SSL server clients not connect
benio
Post by benio » 2020-06-10 14:27
Welcome again :)
I isntall cert file and private kay file for ssl certificate.
I enable adidtional ports to imap and smtp for ssl communication via phones , laptops and etc to email server.
When i connect eg. phone on correct ports i recive information to ssl is incorect "Trust anchor for certification patch not found".
Can you help me to resolve this problem?
Best regards.
Re: SSL server clients not connect
Post by mattg » 2020-06-10 16:53
Where did you get the certificate from?
Did you include the CA and intermediary trust certificates into the certificate file?
benio
Post by benio » 2020-06-10 21:52
Welcome I recive from my ssl provider 4 filers in txt:
1certificate
2. cert intermediate 1
2. cert intermediate 2
3 cert intermadiate 3
4 private key
I put into hamailserver file with certificate 1 and private key
I dont have big knowledge about ssl cert.
How i can include CA into main cert file ?
Best regards.
titanius81
Post by titanius81 » 2020-06-10 22:19
I am also having your same problem but I believe that the chain must be complete with all the root and intermediate certificates in a single file. I follow the discussion
I always want to learn
Post by mattg » 2020-06-11 03:24
You also need to add the intermediary and root certificates INTO your .crt file from your own certificate.
Open your .crt file in (preferably) notepad++ also open the .crt file from the intermediate certificate and copy that information. paste the information BEFORE your certificate detail.
it should look like this:
-----BEGIN CERTIFICATE-----
<gibberish for the ROOT certificate (also called CA)>
-----END CERTIFICATE-----
<lots of gibberish for the intermediate certificate>
<lots of gibberish from YOUR certificate>
save the certificate AS ONE FILE and private key (the .key file) in a directory readable for hmailserver (preferably in a directory *only* hmailserver can read).
benio
Post by benio » 2020-06-11 17:04
Welcome i check logs and i found on error log this information. I create new file but problem still active.
My key its ok because work on other services Ok.
What i a reason of this error :
"ERROR"	5840	"2020-06-11 16:56:39.647"	"Severity: 2 (High), Code: HM5113, Source: SslContextInitializer::InitServer, Description: Failed to load private key file. Path: C:\SSL\wildcardbeniokluczprywatny.txt, Address: 0.0.0.0, Port: 465, Error: use_private_key_file: key values mismatch"
"ERROR"	5840	"2020-06-11 16:56:39.663"	"Severity: 2 (High), Code: HM5113, Source: SslContextInitializer::InitServer, Description: Failed to load private key file. Path: C:\SSL\wildcardbeniokluczprywatny.txt, Address: 0.0.0.0, Port: 993, Error: use_private_key_file: key values mismatch"
"ERROR"	5840	"2020-06-11 16:56:39.663"	"Severity: 2 (High), Code: HM5113, Source: SslContextInitializer::InitServer, Description: Failed to load private key file. Path: C:\SSL\wildcardbeniokluczprywatny.txt, Address: 0.0.0.0, Port: 995, Error: use_private_key_file: key values mismatch"
"ERROR"	11076	"2020-06-11 16:57:57.148"	"Severity: 2 (High), Code: HM5113, Source: SslContextInitializer::InitServer, Description: Failed to load private key file. Path: C:\SSL\wildcardbeniokluczprywatny.txt, Address: 0.0.0.0, Port: 465, Error: use_private_key_file: key values mismatch"
"ERROR"	11076	"2020-06-11 16:57:57.163"	"Severity: 2 (High), Code: HM5113, Source: SslContextInitializer::InitServer, Description: Failed to load private key file. Path: C:\SSL\wildcardbeniokluczprywatny.txt, Address: 0.0.0.0, Port: 993, Error: use_private_key_file: key values mismatch"
"ERROR"	11076	"2020-06-11 16:57:57.163"	"Severity: 2 (High), Code: HM5113, Source: SslContextInitializer::InitServer, Description: Failed to load private key file. Path: C:\SSL\wildcardbeniokluczprywatny.txt, Address: 0.0.0.0, Port: 995, Error: use_private_key_file: key values mismatch"
"ERROR"	3448	"2020-06-11 17:02:00.023"	"Severity: 2 (High), Code: HM5113, Source: SslContextInitializer::InitServer, Description: Failed to load private key file. Path: C:\SSL\SSL_KLUCZ_PRYW.txt, Address: 0.0.0.0, Port: 465, Error: use_private_key_file: key values mismatch"
"ERROR"	3448	"2020-06-11 17:02:00.039"	"Severity: 2 (High), Code: HM5113, Source: SslContextInitializer::InitServer, Description: Failed to load private key file. Path: C:\SSL\SSL_KLUCZ_PRYW.txt, Address: 0.0.0.0, Port: 993, Error: use_private_key_file: key values mismatch"
"ERROR"	3448	"2020-06-11 17:02:00.039"	"Severity: 2 (High), Code: HM5113, Source: SslContextInitializer::InitServer, Description: Failed to load private key file. Path: C:\SSL\SSL_KLUCZ_PRYW.txt, Address: 0.0.0.0, Port: 995, Error: use_private_key_file: key values mismatch"
Post by RvdH » 2020-06-11 23:39
benio wrote:
2020-06-11 17:04
Does the private key look like this?
GIBBERISHGIBBERISHGIBBERISHGIBBERISHGIBBERISH
-----END RSA PRIVATE KEY-----
If not, and looks like
-----BEGIN ENCRYPTED PRIVATE KEY-----
or
Proc-Type: 4,ENCRYPTED
DEK-Info: AES-256-CBC,GIBBERISHGIBBERISHGIBBERISH
then it is encrypted, decrypt using
openssl rsa -in ssl.key.encrypted -out ssl.key.decrypted
You are prompted for the password
benio
Post by benio » 2020-06-11 23:53
Welcome.
i resolve problem and clients can connect to server over ssl.
Reason is in proper keys hierarchy in cert file.
this hierarchy wirks with hamailserver:
<SERVER CERT>
<INTERMEDIATE CERT>
<ROOT CERT>
After correct conect clients to server i cbeck logs and when client connecting on client side all its ok no errors but on server log i recive ssl error.
Its hanschake error but on next line connection ok. How i can check this?
"SMTPD"	10756	997	"2020-06-11 23:46:14.054"	"51.75.123.12"	"RECEIVED: STARTTLS"
"SMTPD"	10756	997	"2020-06-11 23:46:14.054"	"51.75.123.12"	"SENT: 220 Ready to start TLS"
"DEBUG"	4404	"2020-06-11 23:46:14.054"	"Performing SSL/TLS handshake for session 997. Verify certificate: False"
"TCPIP"	4404	"2020-06-11 23:46:14.273"	"TCPConnection - TLS/SSL handshake completed. Session Id: 997, Remote IP: 51.75.123.12, Version: TLSv1.2, Cipher: ECDHE-RSA-AES256-GCM-SHA384, Bits: 256"
johang
Post by johang » 2020-06-12 17:47
https://mxtoolbox.com/SuperTool.aspx
in supertool .. paste you IP of your server ... chose "test email server"
Post by jimimaseye » 2020-06-12 18:58
That is the fail of the remote server, not yours.
Post by mattg » 2020-06-13 00:29
2020-06-12 18:58
Actually it is saying that hMailserver is NOT going to test the validity of that certificate
The ONLY certificates that are verified are for servers in routes, and servers in external downloads (POP3)
ALL others are NOT tested (and that message shows)
Post by jimimaseye » 2020-06-13 09:08
2020-06-13 00:29
2020-06-12 18:58
I stand corrected. :oops:
