Alternate SM Mod
cgountanis
Post by cgountanis » 2005-07-26 03:35
i got new download and made website. i can see the login but no one is able to log in. is there some setup that needs to be done to make this work?
php5 win2ksp4
TheAngryPenguin
Post by TheAngryPenguin » 2005-07-26 03:40
/config/config.php -- line 110 needs to be changed.
cgountanis
Post by cgountanis » 2005-07-26 03:42
is there a way to make one site for all domains in hamailserver automatically? i want all my users to be able to use this and just login normally.
using name@domain.com and password is ok just like IMail
i get error:
ERROR
You must be logged in to access this page.
Go to the login page
nocloud
Post by nocloud » 2005-07-26 03:46
i have an older version of squirrelmail modded for hmailserver.
the version i have is:
SQUIRRELMAIL FOR HMAILSERVER MOD 0.1
Last updated
5:36 PM 6/10/2004
This is a modded version of Squirrelmail 1.4.3a compiled and configured by
Patrick Reardon.
i want to upgrade to the latest version. can anybody tell me how to upgrade and whether i can use the same config file
TheAngryPenguin
Post by TheAngryPenguin » 2005-07-26 03:51
cgountanis wrote:is there a way to make one site for all domains in hamailserver automatically? i want all my users to be able to use this and just login normally.
i get error:
ERROR
AFAIK, SM should handle multiple domains fine as long as it's configured correctly. Have you modified line 110 in /config/config.php yet?
The only place where this might be an issue is with:
/*** Server Settings ***/
 * Default Domain
 * The domain part of local email addresses.
 *   This is for all messages sent out from this server.
 *   Reply address is generated by $username@$domain
 * Example: In bob@example.com, example.com is the domain.
 * @global string $domain
$domain = 'yourdomain.com';
Maybe someone else who uses SM for multiple domains can comment on this...
TheAngryPenguin
Post by TheAngryPenguin » 2005-07-26 03:56
nocloud wrote:i have an older version of squirrelmail modded for hmailserver.
Last updated
5:36 PM 6/10/2004
Patrick Reardon.
  • * Backup your existing SM install
    * Extract the new on top of the old
    * Restore /config/config.php
config.php hasn't changed that much in the last few versions of SM, so you should be okay. If not, that's what backups are for, right? ;)
cgountanis
Post by cgountanis » 2005-07-26 06:24
Yes I changed line 110 to the same thing hMail using for SMTP host. Trie logging on as someone fromt hat domain and others. I get not user and password incorrect but this.
ERROR
TheAngryPenguin
Post by TheAngryPenguin » 2005-07-26 06:29
Are you runing this script on the same physical host as your hMailServer?
cgountanis
Post by cgountanis » 2005-07-26 06:32
I tried a users domain nothing and the one that I use in hMail as SMTP host name. Still same error. Thanks for the promt responses. I would love to get this working globally with one installation.
FAWTS
Post by FAWTS » 2005-07-26 16:17
In MailHerver, in ip range, for 127.0.0.1, do you ask for an authentification ?
It is strange, because if your login were wrong, you should have that :
ERROR
Unknown user or password incorrect.
Does your navigator accept cookie ? If no, it must accept them. It can come from you firewall or your anti spyware too.
cgountanis
Post by cgountanis » 2005-07-26 16:54
i did make hmailserver only use one ip My Computer but all the check boxes are default. pop3 and smtp with auth work fine.
cgountanis
Post by cgountanis » 2005-07-27 21:10
so this doesnt work with hmailserver's running on ms sql server? i use ms sql becasue helm runs on that as well.
cgountanis
Post by cgountanis » 2005-07-28 01:28
I tried again. Now I got the user info screen hbut the left frame was empty. PHP5 then after trying to send email I got You need to be logged in and could not get back in? Any clue?
It did send the email too! Now when I login I get left and right frame but in right frame i get need to be logged in error?
FAWTS
Post by FAWTS » 2005-07-28 10:16
When you write "1 IP, mine", you mean 127.0.0.1 or 192.168.*.* or you're true IP?
you need at least the 127.0.0.1. For me, all the servers (pop, smtp and imap) are checked, with no authentification required and the last 4 checkbox are checked.
