VBScript Regex to Grab Status Code and Test If 500 or higher.
cblaze22
Post by cblaze22 » 2019-05-06 03:09
I need a VBScript to Grab Status Code and Test If 500 or higher. I can do this in .NET no problem but VBScript syntax is a little harder for me. The pattern is below but how would i test the string below to grab the 421, then do an IF statement on it (statusCode >= 500)?
^.*Remote server replied: (?<statuscode>\d*).*$
"Error Type: SMTP[nl] Remote server (35.173.65.153) issued an error.[nl] hMailServer sent: [nl] Remote server replied: 421 spr-ibgw-5001a.stratus.cloudmark.com cmsmtp SMTP server not available AUP#1330[nl]"
Re: VBScript Regex to Grab Status Code and Test If 500 or higher.
Post by SorenR » 2019-05-06 14:06
cblaze22 wrote:
2019-05-06 03:09
VBScript RegEx is based on ECMAScript syntax... hMailServer Rule Regex is based on PCRE syntax... Welcome to the brotherhood ;-)
I believe this should do it. Working with Non-capturing Groups in VBScript is not plain logic :mrgreen:
It's my first go at the Non-capturing Group thing and I would not be surprised if I can cook this down even further when I get more time.
Sub OnDeliveryFailed(oMessage, sRecipient, sErrorMessage)
   Dim regex, matches, match, strResult
   Set regex = New RegExp
   regex.IgnoreCase = True
   regex.Pattern = "^(?:.*Remote server replied:\s)([0-9]{3})(?:\s.*)$"
   Set matches = regex.Execute(sErrorMessage)
   If matches.Count >= 1 Then
      Set match = matches(0)
      If match.SubMatches.Count >= 1 Then
         strResult = match.SubMatches(0)
         strResult = ""
      strResult = ""
   EventLog.Write( "strResult: " & strResult & vbTab & " sRecipient: " & sRecipient )
   Set match = Nothing
   Set matches = Nothing
   Set regex = Nothing
cblaze22
Post by cblaze22 » 2019-05-06 14:40
Thanks but is the strResult an integer where I can do
IF strResult  >= 500
' run code
END IF
cblaze22
Post by cblaze22 » 2019-05-06 15:37
I assume this will work
	Dim regex, matches, match, strResult, valInt
         	strResult = ""
      		strResult = ""
	If Not IsEmpty(strResult) Then
            If IsNumeric(valString) Then
                valInt = CInt(valString)
		If valInt >= 500 Then
			' call http
Post by SorenR » 2019-05-06 16:38
   Dim regex, matches, match, strResult, sURL
         strResult = ""
         exit sub ' nothing we can do here...
      strResult = ""
   If IsNumeric(strResult) And CInt(strResult) > 499 Then
      sURL = "http://www.test.com/index.htm?retcode=" & CInt(strResult) & "&recipient= " & sRecipient
      On Error Resume Next
      With CreateObject("MSXML2.ServerXMLHTTP.6.0")
         .setoption(2) = (.getoption(2) & " - SXH_SERVER_CERT_IGNORE_ALL_SERVER_ERRORS")
         .open "GET", sURL, False
         .setrequestheader "User-Agent", "hMailServer EventHandlers.vbs"
         .send ("")
      On Error Goto 0
   Set match = Nothing
   Set regex = Nothing
cblaze22
Post by cblaze22 » 2019-05-07 05:14
Not working
3544 "2019-05-06 23:09:51.609" "Running"
3544 "2019-05-06 23:09:51.609" "Error Type: SMTP[nl] Remote server (166.216.149.129) issued an error.[nl] hMailServer sent: RCPT TO:<8583390609@txt.att.net>[nl] Remote server replied: 550 5.1.1 <8583390609@txt.att.net> recipient does not exist here.[nl]"
3544 "2019-05-06 23:09:51.609" "No Match"
	EventLog.Write("Running")
	EventLog.Write(sErrorMessage)
   	regex.Pattern = "^(?:.*Remote server replied:\s)([0-9]{3})(?:.*)$"
			EventLog.Write(strResult)
EventLog.Write("NO SUBMATCHES")
         		strResult = ""
         		exit sub
EventLog.Write("No Match")
      		strResult = ""
      		exit sub
	If IsNumeric(strResult) And CInt(strResult) >= 500 Then
      		With CreateObject("MSXML2.ServerXMLHTTP")
               		.open "GET", "https://test.com/subscriptions/bounce?email=" + sRecipient + "&statuscode=" + strResult + "&message=" + sErrorMessage, False
               		.setrequestheader "User-Agent", "Test SMTP"
               		.send ("")
      		On Error Goto 0
   	Set match = Nothing
   	Set regex = Nothing
cblaze22
Post by cblaze22 » 2019-05-07 06:54
Missing
regex.MultiLine = True
Post by SorenR » 2019-05-07 10:58
cblaze22 wrote:
2019-05-07 06:54
Missing
of course it does... sorry.
fatman45
Post by fatman45 » 2019-06-11 00:15
Your code could be shortened like this using a capture group.
If regex.Test(sErrorMessage) Then
	valInt = CInt(regex.Replace(sErrorMessage, "$2"))
glenluo
Post by glenluo » 2019-09-06 07:38
Getting the error code is so easy,just one line enough:
Left(Split(sErrorMessage,"Remote server replied: ")(1),3)
