change from write oldfrom to subject
outrunner77
Post by outrunner77 » 2019-06-26 12:50
Hi, I'm using the eventhandler script to change the from address and everything is working correctly, if possible I'd like to add to the script to write the original sender into the subject or message body. Is this possible?
For reference the script I'm using is below. Assume it would just be a matter of writing oldfrom into the message or subject.
oldFrom = oMessage.FromAddress
oMessage.FromAddress = "s.relay@test.com"
oMessage.From = "<s.relay@test.com>"
oMessage.save
EventLog.Write("Testing account From rewrite " & oldFrom & " - to - " & oMessage.FromAddress )
Result.value = 0
Thanks.
Re: change from write oldfrom to subject
Post by jimimaseye » 2019-06-26 14:13
Example.
outrunner77 wrote:
2019-06-26 12:50
OMessage.subject = oldFrom & " " & omessage.subject
oMessage.save
Result.value = 0
outrunner77
Post by outrunner77 » 2019-06-26 14:40
Brilliant. Thank you I'll give it a go.
estradis
Post by estradis » 2019-07-25 17:30
Please keep in mind that subject changes will break DKIM.