You need to have "the internet" to. I allow only smtp and pop, but you can check imap if you want. Then, I require authentification only to extrenal account, but no authentification is required to local accounts (otherwise you can't receive mail from external account).
Then I allow reception only for local to local, local to external and external to local.
Extern to extern is not checked.
Using PHP5 can be a problem too, try with PHP4.4 or PHP 4.3.11 (but not PHP 4.3.10 otherwise PHPwebAdmin won't work).
About MsSQL, I don't think it has something to do with Squirellmail as it doesn't use it.
cgountanis
Post by cgountanis » 2005-07-28 20:03
Can you clean your post up. Two areas to download a grey that you can hardly read. Then maybe have a how to with the basics for us dumb ass people.
cgountanis
Post by cgountanis » 2005-07-28 20:50
OK installed PHP 4.4 over 5 and checked my IMAP and IP settings. I can login one time left menu NEVER FREAKING shows up why? Then after I enter my user info I get error:
ERROR
after just being logged in to enter the info like email address sig page.
do you have to do anything special with php.ini or iis? seems like it loses password but either way never brings up left menu...
cgountanis
Post by cgountanis » 2005-07-28 20:59
Seems like it works on the hMailserver with these logs:
"IMAPD" 3288 "2005-07-28 13:57:05.593" "127.0.0.1" "SENT: A001 OK LOGIN completed[nl]"
"IMAPD" 3288 "2005-07-28 13:57:05.609" "127.0.0.1" "RECEIVED: A002 CAPABILITY"
"IMAPD" 3288 "2005-07-28 13:57:05.609" "127.0.0.1" "SENT: * CAPABILITY IMAP4 IMAP4rev1 QUOTA[nl]A002 OK CAPABILITY completed[nl]"
"IMAPD" 3288 "2005-07-28 13:57:05.609" "127.0.0.1" "RECEIVED: . LIST "INBOX" """
"IMAPD" 3288 "2005-07-28 13:57:05.609" "127.0.0.1" "SENT: * LIST (/NoSelect) "." ""[nl]"
"IMAPD" 3288 "2005-07-28 13:57:05.609" "127.0.0.1" "SENT: . OK LIST completed[nl]"
"IMAPD" 3288 "2005-07-28 13:57:05.609" "127.0.0.1" "RECEIVED: A003 LOGOUT"
"IMAPD" 3288 "2005-07-28 13:57:05.609" "127.0.0.1" "SENT: * BYE Have a nice day[nl]A003 OK Logout completed[nl]"
but left frame empty always ?
cgountanis
Post by cgountanis » 2005-07-28 21:19
Have you tried this on a Windows 2000 server has anyone?
Warning: Cannot modify header information - headers already sent by (output started at C:\WebMail\wwwroot\functions\page_header.php:32) in C:\WebMail\wwwroot\functions\global.php on line 306 in right frame just clicking around but left still blank.
I did get this on first login seems like error to me?
"IMAPD" 3288 "2005-07-28 14:25:53.093" "127.0.0.1" "RECEIVED: A001 LOGIN "cgountanis@DOMAIN.COM" "mypasswordhere""
"IMAPD" 3288 "2005-07-28 14:25:53.093" "127.0.0.1" "SENT: A001 OK LOGIN completed[nl]"
"IMAPD" 3288 "2005-07-28 14:25:53.093" "127.0.0.1" "RECEIVED: A002 CAPABILITY"
"IMAPD" 3288 "2005-07-28 14:25:53.093" "127.0.0.1" "SENT: * CAPABILITY IMAP4 IMAP4rev1 QUOTA[nl]A002 OK CAPABILITY completed[nl]"
"IMAPD" 3288 "2005-07-28 14:25:53.093" "127.0.0.1" "RECEIVED: . LIST "INBOX" """
"IMAPD" 3288 "2005-07-28 14:25:53.093" "127.0.0.1" "SENT: * LIST (/NoSelect) "." ""[nl]"
"IMAPD" 3288 "2005-07-28 14:25:53.093" "127.0.0.1" "SENT: . OK LIST completed[nl]"
"IMAPD" 3288 "2005-07-28 14:25:53.093" "127.0.0.1" "RECEIVED: A003 LOGOUT"
"IMAPD" 3288 "2005-07-28 14:25:53.093" "127.0.0.1" "SENT: * BYE Have a nice day[nl]A003 OK Logout completed[nl]"
"IMAPD" 1652 "2005-07-28 14:25:53.640" "127.0.0.1" "RECEIVED: A001 LOGIN "cgountanis@DOMAIN.COM" """
"IMAPD" 1652 "2005-07-28 14:25:53.640" "127.0.0.1" "SENT: A001 NO Invalid user name or password.[nl]"
Paul_Nerds
I have errors.
