Spam
Ralph
Spam
Post by Ralph » 2006-08-22 01:11
I have just installed HMailServer and wish to integrate spam management to minimize the amount of spam. I am running an IMAP environment. Secondly I can't install Perl so ASSP, etc are out of the question. Is there an alternative?
Bram
Post by Bram » 2006-08-22 07:56
In the forum there are mentioned two, but they are both commercial (sfi-spam-filter can be used though without restrictions)
http://www.logsat.com/sfi-spam-filter.asp
ewall from http://www.sssolutions.com/
Ralph
Post by Ralph » 2006-08-22 21:59
Bram,
Thanks for that. What do you mean by "sfi-spam-filter can be used though without restrictions"? Are there no restrictions at all if I don't purchase it?
Post by ^DooM^ » 2006-08-22 22:03
SpamFilter-ISP wrote: SPAM Filter ISP 3.1.3.597 can be licensed for $600 per server. You will never have to worry about how many end users you are supporting.
You may use it freely for development and evaluation purposes. Contact us at sales@***.com with questions.
Bram
Post by Bram » 2006-08-23 08:19
The evaluation version will not expire it will only add "evaluation version" to you HELO command and adds a header in you message.
PS If you are installng it with remote desktop and use it as a service, make sure you use the /console option otherwise you won't get to see the interface.
bazporter
Post by bazporter » 2006-08-24 02:50
You can get a compiled Windows binary version of SpamAssassin from this page (direct download link here) which means that you don't need to install perl etc. It's usually not the latest version of SpamAssassin as it takes the guy who creates it a little while to create a new build when SpamAssassin do a new release, but it works like a charm, especially if you add all the SARE rulesets too.
This means you can use spamc/spamd checking which is the fast way of using SpamAssassin, and works realy well.
HTH
Regards
Barry
Post by ^DooM^ » 2006-08-24 10:33
Thanks for the link Baz. Most useful ;)
weetabix
Post by weetabix » 2006-09-03 17:26
bazporter wrote:You can get a compiled Windows binary version of SpamAssassin from this page (direct download link here) which means that you don't need to install perl etc. It's usually not the latest version of SpamAssassin as it takes the guy who creates it a little while to create a new build when SpamAssassin do a new release, but it works like a charm, especially if you add all the SARE rulesets too.
Hi Barry,
I can not get a single thing to work, did you have to do anything special to make it run or could you use spamd/spamc "out of the box"?
Spamd starts and runs nicely, but i cant get spamc to output any result to either cmd console or log file.
Thanks,
Tommy :)
bazporter
Post by bazporter » 2006-09-03 18:12
Hi Weetabix,
You need to be using a script with the calls to spamc to make it work once spamd is up and running. There is a very good script detailed here which I adapted for my own system: http://www.hmailserver.com/forum/viewto ... 2222#12222
HTH.
Regards
Barry
Bram
Post by Bram » 2006-09-04 08:09
Found another spam filter, which includes spamassassin :
http://www.pinjo.nl/
Installation very simple, but no automatic whitelisting as far as i could see
