Firewall Ban
hMailserver-User
Re: Firewall Ban
Post by hMailserver-User » 2019-11-23 15:02
2019-11-23 14:34
I noticed there's a space at the beginning:
VALUES (' 2019-11-23 08:29:31',
The script reads the date and time from the firewall log. So the formatting problem could be coming from the firewall log and not necessarily from powershell. What are the date and time formats in the firewall log (localized in Germany)?
I am from Austria - my windows default settings for time, ...:
Here are some lines from my firewall log:
2019-11-23 12:53:23 DROP TCP 193.56.28.101 000.000.000.000 59653 25 48 S 4232364007 0 8192 - - - RECEIVE
2019-11-23 12:56:17 DROP TCP 193.56.28.101 000.000.000.000 56217 25 52 S 3342926694 0 8192 - - - RECEIVE
2019-11-23 12:56:20 DROP TCP 193.56.28.101 000.000.000.000 56217 25 52 S 3342926694 0 8192 - - - RECEIVE
2019-11-23 12:56:26 DROP TCP 193.56.28.101 000.000.000.000 56217 25 48 S 3342926694 0 8192 - - - RECEIVE
2019-11-23 12:57:01 DROP TCP 185.234.219.102 000.000.000.000 57140 25 52 S 404735548 0 8192 - - - RECEIVE
2019-11-23 12:57:04 DROP TCP 185.234.219.102 000.000.000.000 57140 25 52 S 404735548 0 8192 - - - RECEIVE
In the log there is no space in the beginning
Re: Firewall Ban
Post by palinka » 2019-11-23 16:22
hMailserver-User wrote:
2019-11-23 15:02
Here is the entirety of the firewall parsing. Is it possible that you introduced a space by accident?
#	Get firewall logs - https://github.com/zarabelin/Get-WindowsFirewallLogs/blob/master/Get-WindowsFirewallLog.ps1
$LSRegex = "($LANSubnet\.\d{1,3})|(158\.201\.243\.\d{1,3})"
$MinuteSpan = 5 # Should match interval of scheduled task
$EndTime = $QueryTime
$StartTime = ([datetime]::parseexact($QueryTime, 'yyyy-MM-dd HH:mm:00', $Null ) - (New-TimeSpan -Minutes $MinuteSpan)).ToString("HH:mm:ss")
$DateEnd = $QueryTime
$DateStart = ([datetime]::parseexact($QueryTime, 'yyyy-MM-dd HH:mm:00', $Null ) - (New-TimeSpan -Minutes $MinuteSpan)).ToString("yyyy-MM-dd")
$FirewallLogObjects = import-csv -Path $FirewallLog -Delimiter " " -Header Date, Time, Action, Protocol, SourceIP, `
    DestinationIP, SourcePort, DestinationPort, Size, tcpflags, tcpsyn, tcpack, tcpwin, icmptype, icmpcode, info, path | `
    Where-Object {$_.date -match "[0-9][0-9][0-9][0-9]-[0-9][0-9]-[0-9][0-9]"}
$FirewallLogObjects = $FirewallLogObjects | Where-Object {$_.Date -ge $DateStart -and $_.Date -lt $DateEnd}
$FirewallLogObjects = $FirewallLogObjects | Where-Object {$_.Time -ge $StartTime -and $_.Time -lt $EndTime}
$FirewallLogObjects | foreach-object {
	if ($_.DestinationPort -match $MailPorts) {
		if ($_.SourceIP -notmatch $LSRegex){
			$IP = ($_.SourceIP).trim()
			$DateTime = (($_.Date).trim()+" "+($_.Time).trim())
			$Query = "INSERT INTO hm_fwban_rh (timestamp, ipaddress) VALUES ('$DateTime', '$IP')"
			MySQLQuery $Query
Maybe you accidentally added a space here:
$Query = "INSERT INTO hm_fwban_rh (timestamp, ipaddress) VALUES ('?SPACE?$DateTime', '$IP')"
The date time format in the log is the same. I don't think its a formatting error.
hMailserver-User
Re: Firewall Ban
Post by hMailserver-User » 2019-11-23 16:47
2019-11-23 16:22
			MySQLQuery $Query
Checked it and the above line is like it should be:
I have forgotten to say that i had that entry only one time. It doesn't happen every time a entry is made into hm_fwban_rh ...Sorry. :roll:
I have another error on this:
19.11.23 12:55:01.49 : ERROR : Unable to run query : INSERT INTO hm_fwban_rh (timestamp, ipaddress) VALUES ('2019-11-23 12:50:10', '193.56.28.101')
Ausnahme beim Aufrufen von "Fill" mit 2 Argument(en):  "Packets larger than max_allowed_packet are not allowed."[0]
But also only one time today.
Re: Firewall Ban
Post by palinka » 2019-11-23 17:16
2019-11-23 16:47
I've never seen that before. I googled it. It seems strange. Apparently, the default max_allowed_packet is 16 MB. There is not a chance in hell that a single date and a single IP address approach a single kb, much less 16MB. I looked in my.ini and my own setting is max_allowed_packet = 1M.
I wouldn't worry about it. If it happens again look in MySQL my.ini and see if you have "max_allowed_packet". If not, add this and reboot:
Or 16MB, which is supposedly the default. 1GB is the max.
hMailserver-User
Re: Firewall Ban
Post by hMailserver-User » 2019-11-23 19:31
2019-11-23 17:16
My current my.ini has no entry for that so default will be used ...
Now i have a queston:
	If (oClient.Port = 25) Then
		'  ALLOWED COUNTRIES - Port 25 only... Check Alpha-2 Code here -> https://en.wikipedia.org/wiki/ISO_3166-1
		strBase = "^(US|CA|AT|BE|CH|CZ|DE|DK|ES|FI|FR|GB|GL|GR|HR|HU|IE|IS|IT|LI|MC|NL|NO|PL|PT|RO|RS|SE|SI|SK|SM|AU|NZ)$"
		If Lookup(strBase, oGeoip("countryCode")) Then bolGeoIP = True
		'  ALLOWED COUNTRIES - All ports except 25... Check Alpha-2 Code here -> https://en.wikipedia.org/wiki/ISO_3166-1
		strBase = "^(AT|CZ|DE)$"
For my understanding the above setting should on port 25 allow the countries "US|CA|AT|BE|CH|CZ|DE|DK|ES|FI|FR|GB|GL|GR|HR|HU|IE|IS|IT|LI|MC|NL|NO|PL|PT|RO|RS|SE|SI|SK|SM|AU|NZ" and additional on every other port (993, 465, 587, ...) only the countries AT, CZ and DE are allowed. This will allow IMAP from mobile clients roaming there. correct?
Re: Firewall Ban
Post by palinka » 2019-11-23 20:00
2019-11-23 19:31
Yes, exactly.
One other thing I've found is that sometimes due to network or other errors, a geoip result cannot be found, which makes the result NULL. Since NULL does not match any of your allowed country codes, it will be rejected. The potential for false positives on NULL value is high, and I prefer a NULL response just get past the filter - if its spam, its likely to get picked up on one of the other filters or by spamassassin. To allow a NULL response, just add a pipe at the end of your string base like this:
...CZ|DE|)$
Since there is nothing after the pipe, NULL will pass because NULL = nothing. :D
Re: Firewall Ban
Post by palinka » 2019-11-23 23:02
I just added this auto expiration to my powershell:
#	Automatic expiration from firewall - Reason: "One Hit Wonders"
#	Release all IPs that never returned after specified number of days
$Days = "30" 	# <-- Number of days for automatic expiry
$Query = "
	SELECT id, ipaddress
	FROM hm_fwban
	WHERE hm_fwban.ipaddress NOT IN
		SELECT ipaddress
		FROM hm_fwban_rh
	AND timestamp < NOW() - INTERVAL $Days DAY
	AND flag IS NULL
	ORDER BY timestamp DESC
MySQLQuery $Query | foreach {
	$ID = $_.id
	$IP = $_.ipaddress
	& netsh advfirewall firewall delete rule name=`"$IP`"
	$Query = "UPDATE hm_fwban SET flag=1 WHERE id='$ID'"
	MySQLQuery $Query
Now that I have several months and 13k firewall rules - and a way to better analyze who gets blocked, I see that about 55% of my bans have never returned, so there's no point in keeping them.
