Property ServerState what is the return numbers mean???
Pern
Post by Pern » 2006-09-14 02:01
Property ServerState As eServerState
Returns the current state of the server
i got it to return a value of 3 what are the posible return numbers and there meanings??
thankyou in advance for your time in this mater
Johnny - aka Pern
gruenie
Post by gruenie » 2006-09-14 15:55
Yes, the same question here! :-)
If I'm right, "1" means stopped and "3" means running.
Are there other possibilities?
I would like to add the question, if the status numbers will be the same also in coming releases of hmailserver or could it be that they change?
Gruenie
Post by martin » 2006-09-14 19:22
Added to the documentation.
http://www.hmailserver.com/documentatio ... pplication
Status numbers will remain the same unless functionality changes or is removed. The API is generally backwards compatible.
Pern
Post by Pern » 2006-09-14 23:05
thank you
gruenie
Post by gruenie » 2006-09-15 00:59
Thank you from me too!
Gruenie
iprat
Post by iprat » 2006-09-15 09:16
Just to comment to Martin that probably:
hStateStopping = 4, Server is running.
probably was meant to be:
hStateStopping = 4, Server is stopping. ;)
gruenie
Post by gruenie » 2006-09-15 16:04
Hi Iprat,
sure you are right and it is probably a typing/copy-error,
but nevertheless, if we are absolutely exact:
While the server is stopping he is still running, becaue if he
wouldn't run, why you would need to stop it? :lol:
Gruenie
iprat
Post by iprat » 2006-09-15 16:45
Sure gruenie !!! :D It must be still running to be stopping :D :D :D
Post by martin » 2006-09-15 17:25
(I updated the docs this morning)
