New version of OSAN Web Mail (0.84 BETA)
Jeinhor
Post by Jeinhor » 2009-02-17 00:25
Hi there!
I just put up a new version of OSAN Web Mail. Some of the new features:
* Saving of sent/draft messages
* Moving of messages between IMAP folders
* Easier to install with MSI-based installation
Extra languages except English is currently only Swedish.
It is still a BETA, and though I am running it on my server without problems I won't promise everything is working. I can't be help responsible for your data, always keep a back-up! Also, this version requires .NET Framework 3.5 and hMailServer 5.
Check out how to install at https://trac.joconit.com/OSAN/wiki/HowtoInstallMSI. Please post any questions and problems in this thread, do not create tickets at Trac for support issues.
Thanks to developer smuda for help on this release!
mark434_18
Re: New version of OSAN Web Mail (0.84 BETA)
Post by mark434_18 » 2009-02-19 04:02
I unable to install the file. I already installed the Visual Web Developer Express 2008 with .net 3.5 but still I encountering error.
Mark c";)
Jeinhor
Post by Jeinhor » 2009-02-19 10:04
Here's how to obtain the source code: https://trac.joconit.com/OSAN/wiki/HowtoCheckoutSource
You will need Visual Studio 2008 to open the solution though, I doubt Web Developer supports solution with class project?
Could you please check the eventvwr and see what error you are getting exactly? What OS are you running? Are you running the install as administrator?
Thanks!
freemailer
Banned
Post by freemailer » 2009-02-23 03:52
Thanks for this new version, the installer is excellent. Just a couple of small comments:
- in the ReadMe, step 4 says "give the accoutn IIS_WPG..." etc. You might want to put in that the user should navigate to the Security tab, first
- I had to also give the Network Service "Local Launch" and "Local Activation" permissions in order for my install to work
- it might be nice (if possible?) to be able to install a new website, as opposed to adding a virtual directory to an existing website
Overall though, looking very nice! Thanks!
Jeinhor
Post by Jeinhor » 2009-02-23 15:54
Your two first opinions will be included in the next release. About the third, I would also like that function, but since I am using a standard Web Setup Project in Visual Studio I don't think it is possible.
You can leave the virtual directory field empty and it will install at the root of the site though...
cybermac
Post by cybermac » 2009-02-27 16:36
Anywhere we can see a demo running?
Jeinhor
Post by Jeinhor » 2009-02-28 01:28
No, not at the moment. The test server I had earlier does unfortunately not exist anymore...
neonate
Post by neonate » 2009-07-06 20:10
I've downloaded the latest version, and everything seems to be working great. The only issue is that the users are told that I haven't configured a location to save sent/draft emails. Where would I make that configuration change? I read the install instructions, but don't see any mention of this location.
Thanks!!!
Jeinhor
Post by Jeinhor » 2009-07-13 09:32
Sorry for the late reply, been busy lately!
That is a per user setting, each user must go into Settings and set folder names there. The reason for this is different users might have different names on their Sent/Draft folders, depending on language and/or e-mail client.
nirjhareswar
Post by nirjhareswar » 2009-08-27 16:05
I recently upgraded hmail server install to 5.2B356 and osan mail (v 90beta) stopped working. It loads the login page properly, when logged in with valid credential it takes me to Error.htm and the error logged is:
2009-08-27 06:39:43,218 [1] FATAL ASP.global_asax (null) - An error occurred in the OSAN WebMail application:
MESSAGE: Input string was not in a correct format.
nSOURCE: mscorlib
FORM: QUERYSTRING:
TARGETSITE: Void StringToNumber(System.String, System.Globalization.NumberStyles, NumberBuffer ByRef, System.Globalization.NumberFormatInfo, Boolean)
nSTACKTRACE: at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
at System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info)
at System.Int32.Parse(String s)
at OSANWeb.WebMail.BindGrid()
at OSANWeb.WebMail.Page_Load(Object sender, EventArgs e)
at System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e)
at System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e)
at System.Web.UI.Control.OnLoad(EventArgs e)
at System.Web.UI.Control.LoadRecursive()
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Are these two versions not compatible.
Any help will be highly appreciated.
Many Thanks,
Nir
CarlUman
Post by CarlUman » 2009-09-09 02:27
Just posting to say thanks for your efforts... I plan to give this webmail a try someday.
quiksilv
Post by quiksilv » 2009-09-23 21:39
I also get the error:
nSOURCE: mscorlib
FORM: QUERYSTRING:
ETC...
Any reason for this?
tarl
Post by tarl » 2009-10-09 19:51
Same string error here.
<Uninstall><PLONK>
Just a heads-up to anyone thinking of trying this:
The documentation is non-existent and the only support I've seen is in these forums, scattered over 10-12 different threads. There's better working, documented, and supported webmail packages out there - many of which are also free. You might want to do yourself a favor and avoid the headache and frustration involved with this package.
Post by martin » 2009-10-09 21:51
> tarl
Why do you even assume that you should receive support for some beta software posted on some random forum? :)
Jeinhor
Post by Jeinhor » 2010-01-19 00:44
Yeah, well, sorry for not answering here but I have been occupied with other things.
When I wrote OSAN there were no alternatives to a .NET-powered web mail. Today, I find several (for example, http://www.afterlogic.com/products/webmail-lite). Therefore there is no longer need for OSAN, I will not "waste" any time on bug fixes on it.
Sorry for any inconvenience, just thought I would bring something back to the great community of hMailServer.
