Nod Antivirus
BA_Dimitris
Nod Antivirus
Post by BA_Dimitris » 2007-01-26 21:41
I have a wink2003 along with hmaiserver 4.3.1 B253.
I use for external antivirus nod32. Although I'm not the person that set up the server I have to support it, and I am new to hmailserver. Concerning my antivirus program we use a batch file containing the following
REM NOD32 Scan Batch File
@echo off
date /t >> "C:\Program Files\hMailServer\Bin\Nod32Scan.log"
time /t >> "C:\Program Files\hMailServer\Bin\Nod32Scan.log"
echo Scanning file %1 >> "C:\Program Files\hMailServer\Bin\Nod32Scan.log"
"C:\Program Files\ESET\nod32.exe" /pattern+ /heur+ /arch+ /sfx+ /pack+ /scanboot- /scanmbr- /scanmem- /list- /sound- /subdir- /expire- /selfcheck- /quit+ /log+ /logappend /log=C:\PROGRA~1\hMailServer\Logs\NOD32.log %1
My problem is that viruses do pass my hmailserver and come up to my outlook 2000 clients where again NO32 on my clients catch the virus inside the message (attachment)
I have checked that both versions of NOD are the same (client and server) and also both virus databases are the same.
Does anyone have an idead around this ??
:shock:
Dimitris
hMailServer 5.3.2 B1769 MSSQL
Win 2003 R2 SP2 / Roundcube/Horde/AfterLogic
bazporter
Post by bazporter » 2007-01-26 22:33
I use nod32 too using the External Virus Scanner configuration in hMailServer with the following command string:
"C:\Program Files\ESET\nod32.exe" /quit+ /selfcheck- /list+ /scanfile+ /scanboot- /scanmbr- /scanmem- /arch+ /sfx+ /pack+ /mailbox+ /ntfs- /sound- /pattern+ /heur+ /ah /adware /unsafe /log+ /logappend /log=C:\Logs\NOD32.log "%FILE%"
Set the Return Code to 1
Works brilliantly for me.
Regards
Barry
BA_Dimitris
Post by BA_Dimitris » 2007-01-27 11:57
Thanks a lot bazporter
I checked your command line and I can see some differences, although most of the parameters are the same. I also have the return value equal to 1.
I will change mine according to yours and I'll keep an eye on my server for a couple of days to see if the problem is solved.
Thanks again
Regards
Dimitris
