Rouncube password
benio
Rouncube password
Post by benio » 2020-06-10 11:55
Welcome again.
I explain my config:
QNAP:
its roundcube install on builtin web server. Imap works like charm but password change not. I enable password plugin and neccesary settings set:
$config['password_driver'] = 'hMail';
// hMail Driver options
// Remote hMailServer configuration
// true:  HMailserver is on a remote box (php.ini: com.allow_dcom = true)
// false: Hmailserver is on same box as PHP
$config['hmailserver_remote_dcom'] = true;
// Windows credentials
$config['hmailserver_server'] = array(
    'Server'   => '192.168.1.241',      // hostname or ip address
    'Username' => 'administrator',  // windows username
    'Password' => 'password'        // windows user password
Hamail its on vm installed on windows 10 pro maschine. Windows ip i set corectly. I turn off firewals et.c
HAMAILSERVER (windows 10) ------------------>qnap webserver with mariadb
I have two problems:
1. I add in php ini line to enable com
2. I try settings from manual hmailserver dcom settings but i dont know what username and password i must set.
Reasuming not works password change from roundcube. Its some simple way to make possiblity setup this feature ?
I use maria db database on built in qnap. Maybe its possible to do this by database .
I am not super IT specialist but i try :)
Best regards.
tunis
Re: Rouncube password
Post by tunis » 2020-06-10 13:19
This will not work, linux have no com function, it's for php on windows only.
If you using a Linux box for webmail then you must install a webserver on the hmailserver with com enable and use that for api between linux and hmailserver.
linux --> webserver@hmailserver --> hmailserver
Post by SorenR » 2020-06-10 14:19
tunis wrote:
2020-06-10 13:19
Your password driver is not on your github repository...
@benio
I use custom plugins made by @tunis to interface my Roundcube on Linux/Apache with hMailServer on Windows/IIS.
Roundcube(PHP) <-http-> Custom Driver(IIS) <-COM-> hMailServer
Actually this will also work with a "walled garden" setup without opening up COM traffic through a firewall..
tunis
Post by tunis » 2020-06-10 14:38
2020-06-10 14:19
I will upload it on github then.
benio
Post by benio » 2020-06-10 14:51
Welcome guys can You give some link and some FAQ how i can make this?
concept looks very good!!!
benio
Post by benio » 2020-07-07 10:34
I reinstall haimalserver on windows and enable iis7 on windows .
I make configuration of plugin .
When i put change pessword i recive site
server adres/webmail/?_task=settings&_action=plugin.password-save
This site with error 500.
When i try put wrong old password incorect i recive error "wrong old password"- i think old password was correct check.
When i puy correct old password then new password then when i click save i recive eroor site.
Please help me to resolve this problem.
Post by RvdH » 2020-07-07 10:56
Did you try with customErrors=off in web.config?
you should see a detailed report about the issue that is causing the 500 error (most likely DCOM)
    <system.web>
        <customErrors mode="Off"/>
    </system.web>
benio
Post by benio » 2020-07-07 11:05
 <system.web>
    </system.web>
Where i can put this code on iis ? On php ini i cant find it .
Post by RvdH » 2020-07-07 11:18
Roundcube is working and installed correctly on IIS?
Then is should be placed in web.config in roundcube website root
You can also do this with IIS Manager, double click the roundcube site in website list, then select Error pages -> Edit feature settings -> Detailed errors
benio
Post by benio » 2020-07-07 11:19
Ok i found in server log this error:
Zgodnie z ustawieniami uprawnienia właściwe dla aplikacji nie jest udzielane uprawnienie Lokalny Aktywacja do aplikacji serwera COM z identyfikatorem klasy CLSID
{2593F8B9-4EAF-457C-B68A-50F6B8EA6B54}
 i identyfikatorem aplikacji APPID
{15C20B67-12E7-4BB6-92BB-7AFF07997402}
 użytkownikowi SERWER\benio o identyfikatorze zabezpieczeń SID (S-1-5-21-3766784178-3320714209-1226256936-1001) z adresu LocalHost (użycie LRPC) działającemu w kontenerze aplikacji o identyfikatorze SID Niedostępny (Niedostępny). To uprawnienie zabezpieczeń można modyfikować przy użyciu narzędzia administracyjnego Usługi składowe.