Delete all firewall rules for IPs that have never appeared in the firewall log after N days. I chose 30 days and this will delete 5,352 firewall rules.
Re: Firewall Ban
Post by palinka » 2019-11-24 00:52
2019-11-23 01:11
Its me again :-)
I am still on my "old" version which is working so far as expected. Before i start from scratch: there must be a problem with releasing / unban IPs via webif.
The following ip is released / marked as safe.
https://www.bilder-upload.eu/bild-0ecb0 ... 9.png.html
Afair marking as safe doesnt automatically removed it from the firewall. Releasing did it.
But the entry comes back. Even if i delete it manually from the windows firewall - the entry comes back again.
How can i track that down?
Hope you understand what i mean :oops:
I think I figured out why marking SAFE didn't remove the firewall rule. I changed the order of operation so processing SAFE comes first. I'm going to experiment a little and see if it works, then I'll update GitHub.
hMailserver-User
Re: Firewall Ban
Post by hMailserver-User » 2019-11-24 01:03
2019-11-24 00:52
Thank you!
Re: Firewall Ban
Post by palinka » 2019-11-24 01:08
2019-11-24 01:03
Thank you!
Funny thing is the only IP I ever marked safe was the one for hmailserver.com. Something Martin did once caused the helo to change temporarily to the name of his VM, which caused my hmailserver to trigger a ban. :mrgreen:
hMailserver-User
Re: Firewall Ban
Post by hMailserver-User » 2019-11-24 10:07
2019-10-31 10:58
nitro wrote:
2019-10-31 10:28
You have to be careful with the lords of Microsoft.
It can be a false positive in, FQDN as HELO.
AM5EUR02FT035.mail.protection.outlook.com
EUR04-DB3-obe.outbound.protection.outlook.com
EUR03-VE1-obe.outbound.protection.outlook.com
I discovered that yesterday too. I added outbound.protection.outlook.com$ to the list of "known false positives" so they skip the test.
you should add this to the version on github too :wink:
Re: Firewall Ban
Post by palinka » 2019-11-26 00:27
2019-11-24 10:07
That's really for individuals to set up. Here's how I did it:
	'	Run on PTR-Record
	If PTR_Record <> "" Then
		'   Exclude certain false positives
		strRegEx = "sendgrid|facebook\.com$|outbound\.protection\.outlook\.com$"
		If Lookup(strRegEx, PTR_Record) Then Exit Sub
		'   Search for dynamic looking PTR
		strRegEx = 	"(.*(((?:[0]{0,2})" & a(0) & "|(?:[0]{0,2})" & a(1) & "|(?:[0]{0,2})" & a(2) & "|(?:[0]{0,2})" & a(3) & ")(?:.+)){3}" &_
					"((?:[0]{0,2})" & a(0) & "|(?:[0]{0,2})" & a(1) & "|(?:[0]{0,2})" & a(2) & "|(?:[0]{0,2})" & a(3) & ").+)$"
		etc........
Also, I think I've found the practical limit of the number of firewall rules. Its something more than 10,000 rules. I started getting database connection errors that I could not pin down and I think they're related to the firewall not responding / not responding in time. Anyway, that caused me to rethink the individual rule per IP. I've changed it to consolidate all rules for a single day into one rule with multiple remote addresses. I'm testing it now. I consolidated 14k rules into about 300. New rules are added normally, then the next day they get consolidated into a single rule. I also figured out a way to update those consolidated rules in case you release, reban manually add or mark safe an IP. :D
So far, no MySQL connection errors, so I think its working. In a couple of days I'll post it to GitHub with instructions.
Re: Firewall Ban
Post by palinka » 2019-11-26 20:54
I just uploaded ^this^ to GitHub. I haven't had any errors at all in 2 days, so I guess its good to go.