Post by Paul_Nerds » 2005-07-29 04:25
Hi
Just noticed I posted this in the wrong place. So I copied it here.
Hi
I am a newbie to PHP and hMailServer and Squirrelmail. Probably not a good combination. I seem to have everything mostly running.
In the SM I get the following errors.
On all pages just below the menu:
Notice: Undefined index: REQUEST_URI in E:\Inetpub\websites\BusinessStop.com\hms_squirrelmail\plugins\timeout_user\functions.php on line 109
Notice: Undefined offset: 1 in E:\Inetpub\websites\BusinessStop.com\hms_squirrelmail\plugins\timeout_user\functions.php on line 110
On the folders page:
Notice: Undefined offset: 0 in E:\Inetpub\websites\BusinessStop.com\hms_squirrelmail\plugins\folder_sizes\setup.php on line 307
Notice: Undefined offset: 0 in E:\Inetpub\websites\BusinessStop.com\hms_squirrelmail\plugins\folder_sizes\setup.php on line 308
Notice: Undefined offset: 0 in E:\Inetpub\websites\BusinessStop.com\hms_squirrelmail\plugins\folder_sizes\setup.php on line 309
Notice: Undefined offset: 0 in E:\Inetpub\websites\BusinessStop.com\hms_squirrelmail\plugins\folder_sizes\setup.php on line 310
Deleted Items 0 0 0 k
Drafts 0 0 0 k
Sent Items 0 0 0 k
4 Folders 0 0 0 k
Notice: Undefined offset: -1 in E:\Inetpub\websites\BusinessStop.com\hms_squirrelmail\plugins\folder_sizes\setup.php on line 138
Notice: Undefined offset: -1 in E:\Inetpub\websites\BusinessStop.com\hms_squirrelmail\plugins\folder_sizes\setup.php on line 139
Notice: Undefined offset: -1 in E:\Inetpub\websites\BusinessStop.com\hms_squirrelmail\plugins\folder_sizes\setup.php on line 140
Notice: Undefined offset: -1 in E:\Inetpub\websites\BusinessStop.com\hms_squirrelmail\plugins\folder_sizes\setup.php on line 141
I suspect I just need to authorize something on the server.
Windows 2003, PHP 5, hMailServer 4.125, this SM.
Thanks for creating this it is great.
Paul
cmurphy54
Post by cmurphy54 » 2005-07-29 05:28
You both need to turn off notices in php.ini.
http://www.hmailserver.com/forum/viewto ... ices#13353
cgountanis
Post by cgountanis » 2005-07-29 05:39
php.ini in winnt windows folder tweak easy plus i went to site make index.php a default document in iis so it comes up on its one without /index.php in url
TheAngryPenguin
Post by TheAngryPenguin » 2005-07-29 05:41
Um, okay. :shock:
cgountanis
Post by cgountanis » 2005-07-29 05:47
BTW I fixed my problem from a redirect change found here: http://www.hmailserver.com/forum/viewto ... 3645#13645
TheAngryPenguin
Post by TheAngryPenguin » 2005-07-29 05:49
cgountanis wrote:Can you clean your post up. Two areas to download a grey that you can hardly read. Then maybe have a how to with the basics for us dumb ass people.
Not sure what you find so dirty about the OP. We cannot strikethrough text in phpBB, so I chose to make the color of text less important. If you're really interested in the this modded script, you really should read through everything in the OP; and the (updated) download links still remain listed in the first sentence.
cgountanis
Post by cgountanis » 2005-07-29 06:05
thanks either way man
chaikw
Post by chaikw » 2005-08-02 03:46
Hi TheAngryPenguin,
For the hms_squirrelmail\plugins\squirrelspell\sqspell_interface.php, our programmer found out that when the aspell return suggestion array:
suggestions[0] = "teats, test, tents, tests, texts, tats, tits, tots, tuts, stets, Tess, teas, tees, bets, gets, jets, lets, mets, nets, pets, sets, tels, tens, vets, wets, totes, tarts, teat's, torts
the "; is in next new line rather than end of the array it should be :?:
suggestions[0] = "teats, test, tents, tests, texts, tats, tits, tots, tuts, stets, Tess, teas, tees, bets, gets, jets, lets, mets, nets, pets, sets, tels, tens, vets, wets, totes, tarts, teat's, torts";
I use the linux box to perform spell check and it return the second array with no error come out :shock:
Do you know which file and which line to modify it?