I have polisch language but its something about COM permissions.
benio
Post by benio » 2020-07-07 11:24
Yes Roundcube works OK.
I place this and code on web root roundcube .
On server log i recive Distributed COM error
Post by RvdH » 2020-07-07 11:34
OK, in IIS Manager note the roundcube website Application pool name it runs under (we use this later)
Run 'dcomcnfg', Component Services -> Computer -> My Computer -> DCOM Config
Select hMailserver, right click properties -> Security Tab -> Launch and Activation Permissions -> Add -> IIS AppPool\[Application pool name] (replace with your noted name) and check local activation checkbox
benio
Post by benio » 2020-07-07 11:42
Welcome i dont have
 IISAppPool\[Application pool name] and check local activation checkbox
I have only users and built in acounts. Can you send some sreenschot?
Post by RvdH » 2020-07-07 11:50
benio wrote:
2020-07-07 11:42
Welcome i dont have
Oops, missed a space.... you have to type it, example:
IIS AppPool\DefaultAppPool
benio
Post by benio » 2020-07-07 11:56
The same result when i add this settings.
I dont know how i can resolve this problem. i stay 2 days and try but no result.
If you have some time i can make remote acces to my server via team viewier if you want see what is the problem
Post by RvdH » 2020-07-07 12:01
Roundcube makes use of the DefaultAppPool?
Otherwise you have to replace DefaultAppPool with the ApplicationPool it actually runs under (Or visa versa)
benio
Post by benio » 2020-07-07 12:08
Yes Default app Pool
Post by RvdH » 2020-07-07 12:30
Mmm, that is strange, that should be sufficient (it does here)
Have you tried restarting IIS after changing DCOM permissions?
benio
Post by benio » 2020-07-07 13:19
I restart server at Your sugestion but situation are the same. Error on server log:
Post by RvdH » 2020-07-07 19:13
benio wrote:
2020-07-07 13:19
I doubt that is a error related to hmailserver dcom, Google suggest this is a error unrelated to hmailserver, eg:
"The application specific permission settings do not grant Local Activation permission for the COM server application with CLSID
{2593F8B9-4EAF-457C-B68A-50F6B8EA6B54) and appid 15C20B67-12E7-4BB6-92BB-7AFF07997402 from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool
(fix)
How to display IIS detailed error messages on screen, guide: https://www.shanebart.com/enable-iis-de ... -messages/
benio
Post by benio » 2020-07-14 23:34
Welcome again.
I try setup fresxh windows 10 install,enable iis install php ,instal roundcube configure all and configure hamailserver . But situation its the same.
I enable errors from previous FAQ but i recive only error 500. I try setup dom from tutorial not resolve problem.
What is wrong in my case ?
benio
Post by benio » 2020-07-15 08:07
Welcome i found strange difrences.
When i put on local computer
localhost/webmail then i recive error 500 and blank page without any site. But window where i put change password have 3 windows (old password , new password and retype new password)
When i enter remote domain adres on the same local computer http://domain/webmail i recive ERROR page from roundcube "cant change password" but i have only two pass enter fields , without old password.
Maybe this take some directions to resolve problem.
Best regards.
Post by RvdH » 2020-07-15 17:37
i don't know what you are doing, all steps explained above work fine here
As of your last remark, that simply looks like a setting of the password plugin, \plugins\password\config.inc.php
// Password Plugin options
// A driver to use for password change. Default: "sql".
// See README file for list of supported driver names.
$config['password_driver'] = 'hmail';
// Determine whether current password is required to change password.
// Default: false.
$config['password_confirm_current'] = true;
benio
Post by benio » 2020-07-23 23:56
Welcome.
Today i put fresch Win10 installatiion.
I install mariadb and hmailserver with new fresh config.
I install IIs and php by windows platform installer 5.0
I instal roundcube .
I make config roundcube and roundcube config again.
All works ok but password change NOT.
If anyone have time to see my config i can make remote desktop acces for my virtual test maschine to investigate the problem.
On maschine dont have any other software installed.
I try enable this function on 4 fresch instals and not works.
I dont have ideas where i make mistake or where is located problem.
Best regards.
