451 qq temporary problem (#4.3.0)
dhaggard
Post by dhaggard » 2007-05-19 15:48
I have been running hMailServer for a few months now, with few problems. None that I couldn't fix. (Installed on Microsoft Windows Server 2003. hMailServer version 4.2.2. Database is MS SQL Server 2000).
But now I have two problems that are beyond me. (Two separate posts)
Suddenly I'm getting this response on every e-mail I send out--
Sent: Fri, 18 May 2007 18:06:36 -0500
Subject: <email subject)
<recipient's e-mail address>
Error Type: SMTP
Error Description: Error message from remote server
Message: 451 qq temporary problem (#4.3.0).
Tried 5 time(s)
MailDaemon
hMailServer
I have searched the Internet on this error, and almost everything attaches it to QMail and storage size limits. But that's not a component or issue with hMailServer. Or is it?
Post by ^DooM^ » 2007-05-19 15:53
That is an error from the remote server not hmail, Hmail tries to send it 5 times then gives up.
This doesn't look to me like a hmail issue.
Are you relaying through your ISP not that, that should produce this error though.
dhaggard
Post by dhaggard » 2007-05-19 15:58
Strange part is that it's every e-mail, to anywhere. So maybe my ISP's server is the issue. Yes, I have hMail set to point to my ISP's mail server for relay. Perhaps some new security setting they have?
Just wondering if there's a setting on my end that that end doesn't like.
Post by martin » 2007-05-19 16:54
If all your email are delivered to your ISP, it's either a problem at your ISP, or some router in your network which intercepts SMTP traffic and produces the error. There's no hMailServer that would cause this.
dzekas
Post by dzekas » 2007-05-20 16:03
Error is generated by qmail-queue. Disk space or filtering issues on remote server. Not related to hMailServer.
dhaggard
Post by dhaggard » 2007-05-21 01:47
My ISP had me change the relay server setting to another server, as they had changed their relay settings. And all is fixed now. Thanks.