Thanks.
Regards,
Chai Kam Weng
CoaxServices
Post by CoaxServices » 2005-08-10 02:09
I cant change the password. I have HMailServer 4.
Please help me.
Post by martin » 2005-08-10 02:13
What happens when you try to change the password?
Does your computer blow up? If so, it may be some kind of electrical problem.
cgountanis
Post by cgountanis » 2005-08-10 04:04
I think it is the same PHP redirect issue. I had to remove because I didnt feel like recoding every little bug. Why does PHP 5 redirect not work on Windows?
johnmandre
Errors Logging In
Post by johnmandre » 2005-08-11 04:54
Background: I'm moving my mail from one server to another. I got the hms issues all worked out and I can connect to the new server just fine (with Thunderbird).
However, when I try this hms_squirrelmail I got some errors. I went through conf.pl (after installing activeperl) but still getting some errors.
Now, after entering user/pass, /src/redirect.php is throwing some errors:
Warning: touch(): Utime failed: Permission denied in C:\WebSites\hms_squirrelmail\plugins\login_alias\functions.php on line 73
Warning: Cannot modify header information - headers already sent by (output started at C:\WebSites\hms_squirrelmail\plugins\login_alias\functions.php:73) in C:\WebSites\hms_squirrelmail\src\redirect.php on line 101
Warning: Cannot modify header information - headers already sent by (output started at C:\WebSites\hms_squirrelmail\plugins\login_alias\functions.php:73) in C:\WebSites\hms_squirrelmail\src\redirect.php on line 169
Any ideas? I searched around but didn't find much help.
All insights welcome.
johnmandre
Post by johnmandre » 2005-08-11 05:54
I should have added, I'm using Windows Server 2003, IIS, IE 6, PHP 4.3.11, the latest activeperl.
nuvus
Post by nuvus » 2005-08-11 15:03
martin wrote:What happens when you try to change the password?
CoaxServices wrote:I cant change the password. I have HMailServer 4.
Please help me.
Martin,
I'm having the same problem with SquirrelMail
I cant change password (HMailServer 4 -on W2003 )
no error .. only return page blank
Why is this happening?
Post by martin » 2005-08-11 15:19
Can you try this?
cmurphy54 wrote: From the windows Control Panel, go to Administrative Tools
Open up Component Services
Expand Component Services folder
Expand down to Computers | My Computer | DCOM Config
Right click on hMailServer and select properties
Select Security tab
Under Launch and Activation Permissions, Select Customize and click edit
Make sure your anonymous IIS user has Local Lauch and Local Activation permissions set to Allow.
johnmandre
Post by johnmandre » 2005-08-12 00:06
martin wrote:Can you try this?
Select Security tab
I tried it. Nothing changed. :(
CoaxServices
Post by CoaxServices » 2005-08-13 02:04
Select Security tab
This change the Password but not redirect page. only show a white page.
johnmandre
Insights
Post by johnmandre » 2005-08-13 06:56
OK, I had an idea. On my old server I used the normal squirrelmail but on my new server I used the hms mod.
I put the hms mod on my old server (where the old squirrelmail works fine) and the hms mod fails with the same falure as listed above. :(
I then put the regular squirrelmail installation on my new server and...it worked just fine. :)
So, it's nothing with the hms config, it must be something with the hms mod'ed version of squirrelmail.
What, oh what could it be? I'd love to use the new version. Anyone have any thoughts?
TheAngryPenguin
Re: Insights
Post by TheAngryPenguin » 2005-08-13 07:08
johnmandre wrote:What, oh what could it be? I'd love to use the new version. Anyone have any thoughts?
