HOWTO: Use NOD32 with hMailServer
MeBerserk
Post by MeBerserk » 2006-05-21 02:11
NOD32 Command Line Parameters:
"<nod32.exe>" /selfcheck- /expire- /sound- /quit+ /pattern+ /heur+ /scanboot- /scanmbr- /scanmem- /arch+ /sfx+ /pack+ /adware /unsafe /ah /clean /quarantine
If you want to log the scan add these parameters:
/log+ /logappend /log="<logfile>"
Replace <nod32.exe> with the path to your exe file. (default: c:\program files\eset\nod32.exe)
MeBerserk
Post by MeBerserk » 2006-05-21 02:26
Well, I walked into one problem, this should be fixed in hMailServer and that it should work:
hMailServer should place the file parameter inside quotes (")
Post by martin » 2006-05-21 09:00
Now you've posted this to three different places. Makes me a bit confused. Do you expect me to comment it in all places? :)
Have you tried using the %FILE% macro within quotes as I suggested in my other message to you? If hMailServer would always place the file parameter within quotes, it wouldn't work with some other virus scanners.
Also, as far as I know, nod32.exe sometimes shows a user interface. If it does, the hMailSever delivery will hang for that message. And if this happens several times, all delivery threads will hang and hMailServer won't be able to deliver any messages.
MeBerserk
Post by MeBerserk » 2006-05-21 15:13
Hehe sorry for that.. =P
To bad, I really like NOD32 because it works great... Well I'm gonna test this for a while see what's happens
MeBerserk
Post by MeBerserk » 2006-05-21 15:26
For now it seems to work even the scan goes incredably fast, if I read the logs correct it finished in 100th of a second (0.100 seconds)
Post by martin » 2006-05-21 17:02
0.100 seconds isn't a 100th of a second. :)
MeBerserk
Post by MeBerserk » 2006-05-21 17:04
My english ain't that well, just wild guess but it was 0.100 seconds :);)
CraigHarris
Post by CraigHarris » 2006-05-21 18:11
A 10th of a second isn't incredibly fast; thats enough time for a thorough scan with todays CPUs.
MeBerserk
Post by MeBerserk » 2006-05-21 18:23
Also on a 1.29Ghz CPU than? :P that's what my server got LOL
ikshadow
Post by ikshadow » 2006-07-31 12:33
How could I set nod32 to delete all password protected and encoded zip/rars etc...
Pern
nod32 virus setting
Post by Pern » 2006-09-10 19:35
example (what i use) virus line
"C:\Program Files\ESET\nod32.exe" /quit /selfcheck- /list- /scanfile+ /scanboot- /scanmbr- /scanmem- /arch+ /sfx+ /pack+ /mailbox+ /ntfs- /sound- /pattern+ /heur+ /ah /adware /unsafe /log+ /logappend /log=C:\PROGRA~1\hMailServer\Logs\Nod32\NOD32.log "%FILE%"
{update - redid to make statement a bit clearer}
please note the "%FILE%" must have quotes, as this was a problem in
http://www.hmailserver.com/forum/viewtopic.php?t=5043
{it kept making a file named program in the root C: drive}
{/update}
just thought everyone should know and have a example string to work with/try/use
Johnny - aka Pern
Post by martin » 2006-09-10 19:37
%FILE% doesn't do anything.. hMailServer just replaces the %FILE% in the string with the path to the file. Adding %FILE% to the string can't have the effect that an extra file is created in the root directory. (If it does, it's a NOD32 issue)
Pern
Post by Pern » 2006-09-10 20:04
the program file was being created in root drive c: was due to the break(space) in the argument line..thus causeing it to not have the corect path..fix was in fact the "%file%" marco being in quotes.
excerp from nod32 log file showing broken path due to not having "%file%" in quotes. (user error)
Scanned disks, folders and files: C:\Program\; Files\hMailServer\Data\{D74EF1AF-8DC1-4460-B8B9-51DD41A721F4}.eml\
Path C:\Program\ is invalid.