Re: Firewall Ban
Post by palinka » 2019-11-27 17:23
I woke up this morning and nothing was working. OH NOES!!! :lol:
I had to log in to my server from a real keyboard and monitor. In my installation, as I was messing with GitHub yesterday, I changed my db password to "supersecretpassword" instead of the real password. Therefore, the query failed for rule consolidation. Therefore the output of yesterday's IPs was blank. Therefore the firewall rule created had NOTHING as remoteaddress. Therefore, I created a firewall rule blocking all local and all remote IPs. :mrgreen:
So... I added a test to make sure that never happens again. If blank then stop. This is updated on GitHub.
Re: Firewall Ban
Post by palinka » 2019-11-27 18:23
New GitHub update: Removed deduplicator from hmsFirewallBan.ps1 and created new standalone deduplicator that also looks for orphaned rules.
Re: Firewall Ban
Post by palinka » 2019-12-05 23:05
2019-11-24 10:07
Everything working ok?
Re: Firewall Ban
Post by palinka » 2020-01-14 03:51
Updated search page so if you click on "HELO", a popup window shows details including PTR. The PTR record is derived dynamically from PHP "gethostbyaddr", so no new db column is required.
Demo: http://hmsfirewallbandemo.ddns.net/
Files: https://github.com/palinkas-jo-reggelt/ ... rewall-Ban
adrianmihai83
Re: Firewall Ban
Post by adrianmihai83 » 2020-01-18 23:44
Just a little inconsistency:
in hmsFirewallBan.ps1 you create table hm_fwban and in EventHandlers.vbs you add to table hm_FWBan
Edit: also, there is no field countrycode
Re: Firewall Ban
Post by palinka » 2020-01-18 23:59
Countrycode is a remnant. That should be removed, I guess... :oops:
Post your errors here and I'll walk through the fixes. At one point, I thought I had it all fixed, but I keep changing my own installation. :D
Re: Firewall Ban
Post by palinka » 2020-01-19 00:07
I just looked on GitHub.
'	Function FWBan - http://hmailserver.com/forum/viewtopic.php?f=9&t=34082
Function FWBan(sIPAddress, sReason, sHELO)
   Include("C:\Program Files (x86)\hMailServer\Events\VbsJson.vbs")
   Dim ReturnCode, Json, oGeoip, oXML
   Set Json = New VbsJson
   On Error Resume Next
   Set oXML = CreateObject ("Msxml2.XMLHTTP.3.0")
   oXML.Open "GET", "http://ip-api.com/json/" & sIPAddress, False
   oXML.Send
   Set oGeoip = Json.Decode(oXML.responseText)
   ReturnCode = oXML.Status
   On Error Goto 0
   strSQL = "INSERT INTO hm_FWBan (timestamp,ipaddress,ban_reason,countrycode,country,helo,flag) VALUES (NOW(),'" & sIPAddress & "','" & sReason & "','" & oGeoip("countryCode") & "','" & oGeoip("country") & "','" & sHELO & "','4');"
   Call oDB.ExecuteSQL(strSQL)
Yes, you are 100% correct about country code - NOT present in hmsFirewallBan.ps1 table create. The powershell is correct. In eventhandlers.vbs, change "strSQL" above to:
   strSQL = "INSERT INTO hm_FWBan (timestamp,ipaddress,ban_reason,country,helo,flag) VALUES (NOW(),'" & sIPAddress & "','" & sReason & "','" & oGeoip("country") & "','" & sHELO & "','4');"
Also, you're right about hm_fwban vs hm_FWBan, although I don't think it makes any difference on windows, which generally doesn't care about capital vs lowercase letters. I will change it, though.
Re: Firewall Ban
Post by palinka » 2020-01-21 00:14
Big time changes.
* Added PTR as a database column.
* Added column "rulename" to keep track of which firewall rules contain which IPs. This is important because...
* … Added a method of preventing consolidated rules from containing more than 400 IPs, which could cause trouble with firewall creation, among other things, on very busy servers.
* Removed all references to Powershell NetFirewallRule cmdlet for compatibility reasons - the Firewall Ban project should work on older windows systems now. Now firewall is controlled by Netsh.
Re: Firewall Ban
Post by palinka » 2020-02-01 15:25
Funny helo by script kiddie trying to send spam or guess a password.