I really haven't a clue. I cannot reproduce this, and the new version has been built exactly as the old was, so I am surprised to hear of any problems. I would be highly suspicious of your server config -- this script runs perfectly fine on linux boxes. Has anything changed recently, like your versions and/or configurations of Apache and/or PHP?
kindredx
SM Mod Amin
Post by kindredx » 2005-08-30 03:31
Great work on this SM mod. I have just recently installed it and it works and looks great. I am kinda new to PHP, so my question is about the admin account. How do I create one, or login to the current admin account to modify some of the options in the SM Mod.
Thanks,
Kindredx
TheAngryPenguin
Re: SM Mod Amin
Post by TheAngryPenguin » 2005-09-07 17:38
kindredx wrote:Great work on this SM mod. I have just recently installed it and it works and looks great. I am kinda new to PHP, so my question is about the admin account. How do I create one, or login to the current admin account to modify some of the options in the SM Mod.
Thanks,
Kindredx
../plugins/administrator/INSTALL wrote:An alternative method, but less secure, is to add a file called
admins into the plugin folder with the names of the users that
you want to allow the use of the plugin.
Use this plugin at your own risk, and always remember to make a
backup of your config.php file before use.
I have never actually used this plugin. A while back, someone posted the same question and was able to get it to work with the above quoted information. Unfortunately, I cannot find that particular post.
chaikw
Time mis-match on webmail
Post by chaikw » 2005-09-08 10:10
Hi TheAngryPenguin,
I'm using Windows 2003 server with apache 2.0.54, php5.0.4, hMailServer 4.1 Biuld 136 and the SM mail from you.
All working fine on testing environment (LAN). When I try it out on WAN, the time on left side panel change. My Server system time is 4.19pm, 8 Sep 05 but the left panel show 8.16am, 8 Thursday.
And I not getting any email.
Any ideas?
Thanks.
Chai
Regards,
Chai Kam Weng
chaikw
error on auto reply
Post by chaikw » 2005-09-09 06:15
I tested the on-read auto reply function on SM. When I read the mail and it prompt for auto reply.
When I click yes, I get the following error message on top of the page:
ERROR:
Requested action not taken: mailbox unavailable
Server replied: 550 sender address must be specified.
I sure the sender mailbox is OK cause I can sent and receive mail.
Any ideas?
Thanks.
Regards,
Chai Kam Weng
dlong
New Install: Fatal error: Only variables can be passed by re
Post by dlong » 2005-09-17 20:57
IGNORE. SORRY. BRAIN FREEZE. I had already fixed the problem.
Logging in I'm getting the error:
Fatal error: Only variables can be passed by reference in E:\webmail\functions\imap_messages.php on line 480
Fresh install. Default install, nothing changed except for domain. Anyone seen this before? Any ideas or suggestions?
Thanks!
-d
Edit: already fixed the problem in a previous version -- found the fix again.
Post by martin » 2005-09-17 20:58
dlong, you should at least say what web server and php version you're using...
dlong
Post by dlong » 2005-09-18 07:40
BTW.
For those interest, this has to do with running PHP5 (stable - 5.0.5) instead of PHP4 with SquirrelMail and has nothing to do with hMailServer. The fix, for those running a stable version of SquirrelMail (stable - 1.4.5; or SM Mod .02 which is based on 1.4.5) is to replace about 6 lines of code in 4 files.
http://www.squirrelmail.org/wiki/en_US/ ... ByPhpError (towards the bottom).
There is diff information @ http://sourceforge.net/tracker/index.ph ... tid=423679
-d
aklryan
time zone problem on squirrel mail
Post by aklryan » 2005-09-28 11:40
hi TheAngryPenginue,
I am still having problem on the timezone. I am using the copy download from ur site. Any idea?
aklryan
TheAngryPenguin
Re: time zone problem on squirrel mail
Post by TheAngryPenguin » 2005-09-28 15:24
chaikw wrote:Hi,
ERROR:
Any ideas?
Thanks.
aklryan wrote:hi TheAngryPenginue,
aklryan
My apologies
SM's Bug Tracker wrote: GMT instead of selected TZ issue should be fixed in 1.5.1cvs.
config/conf.pl v.1.217 and include/validate.php 1.19
timestamp issue can't be fixed in SquirrelMail. Problem is
in apache/php environment handling.
