SSL Security error on install
mmurphy
Post by mmurphy » 2020-10-15 16:46
I'm getting the following error attempting to set up the DB connection to an MS SQL server.
It appears that the issue is related to TLS1.0 not being enabled - Searches on the forum seem to point to modifying the database file of the .ini, however, that .ini does not have a Database section generated, as it hasn't connected to a database successfully.
ADO: [DBNETLIB][ConnectionOpen (SECCreateCredentials()).]SSL Security error.
Re: SSL Security error on install
Post by mattg » 2020-10-16 00:39
Which version of hMailserver are you trying to install
there is a 5.7 ALPHA version that I've been using for over a year that has the required Connector.
Or you can use another Database, eg MySQL
nitro
Post by nitro » 2020-10-16 10:23
mmurphy wrote:
2020-10-15 16:46
I am using MSSQL 2017 in Windows Server 2016 Datacenter, this is the configuration of my .ini file
Provider=MSOLEDBSQL
;connection through Microsoft OLE DB for SQL Server (MSOLEDBSQL) v18 for the use of TLSv1.2 between HmailServer and MSSQL
Type=MSSQL
Username=sa
Password=123432534534gh5ju543g34554
Port=1433
Server=127.0.0.1
Database=hmailserver
Internal=0
