » 2020-05-09 20:09
This works - it returns the correct result. But no function. What I want is to turn this working thing into a function. Its the same as above except not in "function form".
' Function CheckDomain(strDomain)
	Dim strDomain
	WScript.Echo Domain
	' CheckDomain = Domain
' End Function
Post by palinka » 2020-05-13 03:44
Got it working. I knew it was something really stupid. I DIM'd PubSufRegEx, so it was always blank, therefore EVERYTHING MATCHES! YAY!
Anyway, this could be useful for a few things. I have a use for it.
Option Explicit
   Dim f, s, oFSO
      s = f.ReadAll
      f.Close
      ExecuteGlobal s
   On Error Goto 0
      .Pattern = strRegEx
      .Global = False
      .MultiLine = True
      .IgnoreCase = True
		.Pattern = strRegEx
		.Global = bGlobal
		.MultiLine = True
		.IgnoreCase = True
	Dim strRegEx, Match, Matches
	Dim SpamDomain
	Set Matches = oLookup(PubSufRegEx, TLDTopLevel, False)
		If Match.Value = TLDTopLevel Then
			SpamDomain = TLDSecondLevel & "." & TLDTopLevel
	Set Matches = oLookup(PubSufRegEx, (TLDSecondLevel & "." & TLDTopLevel), False)
		If Match.Value = TLDSecondLevel & "." & TLDTopLevel Then
			SpamDomain = TLDThirdLevel & "." & TLDSecondLevel & "." & TLDTopLevel
	Set Matches = oLookup(PubSufRegEx, (TLDThirdLevel & "." & TLDSecondLevel & "." & TLDTopLevel), False)
		If Match.Value = TLDThirdLevel & "." & TLDSecondLevel & "." & TLDTopLevel Then
			SpamDomain = TLDFourthLevel & "." & TLDThirdLevel & "." & TLDSecondLevel & "." & TLDTopLevel
	Set Matches = oLookup(PubSufRegEx, (TLDFourthLevel & "." & TLDThirdLevel & "." & TLDSecondLevel & "." & TLDTopLevel), False)
		If Match.Value = TLDFourthLevel & "." & TLDThirdLevel & "." & TLDSecondLevel & "." & TLDTopLevel Then
			SpamDomain = TLDFifthLevel & "." & TLDFourthLevel & "." & TLDThirdLevel & "." & TLDSecondLevel & "." & TLDTopLevel
	CheckDomain = SpamDomain
' Test a few EHLOs
Dim strDomain
' strDomain = "pool-72-76-221-125.nwrknj.fios.verizon.net"    ' public suffix domain verizon.net
' strDomain = "msnbot-207-46-13-192.search.msn.com"           ' public suffix domain msn.com
' strDomain = "SKNcd-03p13-20.ppp11.odn.ad.jp"                ' public suffix domain odn.ad.jp
' strDomain = "v150-95-128-207.a079.g.TyO1.STATIC.cnode.io"   ' public suffix domain cnode.io
' strDomain = "230.19.7.186.f.dyn.claro.net.do"               ' public suffix domain claro.net.do
' strDomain = "hotelbrisamaral.static.gvt.net.br"             ' public suffix domain gvt.net.br
strDomain = "6thLevel.5thLevel.hotelbrisamaral.rs.gov.br"     ' public suffix domain hotelbrisamaral.rs.gov.br
' strDomain = "expressomx.pr.gov.br"                          ' public suffix domain expressomx.pr.gov.br
' strDomain = "mail.saude.ma.gov.br"                          ' public suffix domain saude.ma.gov.br
Dim RecordSpamDomain : RecordSpamDomain = CheckDomain(strDomain)
If RecordSpamDomain <> "" Then
	WScript.Echo "Record SpamEHLO: " & strDomain & " as Main Domain: " & Chr(34) & RecordSpamDomain & Chr(34)
	WScript.Echo "Shit's broke, yo!"
