Saving oMessage in OnAcceptMessage to Get MessageID
cblaze22
Post by cblaze22 » 2019-05-07 07:08
I found this in the code base below. The Message ID is not available in the OnAcceptMessage, however if you hit .Save like it shows below, will that assign an ID to the message so we can send it out for delivery right away. PLEASE SOMEONE CONFIRM!
[Test]
      public void TestAddTextDuringSending()
         hMailServer.Account oAccount1 = SingletonProvider<Utilities>.Instance.AddAccount(_domain, "test@test.com", "test");
         // Send a message to the account.
         hMailServer.Message oMessage = new hMailServer.Message();
         Assert.AreEqual(0, oMessage.State);
         hMailServer.Scripting scripting = SingletonProvider<Utilities>.Instance.GetApp().Settings.Scripting;
         string signature = "MySignature";
         string script = "Sub OnAcceptMessage(oClient, oMessage) " + Environment.NewLine +
                               " Call EventLog.Write(\"Subject:\" +oMessage.Subject)" + Environment.NewLine +
                               " Call EventLog.Write(\"Date:\" +oMessage.Date)" + Environment.NewLine +
                               " Call EventLog.Write(\"Body:\" +oMessage.Body)" + Environment.NewLine +
                               " oMessage.Body = oMessage.Body & \"" + signature + "\" " + Environment.NewLine +
                               " oMessage.Save() " + Environment.NewLine +
                          "End Sub"  + Environment.NewLine +  Environment.NewLine;
Re: Saving oMessage in OnAcceptMessage to Get MessageID
Post by SorenR » 2019-05-07 12:33
cblaze22 wrote:
2019-05-07 07:08
[Test]
You cannot force creation of oMessage.ID. The event OnAcceptMessage() is when all of the email (headers, body, attachments etc.) is received - just before your server returns "SENT: 250 Queued (1.609 seconds)" to the originating server. Message is still in memory about to be written to a file on disk. Once the file ([GUID].eml) is created in .\hMailServer\Data a record is created in database for indexing thus the oMessage.ID is created.
So you see, you cannot do anything with oMessage.ID until Sub OnDeliveryStart(oMessage).
cblaze22
Post by cblaze22 » 2019-05-07 13:33
Is there a method that is available, that has the ID, but is called before it goes into the queue or right after it goes in the queue.
My goal is to send the email immediately based on a header instead of say waiting in the queue for a hour to be processed because an important email is backed up.
Post by SorenR » 2019-05-07 15:28
cblaze22 wrote:
2019-05-07 13:33
Nope...
estradis
Post by estradis » 2019-06-07 14:30
2019-05-07 12:33
... Message is still in memory about to be written to a file on disk. ...
Sorry SorenR, but I don't agree!
When the event OnAcceptMessage is fired, the file already exists in Data Directory. This fact is an essential part of our Eventhandler.vbs as we pass the event handling to another (high performant) server and process only the results in EventHandler.vbs. If the file wouldn't exist at this time, our complete scripting wouldn't work. (See anonymized snippet from our trace log before the event was passed to the event server below)
BUT somewhere after OnAcceptMessage the filename (GUID) will change, I guess in that moment it will be copied to the user directory.
[2019.06.03 19:03:22.046]: EventHandlers.vbs: DEBUG: sEventName="OnAcceptMessage"
[2019.06.03 19:03:22.046]: EventHandlers.vbs: DEBUG: oMessage.From=""***** ******" <*****@outside.com>"
[2019.06.03 19:03:22.046]: EventHandlers.vbs: DEBUG: oMessage.FromAddress="*****@outside.com"
[2019.06.03 19:03:22.046]: EventHandlers.vbs: DEBUG: oMessage.Filename="C:\Program Files\hMailServer\Data\{E32586DA-8E04-43A9-822B-24C99AC78EC6}.eml"
[2019.06.03 19:03:22.046]: EventHandlers.vbs: DEBUG: sMsgFileName="C%3A%5CProgram%20Files%5ChMailServer%5CData%5C{E32586DA-8E04-43A9-822B-24C99AC78EC6}.eml"
[2019.06.03 19:03:22.046]: EventHandlers.vbs: DEBUG: sAdressesInHeaders=""john.doe@example.com" john.doe@example.com;jane.doe@example.com"
[2019.06.03 19:03:22.046]: EventHandlers.vbs: DEBUG: oRecipient.Address="john.doe@example.com"
[2019.06.03 19:03:22.046]: EventHandlers.vbs: DEBUG: oRecipient.OriginalAddress="john.doe@example.com"
Post by SorenR » 2019-06-07 15:11
Yes I know ... From a later topic... It think it is a matter of semantic, when the "file is written" I believe it is filed under the specific account on disk, but I have not verified this yet..
https://www.hmailserver.com/forum/viewt ... 78#p212078
I do not remember seing the file changing it's name in the process however.
estradis
Post by estradis » 2019-06-07 15:38
2019-06-07 15:11
I searched several times for the filenames from the trace log, but I could never find the files. The file name will be changed definitively! :roll:
And by the way, I just read my previous post again and should probably work on my semantics myself. Looks like I'm getting out of practice. :?
Post by SorenR » 2019-06-07 17:27
estradis wrote:
2019-06-07 15:38
2019-06-07 15:11
I used: EventLog.Write(oMessage.FileName) as the first line in every trigger using "oMessage", never recorded my findings but IIRC it was the same filename all the way.
I have SAMoveVsCopy=1 in my .INI file, that may play a role ... :?: :mrgreen:
estradis
Post by estradis » 2019-06-11 10:30
2019-06-07 17:27
estradis wrote:
2019-06-07 15:38
2019-06-07 15:11
During the events the filename will be the same as you can see in the trace log from the example above
[2019.06.03 12:57:50.996]: EventHandlers.vbs: DEBUG: sEventName="OnSMTPData"
[2019.06.03 12:57:50.996]: EventHandlers.vbs: DEBUG: oMessage.Filename="C:\Program Files\hMailServer\Data\{2CEB9555-3840-4102-B94C-03D23A94ADB5}.eml"
[2019.06.03 12:57:51.839]: EventHandlers.vbs: DEBUG: sEventName="OnAcceptMessage"
[2019.06.03 12:57:51.839]: EventHandlers.vbs: DEBUG: oMessage.Filename="C:\Program Files\hMailServer\Data\{2CEB9555-3840-4102-B94C-03D23A94ADB5}.eml"
But as I wrote above
estradis wrote:
2019-06-07 14:30
... somewhere after OnAcceptMessage the filename (GUID) will change ...
Unfortunatly we currently don't trace OnDeliveryStart Messages, so I cannot say what the filename is in that event.
I also don't believe that SAMoveVsCopy=1 plays a role because SA will be processed between OnSMTPData and OnAcceptMessage, but the filename is not changed when the second event is fired.
By the way is that an official but undocumentated setting?
Post by jimimaseye » 2019-06-11 14:13
estradis wrote:
2019-06-11 10:30
https://www.hmailserver.com/forum/viewt ... 10&t=30900
estradis
Post by estradis » 2019-06-12 10:04
Thank you for sharing the link. :D
(Just a mind: Maybe you want to add the link to your personal signature as well?)