See https://sourceforge.net/tracker/index.p ... tid=423679 for instructions and a link to an alternate timezones.cfg -- FYI, it looks like this issue will be/is fixed with 1.5.x
aklryan
Post by aklryan » 2005-09-29 08:32
Hi TheAngryPenguin,
thanks for the link. hm.... after replace the file, it working now.
aklryan
TheAngryPenguin
Post by TheAngryPenguin » 2005-09-30 03:12
No problem. I think we're all looking forward to the stable release of 1.5.x...
dzekas
timezones
Post by dzekas » 2005-10-13 21:34
Please follow SquirrelMail code changes before declaring that timezones issue is fixed in 1.4.5. There is open bug in 1.4 tracker. Timezones issue is fixed only in 1.5.1cvs and you haven't backported all SquirrelMail 1.5.1cvs timezones handling code.
If you want to check if timezone is working - select any timezone. If it is not working - timezone reverts to GMT. Windows does not support GNU C timezone names. Your timezones.cfg contains GNU C time zones.
TheAngryPenguin
Post by TheAngryPenguin » 2005-10-13 21:59
Sorry, when I wrote that, I swear that it was posted as 1.4.5 in the tracker - Apparently, "GMT instead of selected TZ issue should be fixed in 1.5.1cvs." The first post has been modified accordingly.
doug2die4
Inbox
Post by doug2die4 » 2005-10-21 01:52
I've just installed and configure IIS on win2K, Hmailserver (latest stable version), the mod taken from this website, and php5
When I click on Inbox it appears me that:
Fatal error: Only variables can be passed by reference in C:\Program Files\hMailServer\webmail\hms_squirrelmail\functions\imap_messages.php on line 480
Could anyone help me.
P.S. I've seen in the first post that php5 is now supported!!!!! THX111
matty
Post by matty » 2005-10-21 04:06
See my solution to this problem here:
http://www.hmailserver.com/forum/viewtopic.php?t=2667
rattenfanger
Post by rattenfanger » 2005-10-21 11:03
I love this mod! It looks very nice :)
One thing: hMailServer now supports the SORT extension for new versions (I think for the 4.2 alpha branche??) Maybe its nice to notice in the opening post the ability to set the server side sort to true. It makes SM muchhh faster! Depening this variable on the server version is also a possibilty I think?
TheAngryPenguin
Post by TheAngryPenguin » 2005-10-21 15:31
Hmm -- I confirmed that I am 'watching' this topic, and yet, I haven't received any notifications of the last three posts or so. At any rate, I'll soon add the spiele about SORT compatability to the OP. Thanks rattenfanger!
EDIT1: It figures -- I just recieved a notification for my own post! <g>
EDIT2: Strange -- just got another one... :shock:
doug2die4
Post by doug2die4 » 2005-10-24 01:48
Thx matty that exacly what was wrong
Every thing fine altouight fot the moment
dennism
Post by dennism » 2005-11-02 21:08
On this picture I see graphically objects:
http://www.hmailserver.com/pics/squirrelmail_tmb.gif
How can I get that I my SquirrelMail?
And can anybody tell me which theme for SquirrelMail this picture use?
kingsz1
Post by kingsz1 » 2005-11-07 07:07
Thank you for the great work!
Mod 0.1 work fine, buit cannot change password. the newer (7z version) had to much problem but could change password. so I just copy the option.php from here to the Mod 0.1 then it work fine.
if you assemble the Add New User script (in this forum) into Mod 0.1, it would be better for the beginer (like me).
Thank you again. and hope you keep this work up.
jkearney
Post by jkearney » 2005-11-07 19:33
I have got problems with the plugins as well.
I am running win2k, hmailserver, hms_squirrelmail from here, iis 5, php 5.05.
The errors I am getting are:
timout_user/functions.php line 109. It seems that "$_SERVER['REQUEST_URI']" is not returning anything from the error message?
("undefined index REQUEST_URI").
Has anyone had any joy with this problem?
I will be disabling the timeout plugin i guess, until anyone knows a solution?
thanks v much,
james.
Post by martin » 2005-11-07 20:28
jkearney: Are you using PHP as a CGI? If so, perhaps you can switch to ISAPI instead? (At least I think it's called ISAPI in IIS)
jason
Post by jason » 2005-11-08 23:28
Can you give me a little more info so that I can try to figure out if I am running PHP as CGI?