And of course there is no PTR....
Re: Firewall Ban
Post by palinka » 2020-02-02 04:14
I updated GitHub today. Before, I had a method of manually adding or releasing IP ranges but it was "fake", meaning it only worked for /24 CIDR ranges and ignored any previously added or released IPs. Banned IP ranges were added as firewall rules using x.x.x.0/24 remote IP. That meant that they could only be removed exactly the same way. Therefore there was no control over individual IPs within the range.
Now it works with real CIDR ranges for both adding and releasing IPs. You can only add or release /22 - /32 ranges - a maximum of 1024 IP addresses at a time.
For CIDR ban:
* Looks for previously banned entries within the range - ignores them because they're already banned
* Looks for released IPs within the range - updates them to banned and adds firewall rule
* Looks for IPs marked safe - ignores them (no change to safe status)
* All other IPs within the range (any not found in the database) get banned and adds firewall rules for them
For CIDR release:
* Looks for banned IPs within the range and releases them, removes firewall rules
* Ignores IPs within the range that are already released or marked safe
* No need to deal with IPs not found in database
When banning a range, IP entries in the database and the firewall are made individually. Therefore you can also release them individually if, for example, you learn one former spammer has turned his back on his evil ways. Or, you learn that you accidentally banned all of facebook's messaging servers - you can release them en masse.
Anyway, a useful feature, I think. Plus the entire operation occurs at the PHP admin, so no changes were required for the powershell part of things.
Re: Firewall Ban
Post by palinka » 2020-02-21 02:11
Latest updates:
* MSSQL support
* Added IP map (works great on mobile too!)
* Added new table for fast queries of certain firewall blocks data - old table queries become slow with several hundred thousand rows. I'm working on a solution to kill off that table altogether, but for now, the web admin is much speedier in general.
* Many bugfixes
Demo - http://hmsfirewallbandemo.ddns.net/
Files - https://github.com/palinkas-jo-reggelt/ ... rewall-Ban
Re: Firewall Ban
Post by palinka » 2020-02-25 22:46
I added these dial guages to the web admin. They show today's results for how many IPs were added, how many IPs were dropped at the firewall, and how many total connections were dropped at the firewall.
The yellow zone represents 75% - 100% of the highest number of hits in a single day, so it's subject to change over time.
The red zone is 100% - 120%. If you're in the red zone, you're breaking a daily record.
Re: Firewall Ban
Post by palinka » 2020-03-12 02:51
Fixed an annoying but minor bug. First connection to MySQL often failed with this error:
20/03/11 18:52:32.16 : ERROR : Unable to run query : SELECT ipaddress, id, DATE(timestamp) AS dateip FROM hm_fwban WHERE flag=5
Exception calling "Open" with "0" argument(s): "Authentication to host '127.0.0.1' for user 'hmailserver' using method 'mysql_native_password' failed with message: Reading from the stream has failed."[0]
Sometimes the error has to do with connecting with anonymous password, which is obviously not the case - password is indeed required.
This is random and only affects the very first query when the script is called on its 5 minute interval. Fortunately, this query rarely produces results anyway, so it didn't affect me much. I finally found the solution here:
http://www.voidcn.com/article/p-phfoefri-bpr.html
What this guy described fits the symptoms perfectly. I hope to never see an error log again.
Re: Firewall Ban
Post by palinka » 2020-03-12 12:33
Hit another milestone: single digit bans. :mrgreen:
Oh, they'll be back with a vengeance soon enough. They come in waves that (I think) coincide with new bot viruses. But the overall trend is still downward.
One thing I've noticed, since I record the helo, is patterns in the helo. They come in waves too.
Re: Firewall Ban
Post by palinka » 2020-04-04 03:21
Hit 20k firewall rules today. Another milestone. :mrgreen:
Technically, I hit 20k remote-IPs banned by this project.
Re: Firewall Ban
Post by palinka » 2020-04-26 14:22
Another milestone. ONE MILLION firewall drops. :mrgreen:
9,380 IPs attempted to connect but were dropped at the firewall a total of 1,010,440 times since July 17th, 2019
