Set ForwardAddress from a Script doesnt work
Wichert
Post by Wichert » 2019-10-21 09:17
im new at Hmailserver and the scripting with it.
I searched for a possibility to activate and set the ForwardAddress form a Script.
At the moment i have the follwed code and it works for the Fields. I can look at the Webinterface and the Checkboxes and the Address is correctly insert.
But it doesnt work. The Hmailserver tried 7 times and said that the recipients could not be reached.
After i pressed "Save" in the Webinterface it works fine.
I used the following forum entry for my scripting:
https://www.hmailserver.com/forum/viewtopic.php?t=9875
I hope someone can help.
Best Regards
My Code:
Sub ForwardON(oMessage)
   Dim obApp
   Call obApp.Authenticate("Administrator","******")
	strForward= oMessage.body
	aUsername = Split(oMessage.fromaddress,"@")
	Dim obDomain
	Set obDomain = obApp.Domains.ItemByName(aUsername(1))
	Dim obAccount
	Set obAccount = obDomain.Accounts.ItemByAddress(oMessage.fromaddress)
	obAccount.ForwardAddress  = strForward
	obAccount.ForwardEnabled = 1
	obAccount.ForwardKeepOriginal = 1
	oMessage.subject = "Emails are forward to" & strForward
	oMessage.body = strForward
	obAccount.Save 'saves account
	oMessage.save
Re: Set ForwardAddress from a Script doesnt work
Post by katip » 2019-10-21 11:59
there is something wrong i think. you should enter an address here. not the mail body.
Wichert
Post by Wichert » 2019-10-21 13:07
i type only the E-Mail Adress into the "body" an set the mails as "plain-text".
Is that impossible?
Post by katip » 2019-10-21 15:47
i don't think it will be parsed correctly.
i suppose you try to activate forwarding by sending a message. try Subject instead of Body to put the address.
Wichert
Post by Wichert » 2019-10-22 14:55
Thx Katip,
it was a Problem with the "body".
I wrote the body to a File and read only the row with Email Address.
In my case its the first row.
See code below if someone need this.
Sub WeiterleitungAN(oMessage)
   Dim CreateGUIDval, obUtilities, PathStore
   PathStore = "C:\Mailing\Weiterleitung"
   Set obUtilities = CreateObject("hMailServer.Utilities")
   TempParamFile = PathStore & "\" & Mid(obUtilities.GenerateGUID, 2, 36) & ".txt"
    Set objTextFile = objFSO.OpenTextFile(TempParamFile, 2, true)
    objTextFile.WriteLine(oMessage.body)
    objTextFile.Close
   Dim Weiterleitungsadresse
   Set oRead = objFSO.OpenTextFile(TempParamFile, 1)
   Do Until oRead.AtEndOfStream
     MessageInputLine = oRead.ReadLine
	 If not MessageInputLine = "" then
		 Weiterleitungsadresse = MessageInputLine
	End if
   Loop
	oRead.Close()  ' Close input file
	objFSO.DeleteFile TempParamFile
   Dim obApp
	Dim obDomain
	Dim obAccount
	obAccount.ForwardAddress  = Weiterleitungsadresse
	oMessage.subject = "E-Mails werden weitergeleitet an: " & Weiterleitungsadresse
	oMessage.save
Post by katip » 2019-10-22 15:49
that looks fine now.
thanks for sharing.
