Post new topic Reply to topic  [ 37 posts ]
Author Message
 Post subject: FTP Server ?
PostPosted: 2009-10-22 10:37
Any recommendations for a windows based FTP Server?
_________________
An old dog learning new tricks...
Top
 Profile
 Post subject: Re: FTP Server ?
PostPosted: 2009-10-22 11:34
I second Filezilla server. easy to use, supports virtual folders, groups and above all is free :P
_________________
Top
 Profile
PostPosted: 2009-10-22 12:54
It's good for basics ... tho lacks quota support which is a real pain in the ass.
If you have $$$ try http://www.serv-u.com/ ... I've used that for ages where I need quotas and Filezilla where I dont.
Also get a nice web interface for users with serv-u so they dont have to have FTP clients setup which they wont understand.
Cheers
S
Top
 Profile
PostPosted: 2009-10-22 14:35
I personaly always use G6 FTP server (http://www.g6ftpserver.com/) quite stable and nice administrator pannel. (also able to have easy secured connection on the server)
_________________
Windows Server 2008 R2 Web edition | Hmailserver Version 5.4 | MSSQL 2008 R2
Join us on IRC! http://webchat.hellscream.org.uk #hmailserver
Top
 Profile
PostPosted: 2009-10-22 15:05
I used G6 many many moons ago. I preferred it over serv-u at that time (talking 15 years ago). If you want an easy to use free FTP server that is stable and open source go with filezilla without a doubt.
_________________
Top
 Profile
PostPosted: 2009-10-22 19:02
Thanks guys,
I went with filezilla. I only need something lightweight for moving files between development area and live area on my pc/server easily using dreamweaver's inbuilt ftp to server. It seems to work like a dream.
Not wildly impressed with it's GUI but I should only need to use it once in a while.
_________________
Top
 Profile
PostPosted: 2009-10-22 19:16
Yeah the GUI is plain but then it's meant for servers so it does the job.
_________________
Top
 Profile
PostPosted: 2009-10-23 12:13
In most of the good FTP servers are anti-"hammering" something that is integrated into the server, since else it could be a security risk.
_________________
Top
 Profile
PostPosted: 2009-10-23 12:19
The only bots i see hammering my FTP server try the username Administrator only then they get shunned in my firewall ;)
_________________
Top
 Profile
PostPosted: 2009-10-23 12:48
for quick and easy i use
http://www.whitsoftdev.com/slimftpd/
of for a more larger enviroment
http://www.warftp.org/?menu=344
Top
 Profile
PostPosted: 2009-10-23 13:02
Ohhh I forgot about warftpd. If i remember correctly it was hard to setup and use all those years ago. Will have to try the new one and see if it has improved.
_________________
Top
 Profile
PostPosted: 2009-10-25 00:13
I have problem with filezilla server. It uploads to server OK but when I do a get from server (using dreamweaver) the file is created or overwritten locally with time and date but file is always empty. i.e. data in file doesn't get copied.
Any ideas on why that might be happening?
_________________
Top
 Profile
PostPosted: 2009-10-25 00:22
Are you using PASV or PORT? (use PASV if your not).
_________________
Top
 Profile
PostPosted: 2009-10-25 00:24
i'm using PASV as far as I can tell
_________________
Top
 Profile
PostPosted: 2009-10-25 00:38
I see said the blind man....
It was a log file which Apache has its mits on. Stop Apache and the download works fine.
_________________
Top
 Profile
PostPosted: 2009-10-27 17:15
i suggest to use also filezilla client 'couse has the ZIP option to speedup the trasfer..
Top
 Profile
PostPosted: 2009-10-27 17:22
oh also in the past i've used guildftp and quick 'n easy ftp server
Top
 Profile
PostPosted: 2009-11-25 10:31
This is hMailserver Support not IE support.
_________________
Top
 Profile
PostPosted: 2009-11-25 18:15
eakinasila wrote:
How do you fix the http, https, and the ftp ports? When I open up internet explorer, I get the "Cannot display the web page" error. When I diagnostic the problem, it says that the http port 80, the https port 443, and the ftp port 21 need to be checked and that they might be being blocked by the firewall. There not being blocked, so what do I do?
Contact your network administrator.
Top
 Profile
PostPosted: 2009-11-25 18:58
:lol:
_________________
Top
 Profile
PostPosted: 2009-12-04 11:01
he is probebly on a Microsoft training.
Top
 Profile
PostPosted: 2009-12-04 11:49
Getting back to FTP servers....
What Filezilla has that I haven't seen elsewhere is the ability to impose speed limits on the overall connection or login by login which is really helpful for long transfers to stop them hogging all the bandwidth
It can even be configured to change speed limit by time period
Top
 Profile
PostPosted: 2010-01-21 20:06
Just install IIS and go to options/configurations and select FTP components to be installed. If use use Win 2008 and IIS 7, the FTP server that comes with it can be set up as secured FTP (SSL). We have a working FTP on 2008 for http://www.realtimereferral.com and are pretty happy with it. You can allocated quotas or have a home directory for your users.
Top
 Profile
PostPosted: 2010-01-22 02:17
You could do that in 2003 as well on IIS6
_________________
Top
 Profile
PostPosted: 2010-01-22 03:00
And also in Windows 2000, and Windows XP, and Vista, and...
_________________
Documentation
Top
 Profile
PostPosted: 2010-01-22 17:34
But you only need to have a MS License for every user you use there.
_________________
Top
 Profile
PostPosted: 2010-01-23 02:17
Not necessarily true.
Even for authenticated access, a single user can connect multiple times, even simultaneously. :wink:
On non-server platforms the number of concurrent connections is limited as per IIS limits (FTP is a sub-set of IIS)
_________________
Documentation
Top
 Profile
PostPosted: 2010-01-23 03:01
The limit is 5 on a single license.
When I made my first web site I decided to use Apache for this reason and the side benefit was more security, and never looked back. 8)
Almost forgot:
viewtopic.php?p=96759#p96759
Actually it is 10 concurrent connections in windows XP, same for Vista and Windows 7 I believe.
Apache is 'just' (Yes I know better, open source and more widely used, etc) a web server. IIS also contains FTP, POP3 and an SMTP component to name a few.
Matt
_________________
Documentation
Top
 Profile
PostPosted: 2010-01-23 14:40
hMailServer.com uses IIS 6
_________________
Top
 Profile
PostPosted: 2010-01-23 22:14
I have never seen it offline, it's always up when I come here.
_________________
Top
 Profile
PostPosted: 2010-01-24 02:12
It's rarely offline, but the last couple of days there has been at least two outages, both exceeding a couple of hours.
Either that or some bad network traffic somewhere. I was able to access evrything else I normally do on the web, just not hMailserver forums.
_________________
Documentation
Top
 Profile
PostPosted: 2010-01-24 20:30
its been offline a couple of times for me too ... I think it needs a bit of a manual kick sometimes from Martin when patches have been applied, and theres been a couple of MS patches not on the usual tuesday, so might have been waiting for Martin to press the button
S.
Top
 Profile
PostPosted: 2010-01-25 12:11
Almost forgot:
http://www.hmailserver.com/forum/viewto ... 759#p96759
Matt
This is only when you have a connection license. If you have a user license, or a "Webserver" license you don't need users licenses if you are not in a domain. But i still prefer to have another ftp server instead of the IIS FTP Server because that one is a little les stable and unable to do some options you can only have with a seperated software FTP server.
_________________
Top
 Profile
PostPosted: 2010-01-26 15:11
not only when you use IIS FTP the users need to be in the local SAM to have acces to your system
Also by default (and you can not disable it) it is active FTP and passive FTP. you will never know when you have errors.
You need to setup a static portrange.
Top
 Profile
PostPosted: 2010-01-26 15:32
http://support.microsoft.com/kb/555022
useful if you want to limit the port range.
S.
Top
 Profile
PostPosted: 2010-01-27 14:26
and if your using Windows firewall and you don't want to manually enter all those settings in the exception
Open_FTP_FirewallPorts.bat
Code:
Echo OFF
ECHO OPENING FIREWALL PORTS
FOR /L %%I IN (5500,1,5700) DO NETSH FIREWALL ADD PORTOPENING TCP %%I FTPPort%%I
ECHO FINISHED
Pause
and port 20 and port21 must also be opend 8)
Top
 Profile
PostPosted: 2010-09-04 18:15
I use zFTP; the free version is capable, licenses to use additional features are reasonably priced.
_________________
aka itproxy | Samsung NC10 1.6GHz | WinXP Home SP3 | Apache 2.2 | hMail 5.3 | AfterLogic 5.0 | MySQL 5.5 | PHP 5.3 | FileZilla 0.9 | BIND 9.9 | Real VNC 4.1 | OpenSSH 3.8 | Comodo 5.1
Top
 Profile
Who is online
Users browsing this forum: No registered users and 3 guests
Search for:
