OnAcceptMessage and temporary fail
amokkaths
Post by amokkaths » 2015-12-09 00:35
Hello.
I do some check in my OnAcceptMessage.
The result of this check relies on remote system, so if that system is not available, check can not be done, function can't say if it should permit or deny the message. In this situation answering with "temporary fail" is right solution.
Is there a way to answer with 4xx temporary error from OnAcceptMessage?
Should I post a feature request?
Re: OnAcceptMessage and temporary fail
Post by jimimaseye » 2015-12-09 01:12
There is no way. It's either an accept or 5xx.
https://www.hmailserver.com/documentati ... eptmessage
