TCPIP "connected to" message
sergiortc
Post by sergiortc » 2020-06-22 18:31
I've been registering TCPIP messages of the form:
"TCPIP"	1444	"2020-06-20 00:03:01.352"	"TCP - 212.70.149.82 connected to MyServerIPHere:25."
"TCPIP"	1444	"2020-06-20 00:03:03.571"	"TCP - 212.70.149.50 connected to MyServerIPHere:25."
"TCPIP"	1444	"2020-06-20 00:03:32.055"	"TCP - 212.70.149.82 connected to MyServerIPHere:25."
"TCPIP"	1444	"2020-06-20 00:03:34.899"	"TCP - 212.70.149.50 connected to MyServerIPHere:25."
"TCPIP"	1444	"2020-06-20 00:04:02.727"	"TCP - 212.70.149.82 connected to MyServerIPHere:25."
"TCPIP"	1444	"2020-06-20 00:04:06.289"	"TCP - 212.70.149.50 connected to MyServerIPHere:25."
"TCPIP"	1444	"2020-06-20 00:04:33.399"	"TCP - 212.70.149.82 connected to MyServerIPHere:25."
"TCPIP"	1444	"2020-06-20 00:04:37.649"	"TCP - 212.70.149.50 connected to MyServerIPHere:25."
"TCPIP"	1228	"2020-06-20 00:05:01.196"	"TCP - 76.108.196.78 connected to MyServerIPHere:110."
"TCPIP"	1444	"2020-06-20 00:05:04.055"	"TCP - 212.70.149.82 connected to MyServerIPHere:25."
In just one day 2801 times from 212.70.149.82 and 2740 times from 212.70.149.50.
Can anyone tell me what is the exact meaning of this message? in which way are those IPs connected to MyServerIPHere?
Is there something I can do to avoid this?
Thank you.
johang
Re: TCPIP "connected to" message
Post by johang » 2020-06-23 00:48
sergiortc wrote:
2020-06-22 18:31
Thank you.
they connect to your port 25 ( SMTP )
if you enable "SMTP" to log you can read what they do ..
Post by mattg » 2020-06-23 05:02
and perhaps add more logging to see if they are testing your server for security, or perhaps doing a dictionary attack trying to guess passwords
johang
Post by johang » 2020-06-23 16:04
sergiortc wrote:
2020-06-22 18:31
if your mailserver is on internet ... anyone and all can reach it ..
autoban will place offending IP in quarantine ( as per whatever your configuration is.. personally i lock them out for a year )
but that does not stop them from trying to connect and show up in your hmailserver-log
on this forum you can find ways of putting those IPs into the firewall of your windows machine, they will still try to connect .. but they wont get into hmailserver log
and if you have firewall/router outside of that .. you could always filter away those IPs even further out
i think i manually in my windows firewall, blocked that /24 a month ago myself ..
https://apps.db.ripe.net/db-web-ui/quer ... ource=RIPE
sergiortc
Post by sergiortc » 2020-06-26 18:45
Thank you, Johang and mattg.
I will add more login and try to dig further.
sergiortc
Post by sergiortc » 2020-07-08 19:30
I enabled for an hour Debug Log and found that virtually all messages of the type
Are followed by the message:
"Client connection from 212.70.149.82 was not accepted. Blocked either by IP range or by connection limit."
Only valid users are being allowed to connect successfully.
Thanks.
Post by RvdH » 2020-07-08 20:41
