Can I ban double attachment extensions like *.gz.txt?
Nime
Post by Nime » 2020-09-18 13:37
It seems like I cannot.
Neither SpamAssassin nor ClamAV+SaneSecurity can block *.GZ.txt attachments and I got tons of spams everyday.
Re: Can I ban double attachment extensions like *.gz.txt?
Post by SorenR » 2020-09-18 14:26
The GUI accept the extensions so I presume it should work as intended.
Post by katip » 2020-09-18 14:58
Nime wrote:
2020-09-18 13:37
Spamassassin for sure can score it. try this:
full GZ_TXT_CRAP /\bcontent\-[^\r\n]+?(|file)name\=(\"|).+?(|[\r\n]).+?\.gz\.txt\b/i
score GZ_TXT_CRAP 10.00
Post by RvdH » 2020-09-19 12:10
katip wrote:
2020-09-18 14:58
Nime wrote:
2020-09-18 13:37
# ifplugin mail::SpamAssassin::Plugin::MIMEHeader
	mimeheader GZ_TXT_CRAP  Content-Type =~ /="[^"]+\.gz\.txt"/i
	describe GZ_TXT_CRAP  email contains a *.gz.txt file attachment
# endif
Nime
Post by Nime » 2020-09-22 18:34
Thanks guys!
554 Tagged as Spam by SpamAssassin
Nime
Post by Nime » 2020-09-29 19:49
This is the report of banned messages, huge decrease! Guys, can you modify the regex so I can also ban *.GZ.TXT.TXT or simply *.GZ.* ?
Post by katip » 2020-09-30 08:20
Nime wrote:
2020-09-29 19:49
full search:
full GZ_TXT_CRAP /\bcontent\-[^\r\n]+?(|file)name\=(\"|).+?(|[\r\n]).+?\.gz\./i
MIME plugin:
mimeheader GZ_TXT_CRAP  Content-Type =~ /="[^"]+\.gz\."/i
both match *.gz.* or *.GZ.*
be careful: legitmail.gz.department.doc will match too, just in case..
