Code: 10053, Message: An established connection was aborted by the software in your host machine
otronics
Post by otronics » 2020-05-27 17:09
I've been using hMailServer for years and suddenly all mail has stopped sending.
I never use it to receive email.
My set-up hasn't changed. I've tried disabling my firewall and AV software - no difference.
Logs and diagnostics are below.
"DEBUG"	4916	"2020-05-27 15:51:32.762"	"Creating session 195"
"TCPIP"	4916	"2020-05-27 15:51:32.763"	"TCP - 192.168.0.2 connected to 192.168.0.2:25."
"DEBUG"	4916	"2020-05-27 15:51:32.765"	"TCP connection started for session 187"
"SMTPD"	4916	187	"2020-05-27 15:51:32.766"	"192.168.0.2"	"SENT: 220 SERVER ESMTP"
"SMTPD"	4868	187	"2020-05-27 15:51:32.791"	"192.168.0.2"	"RECEIVED: EHLO 192.168.0.2"
"SMTPD"	4868	187	"2020-05-27 15:51:32.792"	"192.168.0.2"	"SENT: 250-SERVER[nl]250-SIZE[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD"	4916	187	"2020-05-27 15:51:32.809"	"192.168.0.2"	"RECEIVED: AUTH LOGIN"
"SMTPD"	4916	187	"2020-05-27 15:51:32.810"	"192.168.0.2"	"SENT: 334 VXNlcm5hbWU6"
"SMTPD"	4908	187	"2020-05-27 15:51:32.827"	"192.168.0.2"	"RECEIVED: ZW1haWxAc2VydmVyLm90cm9uaWNz"
"SMTPD"	4908	187	"2020-05-27 15:51:32.827"	"192.168.0.2"	"SENT: 334 UGFzc3dvcmQ6"
"SMTPD"	4872	187	"2020-05-27 15:51:32.852"	"192.168.0.2"	"RECEIVED: ***"
"SMTPD"	4872	187	"2020-05-27 15:51:32.858"	"192.168.0.2"	"SENT: 235 authenticated."
"SMTPD"	4916	187	"2020-05-27 15:51:32.908"	"192.168.0.2"	"RECEIVED: MAIL FROM:<blackhole@otronics.co.uk>"
"SMTPD"	4916	187	"2020-05-27 15:51:32.914"	"192.168.0.2"	"SENT: 250 OK"
"SMTPD"	4872	187	"2020-05-27 15:51:32.966"	"192.168.0.2"	"RECEIVED: RCPT TO:<communityfm@blueyonder.co.uk>"
"SMTPD"	4872	187	"2020-05-27 15:51:32.970"	"192.168.0.2"	"SENT: 250 OK"
"SMTPD"	4916	187	"2020-05-27 15:51:33.025"	"192.168.0.2"	"RECEIVED: DATA"
"SMTPD"	4916	187	"2020-05-27 15:51:33.026"	"192.168.0.2"	"SENT: 354 OK, send."
"DEBUG"	4872	"2020-05-27 15:51:33.108"	"Adding task AsynchronousTask to work queue Asynchronous task queue"
"DEBUG"	4672	"2020-05-27 15:51:33.109"	"Executing task AsynchronousTask in work queue Asynchronous task queue"
"DEBUG"	4672	"2020-05-27 15:51:33.109"	"Saving message: {FF624747-FBD6-4A88-AF8E-ECBBC5459A85}.eml"
"DEBUG"	4672	"2020-05-27 15:51:33.115"	"Requesting SMTPDeliveryManager to start message delivery"
"SMTPD"	4672	187	"2020-05-27 15:51:33.115"	"192.168.0.2"	"SENT: 250 Queued (0.080 seconds)"
"DEBUG"	4752	"2020-05-27 15:51:33.118"	"Adding task DeliveryTask to work queue SMTP delivery queue"
"DEBUG"	4768	"2020-05-27 15:51:33.120"	"Executing task DeliveryTask in work queue SMTP delivery queue"
"DEBUG"	4768	"2020-05-27 15:51:33.121"	"Delivering message..."
"APPLICATION"	4768	"2020-05-27 15:51:33.141"	"SMTPDeliverer - Message 5942: Delivering message from blackhole@otronics.co.uk to communityfm@blueyonder.co.uk. File: C:\Program Files (x86)\hMailServer\Data\{FF624747-FBD6-4A88-AF8E-ECBBC5459A85}.eml"
"DEBUG"	4768	"2020-05-27 15:51:33.150"	"Applying rules"
"DEBUG"	4768	"2020-05-27 15:51:33.151"	"Performing local delivery"
"DEBUG"	4768	"2020-05-27 15:51:33.152"	"Local delivery completed"
"TCPIP"	4768	"2020-05-27 15:51:33.153"	"DNS MX lookup: blueyonder.co.uk"
"TCPIP"	4768	"2020-05-27 15:51:33.155"	"DNS - MX Result: 1 IP addresses were found."
"DEBUG"	4768	"2020-05-27 15:51:33.156"	"Starting external delivery process. Server: mx.tb.ukmail.iss.as9143.net (212.54.56.11), Port: 25, Security: 2, User name: "
"DEBUG"	4768	"2020-05-27 15:51:33.156"	"Creating session 196"
"TCPIP"	4768	"2020-05-27 15:51:33.156"	"Connecting to 212.54.56.11:25..."
"DEBUG"	4900	"2020-05-27 15:51:33.158"	"TCP connection started for session 196"
"SMTPD"	4900	187	"2020-05-27 15:51:33.175"	"192.168.0.2"	"RECEIVED: QUIT"
"SMTPD"	4900	187	"2020-05-27 15:51:33.176"	"192.168.0.2"	"SENT: 221 goodbye"
"DEBUG"	4912	"2020-05-27 15:51:33.178"	"Ending session 187"
"SMTPC"	4892	196	"2020-05-27 15:51:33.381"	"212.54.56.11"	"RECEIVED: 220 mx2.tb.ukmail.iss.as9143.net mx2.tb.ukmail.iss.as9143.net ESMTP server ready"
"SMTPC"	4892	196	"2020-05-27 15:51:33.387"	"212.54.56.11"	"SENT: EHLO SERVER"
"SMTPC"	4872	196	"2020-05-27 15:51:33.418"	"212.54.56.11"	"RECEIVED: 421 EHLO MXIN201 Your HELO/EHLO SERVER is not matching your DNS configuration cpc123802-trow7-2-0-cust96.18-1.cable.virginm.net ;id=dxP3jd1VmqB1A;sid=dxP3jd1VmqB1A;mta=mx2.tb;d=20200527;t=165133[CET];ipsrc=77.100.200.97;"
"SMTPC"	4872	196	"2020-05-27 15:51:33.419"	"212.54.56.11"	"SENT: HELO SERVER"
"DEBUG"	4872	"2020-05-27 15:51:33.420"	"The read operation failed. Bytes transferred: 0 Remote IP: 212.54.56.11, Session: 196, Code: 10053, Message: An established connection was aborted by the software in your host machine"
"DEBUG"	4872	"2020-05-27 15:51:33.420"	"Ending session 196"
"DEBUG"	4768	"2020-05-27 15:51:33.421"	"External delivery process completed"
"DEBUG"	4768	"2020-05-27 15:51:33.422"	"Summarizing delivery result"
"DEBUG"	4768	"2020-05-27 15:51:33.422"	"Summarized delivery results"
"DEBUG"	4768	"2020-05-27 15:51:33.422"	"SD::RescheduleDelivery_"
"DEBUG"	4768	"2020-05-27 15:51:33.422"	"Retrieving retry options."
"DEBUG"	4768	"2020-05-27 15:51:33.423"	"Starting rescheduling."
"APPLICATION"	4768	"2020-05-27 15:51:33.423"	"SMTPDeliverer - Message 5942: Message could not be delivered. Scheduling it for later delivery in 1 minutes."
"DEBUG"	4768	"2020-05-27 15:51:33.423"	"PersistentMessage::SetNextTryTime()"
"DEBUG"	4768	"2020-05-27 15:51:33.425"	"PersistentMessage::~SetNextTryTime()"
"DEBUG"	4768	"2020-05-27 15:51:33.426"	"Message rescheduled for later delivery."
"APPLICATION"	4768	"2020-05-27 15:51:33.427"	"SMTPDeliverer - Message 5942: Message delivery thread completed."
Test: Collect server details
Database type: MSSQL Compact
Test: Test IPv6
Test: Test outbound port
Connected successfully.
Test: Test backup directory
Backup directory C:\Program Files (x86)\hMailServer\Backup is writable.
Test: Test MX records
Trying to resolve MX records for server.otronics...
ERROR: MX records for domain server.otronics could not be resolved
Test: Test local connect
Connecting to TCP/IP address in MX records for local domain domain server.otronics...
ERROR: MX records for local domain server.otronics could not be resolved
Re: Code: 10053, Message: An established connection was aborted by the software in your host machine
Post by palinka » 2020-05-27 17:41
and
Something is wrong with your dns. Mxtoolbox also reports "Problem getting IP Address for server.otronics.co.uk".
-OR-
Maybe you've always had your DNS set up this way (you said you send only) but recipients are only now starting to reject due to MX not matching.
Either way, fix your dns. Your sender reputation depends on it.
