hMailAdmin ports for external connection if needed
Pern
Post by Pern » 2006-09-10 01:31
im having a problem with hMailAdmin as a external another computer ran application
i plug in my main domain name and it cant connect says its not there...
i figure ok i have a firewall both via router and winxp maybe its being blocked...but i cant find searching the forums and docs of the ports used to open so the hMailAdmin can communicate with the hserver...if not how can i check what the problem maybe if it does not use ports??
thanks for your time and any help you may provide in this matter
Johnny - aka Pern
Pern
Solution: ports to unblock
Post by Pern » 2006-09-12 18:27
the ports that need unblocking are
1120 and 135 TCP
hope this helps others, as i didnt find any info onthis at all any place when i looked maybe i missed it or something but i coudnt find it
Johnny - aka Pern
