VBScript formatting date/time
Post by SorenR » 2019-04-25 02:02
Function sprintf(sFmt, aData)
   Dim g_oSB
   Set g_oSB = CreateObject("System.Text.StringBuilder")
   g_oSB.AppendFormat_4 sFmt, (aData)
   sprintf = g_oSB.ToString()
   g_oSB.Length = 0
   Set g_oSB = Nothing
WScript.Echo "sprintf 24H format =>", sprintf( "{0:yyyy-MM-dd HH:mm:ss}", Array(Date()))
WScript.Echo "sprintf 12H format =>", sprintf( "{0:yyyy-MM-dd h:mm:ss tt}", Array(Date()))
NOTE: I have not been able to get the 12H AM PM thingy (tt) to work but that could be due to my Windows being Danish, time WILL show as 12 hour format without actually printing "AM" or "PM" ... :roll:
sprintf 24H format => 2019-04-25 00:00:00
sprintf 12H format => 2019-04-25 12:00:00
Re: VBScript formatting date/time
Post by jimimaseye » 2019-04-25 08:51
2019-04-25 02:02
I think youre right. Isnt it only English that does AM,PM? I thought the rest of the world more or less operates a 24hr clock and only the awkward english speakers do it differently. :mrgreen:
estradis
Post by estradis » 2019-04-25 10:22
Our idea was to create a converted array from a datetime value and prepare the results in a way we need it in the scripts. Once the array was created, it is easy to build the necessary strings.
Function GetTimeArray(ts, iDecimals)
	Dim a(6), n, iSeconds, iMilliseconds
	If iDecimals < 0 Then iDecimals = 0
	If iDecimals > 8 Then iDecimals = 8
	n = "00000000"	' <= Leading zeros for array strings
	' Workaround for milliseconds (VBScript doesn't know any function for milliseconds!)
	iSeconds = (Hour(ts) * 3600) + (Minute(ts) * 60) + Second(ts)
	iMilliseconds = Timer() - iSeconds
	iMilliseconds = Fix(iMilliseconds * 10 ^ iDecimals)
	' As we need only strings, we convert the values here and prepend leading zeroes
	' (This increases performance dramatically!)
	a(0) = Right(n & CStr(Year(ts)), 4)
	a(1) = Right(n & CStr(Month(ts)), 2)
	a(2) = Right(n & CStr(Day(ts)), 2)
	a(3) = Right(n & CStr(Hour(ts)), 2)
	a(4) = Right(n & CStr(Minute(ts)), 2)
	a(5) = Right(n & CStr(Second(ts)), 2)
	a(6) = Right(n & CStr(iMilliseconds), iDecimals)
	GetTimeArray = a
Ok, there is no "am"/"pm" in this array, but it shouldn't be that hard to implement it if needed.
Post by SorenR » 2019-04-25 14:37
estradis wrote:
2019-04-25 10:22
	GetTimeArray = a
Like this ?
   With CreateObject("System.Text.StringBuilder")
      sprintf = .ToString()
      .Length = 0
Dim CurrTime  : CurrTime = Now()
Dim Elapsed   : Elapsed = Timer()
Dim MilliSecs : MilliSecs = Right("000" & Int((Elapsed - Int(Elapsed)) * 1000), 3)
WScript.Echo "sprintf 24H format #3  =>", sprintf( "{0:yyyy/MM/dd HH:mm:ss}", Array(CurrTime)) & "." & MilliSecs
:mrgreen:
estradis
Post by estradis » 2019-04-26 01:07
2019-04-25 14:37
--snip--
Like this ?
--snip--
:mrgreen:
:| OOPS, missunderstood!
What I ment was, that the array is created only once and then reused in multiple functions with different formattings. As the string will be built from the parts only by concatenating, the performance increased.
But yes, you're right. Your function results the same.
:lol:
