Reading oMessage-ID in OnAcceptMessage-Event
DataMaster
Post by DataMaster » 2015-04-14 17:41
I hope you can help me.
I am trying to use oMessage.ID in my "OnAcceptMessage"-Event.
I want to change a database entry based on the message ID.
But the ID is always 0. Is the ID not set yet?
I only write into a text file to show my output :)
If you have a better idea how I can "debug" my script, pklease let me know :P
		Set objFSO=CreateObject("Scripting.FileSystemObject")
		' write file
		outFile="c:\test\scriptoutput.txt"
		Set objFile = objFSO.CreateTextFile(outFile,True)
		objFile.WriteLine("ID: " & CStr(oMessage.ID) & " END" & vbCrLf)
		objFile.Close
Re: Reading oMessage-ID in OnAcceptMessage-Event
Post by mattg » 2015-04-14 18:34
https://www.hmailserver.com/documentati ... eptmessage
Notes
OnAcceptMessage is executed before hMailServer has accepted the email message and before it has been saved in the database. This means that you cannot access the ID of the message in this event.
Post by SorenR » 2015-04-14 19:25
OnDeliveryStart should be fine, the message is saved (.ID exists) and it's before Anti-Virus checks and before Global Rules are run.
I run my Custom Logger at "Sub OnDeliverMessage(oMessage)". No messages are moved between IMAPFolders yet even though a Global Rule says so... But that's another story :mrgreen:
cblaze22
Post by cblaze22 » 2019-05-07 07:02
Can you call .Save in the OnAcceptMessage to get the ID?