Path Files\hMailServer\Data\{D74EF1AF-8DC1-4460-B8B9-51DD41A721F4}.eml\ is invalid.
localhost
Post by localhost » 2007-05-03 22:36
Anyone having an issue NOD32 tagging every (even text with no attachment) email that it scans with the following:
VIRUS DETECTED:
The attachment(s) of this message was removed since a virus
was detected in at least one of them.
I tried using the above the path and arg's above but still get the error.
If I try to send a mail with an attachment (any attachment) the mail is delivered but does not have the attached file.
Please help!!!
Post by martin » 2007-05-03 23:23
What return value have you specified in the configuration?
Is it the correct path to nod32.exe?
You probably need to enable debug logging in hMailServer, reproduce the problem, and then check in the log what debug value your scanner returned.
localhost
Post by localhost » 2007-05-03 23:37
Thank you for your reply.
What return value have you specified in the configuration = 0 (what should it be?)
Is it the correct path to nod32.exe? = This is correct.
DEBUG:
"DEBUG" 1704 "2007-05-03 14:31:39.656" "Socket::~Socket(ID: 166)"
"DEBUG" 3852 "2007-05-03 14:31:39.734" "CustomVirusScanner::Scan() - "C:\Program Files\ESET\nod32.exe" /quit /selfcheck- /list- /scanfile+ /scanboot- /scanmbr- /scanmem- /arch+ /sfx+ /pack+ /mailbox+ /ntfs- /sound- /pattern+ /heur+ /ah /adware /unsafe /log+ /logappend /log=C:\PROGRA~1\hMailServer\Logs\Nod32\NOD32.log "C:\Program Files\hMailServer\Data\{65695144-66D5-4188-9AFA-24474D7A4BC1}.eml" - Returned 0"
"DEBUG" 3852 "2007-05-03 14:31:39.734" "CustomVirusScanner::~Scan()"
"APPLICATION" 3852 "2007-05-03 14:31:39.734" "SMTPDeliverer - Message 218: Message attachments stripped (contained virus)."
FiShBuRn
Post by FiShBuRn » 2007-07-11 21:21
What is the return value? 0 doesnt work!
Post by martin » 2007-07-11 21:28
Fishburn, it's time now that you learn how to do search on the Internet and in this forum. Almost all questions you've asked in this forum so far has been easy to find answer to simply by searching. :)
http://www.hmailserver.com/forum/viewto ... turn+value
FiShBuRn
Post by FiShBuRn » 2007-07-11 22:02
thanks Martin! :)
mbach
Post by mbach » 2007-07-20 01:26
Sorry Martin,
but wouldn't it be better to use "1" as return value as described in this article???
http://www.hmailserver.com/forum/viewto ... d32+return
Best regards,
Markus
Post by martin » 2007-07-20 12:46
Don't think it matters.
Alexey-ua
Re: HOWTO: Use NOD32 with hMailServer
Post by Alexey-ua » 2008-12-09 15:17
I have tried to connect nod32 to hMail, read forum and tested configurations.
Finally i stopped at this configuration:
Settings->Antivirus->External Scanner:
Scanner executable C:\hMail-nod32\Scan-nod32.bat "%FILE%"
Return value 1
Scan-nod32.bat
cd "C:\Program Files\ESET\ESET NOD32 Antivirus"
ecls.exe /files /no-boots /arch /mail /sfx /rtp /adware /unsafe /unwanted /pattern /heur /adv-heur /action=clean /log-file=C:\hMail-nod32\hmail-nod32.log /no-log-all %1%
if i used return value 0 - result is deleting attachements in all valid mails and all valid mails classified as visus detected, so never used "0"
if i used return value 2 - result is silent deleting virus attache (without classified letter as virus)
if i used return value 1 - virus attache is deleting and mail classified as virus detected
Alexey.
bagu
Post by bagu » 2009-04-29 23:01
Does someone know how to make ESET Smart Security 4 working with hmailserver ?
Parameters seem to be different and :
"C:\Program Files\ESET\ESET Smart Security\ecls.exe" /files /no-boots /arch /mail /sfx /rtp /adware /unsafe /unwanted /pattern /heur /adv-heur /action=clean /no-quarantine "%FILE%"
With value : 1
Don't detect simple eicar test.
Can you help me ?
hMailServer 5.6.8 With SpamAssassin 3.4.1
Partyface
Post by Partyface » 2009-11-26 01:38
I have the same problem: I use Eset nod32 Antivirus, I set up Scan-nod32.bat return value: 1 but eicar test file go through the mailserver without warning.
Does anybody have any idea?
thank you in advance
[win7 rtm, hMailServer-5.3-B1617]
I change return value to 2 and it's working :-))
ITemplate
Post by ITemplate » 2009-12-01 23:28
Partyface wrote:I change return value to 2 and it's working :-))
Can you confirm that return value == 2 means that the setup is working? I cant even send the eicar test - both gmail and hotmail refuses to send that file :(
So basically Im not able to test of that setup works?
david9394
Post by david9394 » 2009-12-18 09:47
ITemplate,
You need to add "exit %ERRORLEVEL%" at the end of the batch file.
sysadminus
Post by sysadminus » 2009-12-22 09:11
Anyone!
NEED FULL INSTRUCTION FOR ESET 4 + hMailSever.
Best Regards!
Alexey-ua
Post by Alexey-ua » 2009-12-28 21:29
Hi All !
I just checked my config and it works fine :)
I created a new letter with attached text file wich contained eicar string.
I sent mail to myself, and here is output:
VIRUS DETECTED:
test mail with eicar
All configs the same as in the my first post
check "Use external scanner"
Return value 1
Scan-nod32.bat
hmail-nod32.log
ECLS Command-line scanner, version 4.0.467.0, (C) 1992-2009 ESET, spol. s r.o.
Модуль loader, версия 1031 (20091029), сборка 1035
Модуль perseus, версия 1254 (20091221), сборка 1304
Модуль scanner, версия 4723 (20091228), сборка 6285
Модуль archiver, версия 1105 (20091029), сборка 1061
Модуль advheur, версия 1099 (20091030), сборка 1056
Командная строка: /files /no-boots /arch /mail /sfx /rtp /adware /unsafe /unwanted /pattern /heur /adv-heur /action=clean /log-file=C:\hMail-nod32\hmail-nod32.log /no-log-all C:\Program Files\hMailServer\Data\{D928C1B8-B00C-4A17-9558-28364DD90A65}.eml
Сканирование запущено 12/28/09 20:58:53
имя="C:\Program Files\hMailServer\Data\{D928C1B8-B00C-4A17-9558-28364DD90A65}.eml", угроза="Eicar тест файла", действие="содержит зараженные файлы", информация=""
имя="C:\Program Files\hMailServer\Data\{D928C1B8-B00C-4A17-9558-28364DD90A65}.eml » MIME » Copy of eicar.txt", угроза="Eicar тест файла", действие="очищен удалением", информация=""
Сканирование завершено 12/28/09 20:58:53
Время сканирования: 0 с. (0:00:00)
Всего: файлы — 1, объекты 2
Заражено: файлы — 0, объекты 0
Очищено: файлы — 1, объекты 1
JuggalotusHeat
Post by JuggalotusHeat » 2012-04-13 19:55
I have implemented the last batch shown here but ALL email is being marked as code 1. If I put return value as 1 it just flags all email as a virus if it has any content other than txt in it. Any ideas?
Thanks,
Collin
EDIT: if I set it to value 2 it won't detect any virus'
JuggalotusHeat
Post by JuggalotusHeat » 2012-04-17 19:14
JuggalotusHeat wrote:I have implemented the last batch shown here but ALL email is being marked as code 1. If I put return value as 1 it just flags all email as a virus if it has any content other than txt in it. Any ideas?
Thanks,
Collin
^doom^ helped get it working. Instead of using a .bat file. Simply put the command into the hmail v5 interface for external virus scanner. When tested, it gave me a return value of 10. I set that in the admin interface and all is well :)
Onlyme!
