Post new topic Reply to topic  [ 2 posts ]
Author Message
 Post subject: avast antivirus
PostPosted: 2010-07-21 13:08
Is there a way to start Avast Antivirus manualy? I don’t want Avast to run all the time in the background only when I do a manual scan. Is this possible?
_________________
market samurai ~ marketsamurai ~ marketsamurai.com
Top
 Profile
 Post subject: Re: avast antivirus
PostPosted: 2010-07-21 15:35
Can't you just disable the real-time shields? I recall the memory usage drops a lot as you disable them.. Or, not tried it but what happens if you stop the avast services?
_________________
hMailServer build I'm using LIVE on my servers: 5.4-B2013040501
Latest test builds at: http://www.hmailserver.com/forum/viewtopic.php?f=10&t=21420
Top
 Profile
Who is online
Search for:
