Why script didn't work?
mns17
Post by mns17 » 2010-06-07 09:14
subject include russian simbol!!!
script:
Sub OnSubjectov(oMessage)
EventLog.write("Subject befor - " & oMessage.Subject)
oMessage.Subject = "[ov] " & oMessage.Subject
EventLog.write("Subject after - " & oMessage.Subject)
Result:
4900 "2010-06-07 14:02:46.487" "Subject befor - Калмыкову Ивану - пример "технического решения" [Fwd: ТР версии 1.2]"
4900 "2010-06-07 14:02:46.488" "Subject after - [ov] "
4900 "2010-06-07 14:08:08.924" "Subject befor - абвгде"
4900 "2010-06-07 14:08:08.924" "Subject after - [ov] "
4900 "2010-06-07 14:14:09.673" "Subject befor - test"
4900 "2010-06-07 14:14:09.674" "Subject after - [ov] test"
Re: Why script didn't work?
Post by ^DooM^ » 2010-06-07 09:24
What version of hMail are you using?
mns17
Post by mns17 » 2010-06-07 09:51
5.3.2-B1769
Post by martin » 2010-06-07 18:14
If you disable the script, send another message with the same content, locate the .EML file, zip the EML file and send it to me at martin@hmailserver.com I can see if I can reproduce it.
mns17
Post by mns17 » 2010-06-08 04:14
Martin, i send e-mail to you with zip
Post by martin » 2010-06-08 22:27
I've found the problem. It occurs if you try to modify the subject of a message with no message-wide character set. The issue will be fixed in 5.4 (a beta will be available within a week).
I don't know russian. Is the Subject of the message you sent me confidential, or can I add this subject to the automated test suit for hMailServer (which is public)? (I've removed the From-address, To-address and every other field except for the subject line).
mns17
Post by mns17 » 2010-06-09 04:20
Thank, martin.
New Subject on russian for your automatic test:
"Это тестовая тема письма для проверки работы севрера с русскими символами"
Post by martin » 2010-06-18 18:08
Thanks.
Let me know if you want to test 5.4. It's not really ready to be used in production but if you have something specific which you want to test in a test tenvironment, just let me know.
Post by Bill48105 » 2010-06-18 19:05
Did I hear 5.4?!? Got my testbed all ready! :D