Post by Onlyme! » 2012-10-13 17:27
These are the settings to get ESET NOD32 v4 x64 to successful work. :)
Scanner executable
"C:\Program Files\ESET NOD32 Antivirus\ecls.exe" "%FILE%"
(Please note the path to your "ecls.exe" file may be different to mine).
Return value
50
Tip: If you open up your "ecls.exe" in command prompt using the "--help" switch it should display all the various config switches and exit codes.
EICAR Test - https://www.andymillar.co.uk/blog/2007/ ... ith-eicar/
Virus found, exit code 50.
"DEBUG"	4216	"2012-10-13 15:47:40.389"	"Creating session 49"
"DEBUG"	4372	"2012-10-13 15:47:40.629"	"Spam test: SpamTestDNSBlackLists, Score: 0"
"DEBUG"	4372	"2012-10-13 15:47:40.632"	"Total spam score: 0"
"DEBUG"	3192	"2012-10-13 15:47:40.717"	"SURBL::Run"
"DEBUG"	3192	"2012-10-13 15:47:40.794"	"SURBL::~Run"
"DEBUG"	3192	"2012-10-13 15:47:40.794"	"Spam test: SpamTestSURBL, Score: 0"
"DEBUG"	3192	"2012-10-13 15:47:40.797"	"Total spam score: 0"
"DEBUG"	3192	"2012-10-13 15:47:40.797"	"Saving message: C:\Program Files (x86)\hMailServer\Data\{B11234F8-2AE9-4870-AB6C-78AD47689233}.eml"
"DEBUG"	3192	"2012-10-13 15:47:40.802"	"Requesting SMTPDeliveryManager to start message delivery"
"DEBUG"	5228	"2012-10-13 15:47:40.804"	"Delivering message..."
"APPLICATION"	5228	"2012-10-13 15:47:40.807"	"SMTPDeliverer - Message 27: Delivering message from www@caffeine.andymillar.co.uk to xxx@xxx-xxx.com. File: C:\Program Files (x86)\hMailServer\Data\{B11234F8-2AE9-4870-AB6C-78AD47689233}.eml"
"DEBUG"	5228	"2012-10-13 15:47:40.809"	"CustomVirusScanner::Scan()"
"DEBUG"	3580	"2012-10-13 15:47:40.829"	"Closing TCP/IP socket"
"DEBUG"	3580	"2012-10-13 15:47:40.829"	"Ending session 49"
"DEBUG"	5228	"2012-10-13 15:47:43.506"	"CustomVirusScanner::Scan() - "C:\Program Files\ESET NOD32 Antivirus\ecls.exe" "C:\Program Files (x86)\hMailServer\Data\{B11234F8-2AE9-4870-AB6C-78AD47689233}.eml" - Returned 50"
"DEBUG"	5228	"2012-10-13 15:47:43.508"	"CustomVirusScanner::~Scan()"
"APPLICATION"	5228	"2012-10-13 15:47:43.511"	"SMTPDeliverer - Message 27: Message attachments stripped (contained virus)."
"DEBUG"	5228	"2012-10-13 15:47:43.513"	"Applying rules"
"DEBUG"	5228	"2012-10-13 15:47:43.513"	"Performing local delivery"
"DEBUG"	5228	"2012-10-13 15:47:43.516"	"Applying rules"
"DEBUG"	5228	"2012-10-13 15:47:43.521"	"Saving message: C:\Program Files (x86)\hMailServer\Data\xxx-xxx.com\xxx\B1\{B11234F8-2AE9-4870-AB6C-78AD47689233}.eml"
"DEBUG"	5228	"2012-10-13 15:47:43.526"	"Local delivery completed"
"APPLICATION"	5228	"2012-10-13 15:47:43.526"	"SMTPDeliverer - Message 27: Message delivery thread completed."
A normal response, exit code 0 (no virus found).
"DEBUG"	4216	"2012-10-13 15:51:42.023"	"Creating session 50"
"DEBUG"	7204	"2012-10-13 15:51:42.382"	"Spam test: SpamTestDNSBlackLists, Score: 0"
"DEBUG"	7204	"2012-10-13 15:51:42.382"	"Total spam score: 0"
"DEBUG"	3192	"2012-10-13 15:51:42.779"	"SURBL::Run"
"DEBUG"	3192	"2012-10-13 15:51:42.826"	"SURBL::~Run"
"DEBUG"	3192	"2012-10-13 15:51:42.826"	"Spam test: SpamTestSURBL, Score: 0"
"DEBUG"	3192	"2012-10-13 15:51:42.826"	"Total spam score: 0"
"DEBUG"	3192	"2012-10-13 15:51:42.826"	"Saving message: C:\Program Files (x86)\hMailServer\Data\{AE0F0952-E46B-41F4-B76D-5859B9CF7D6B}.eml"
"DEBUG"	3192	"2012-10-13 15:51:42.842"	"Requesting SMTPDeliveryManager to start message delivery"
"DEBUG"	5228	"2012-10-13 15:51:42.842"	"Delivering message..."
"APPLICATION"	5228	"2012-10-13 15:51:42.842"	"SMTPDeliverer - Message 28: Delivering message from xxxx.xxxxx+caf_=xxx=xxx-xx.xxx@gmail.com to xxxx@xxx-xxx.com. File: C:\Program Files (x86)\hMailServer\Data\{AE0F0952-E46B-41F4-B76D-5859B9CF7D6B}.eml"
"DEBUG"	5228	"2012-10-13 15:51:42.842"	"CustomVirusScanner::Scan()"
"DEBUG"	5228	"2012-10-13 15:51:45.525"	"CustomVirusScanner::Scan() - "C:\Program Files\ESET NOD32 Antivirus\ecls.exe" "C:\Program Files (x86)\hMailServer\Data\{AE0F0952-E46B-41F4-B76D-5859B9CF7D6B}.eml" - Returned 0"
"DEBUG"	5228	"2012-10-13 15:51:45.525"	"CustomVirusScanner::~Scan()"
"DEBUG"	5228	"2012-10-13 15:51:45.525"	"Applying rules"
"DEBUG"	5228	"2012-10-13 15:51:45.525"	"Performing local delivery"
"DEBUG"	5228	"2012-10-13 15:51:45.540"	"Applying rules"
"DEBUG"	5228	"2012-10-13 15:51:45.540"	"Saving message: C:\Program Files (x86)\hMailServer\Data\xxx-xxx.com\xxx\AE\{AE0F0952-E46B-41F4-B76D-5859B9CF7D6B}.eml"
"DEBUG"	5228	"2012-10-13 15:51:45.540"	"Local delivery completed"
"APPLICATION"	5228	"2012-10-13 15:51:45.540"	"SMTPDeliverer - Message 28: Message delivery thread completed."
philcar
Post by philcar » 2013-10-16 18:01
Hello all,
This post was most helpful to me.
Confirming hMailserver also seems to be working with ESET file Security 4.5 on Windows Server 2012.
Scanner executable is :
"C:\Program Files\ESET\ESET File Security\ecls.exe" "%FILE%"
Return code 50 indeed.
Refer to :
http://kb.eset.com/esetkb/index?page=co ... d=SOLN2285
or
http://kb.eset.com/esetkb/index?page=co ... d=SOLN3417
Log lines :
"DEBUG" 1068 "2013-10-16 17:26:57.191" "Running custom virus scanner..."
"DEBUG" 1160 "2013-10-16 17:27:00.809" "Scanner: "C:\Program Files\ESET\ESET File Security\ecls.exe" "C:\Program Files (x86)\hMailServer\Data\{01E7FA95-995E-49F3-ADFF-78E3C7D7AC77}.eml". Return code: 50"
"APPLICATION" 1160 "2013-10-16 17:27:00.809" "SMTPDeliverer - Message 468: Message attachments stripped (contained virus Unknown)."
"DEBUG" 1160 "2013-10-16 17:27:00.809" "Applying rules"
"DEBUG" 1160 "2013-10-16 17:27:00.809" "Performing local delivery"
Regards.
Philippe M. Caron
Dataconsult bvba
Gent, Belgium.