Post by RvdH » 2020-05-27 17:47
Use your Ip address PTR as hostname, if 217.160.231.117 is your ip use clienthosting.eu as hostname setting under SMTP hmailserver
It surprise me you say you never had problems using this setup, i would reject it instantly
Post by palinka » 2020-05-27 20:58
2020-05-27 17:47
Me too.
otronics
Post by otronics » 2020-05-28 02:44
Hello.
Thanks for the replies.
server.otronics isn't a 'real' domain. It's the domain I have created on hMailServer.
I was under the impression hMailServer was self-contained and you didn't need 'real' domains for it to work. Am I wrong?
Post by mattg » 2020-05-28 02:52
you only need real domains if you you are interacting with the rest of the world
if your hmailserver is completely isolated then no real domain needed
if you intend to send or receive mail to the world, then you need to play by the rules, and that includes a real domain
otronics
Post by otronics » 2020-05-28 15:16
2020-05-28 02:52
OK. So how has it worked for years up until now?!
How do I correct this DNS problem....ie/ what setting do I need to change etc?
Thank you.
Post by RvdH » 2020-05-28 16:22
otronics wrote:
2020-05-28 15:16
2020-05-28 02:52
Thank you.
Trouble reading?
I would start with what i told you above, otronics.co.uk resolves to 217.160.231.117, if 217.160.231.117 is really you i would set hostname same as PTR, eg:
2020-05-27 17:47
clienthosting.eu & otronics.co.uk share the same MX records, so that should not be a issue
otronics
Post by otronics » 2020-05-28 18:22
2020-05-28 16:22
otronics wrote:
2020-05-28 15:16
2020-05-28 02:52
Thank you.
Trouble reading?
2020-05-27 17:47
Do you mean use clienthosting.eu under the setting: Settings > SMTP > Delivery of e-mail tab > Local host name?
Post by RvdH » 2020-05-28 22:16
otronics wrote:
2020-05-28 18:22
2020-05-28 16:22
otronics wrote:
2020-05-28 15:16
Thank you.
Trouble reading?
2020-05-27 17:47
You could also use otronics.co.uk, HELO needs to resolve to a at least a valid A-record, but that said... clienthosting.eu is safer as some mailserver/spamchecker also check PTR records
otronics
Post by otronics » 2020-06-03 21:26
2020-05-28 22:16
This has not worked.
I've looked into my domain package and I have set-up an email server there.
Same issue though.
I'm obviously missing something.
Debug:
Test: Test IPv6
SMTP relayer is in use.
Trying to connect to host mail.otronics.co.uk...
ERROR: The host name mail.otronics.co.uk could not be resolved.
johang
Post by johang » 2020-06-03 22:10
the reason why you cant resolve MAIL.otronics.co.uk is because that record has NO IP ( or i should write there is NO mail.otronics.co.uk in DNS )
the record : otronics.co.uk = 217.160.231.117 exists in DNS
so either you add "217.160.231.117 IN A MAIL.otronics.co.uk" in your DNS
or you configure your server to respond to otronics.co.uk
otronics
Post by otronics » 2020-06-04 03:21
johang wrote:
2020-06-03 22:10
Am I adding this line onto my hosting/email provider DNS (who are 1&1)?
johang
Post by johang » 2020-06-04 10:47
otronics wrote:
2020-06-04 03:21
johang wrote:
2020-06-03 22:10
the provider that handles the DNS for your zone otronics.co.uk ( propabally 1&1, or do you buy DNS service from someone else ? )
otronics
Post by otronics » 2020-06-04 17:30
johang wrote:
2020-06-03 22:10
Yes - 1&1 look after my DNS.
Can't get it to work though.
How do I do the other option: "configure your server to respond to otronics.co.uk"?
johang
Post by johang » 2020-06-04 17:34
otronics wrote:
2020-06-04 17:30
johang wrote:
2020-06-03 22:10
you should try again:
with ...
Host Name = mail.otronics.co.uk
ipv4 address = 217.160.231.117
otronics
Post by otronics » 2020-06-04 20:07
DNS record created but hMailServer isn't working.
217.160.231.117 doesn't connect but 1&1's MX server does (mx00.1and1.co.uk)
You'll see the MX record error below.
Turns out my domain/DNS is registered with 1&1 and my hosting is with someone else, so mail.otronics.co.uk isn't correct so can be ignored.
Test: Test IPv6
Trying to connect to host mx00.1and1.co.uk...
Trying to connect to TCP/IP address 212.227.15.41 on port 25.
Received: 554-kundenserver.de (mxeue012) Nemesis ESMTP Service not available.
Trying to resolve MX records for syncback.otronics...
ERROR: MX records for domain syncback.otronics could not be resolved
Connecting to TCP/IP address in MX records for local domain domain syncback.otronics...
ERROR: MX records for local domain syncback.otronics could not be resolved
johang
Post by johang » 2020-06-04 20:28
otronics wrote:
2020-06-04 20:07
Test: Test IPv6
that output does not resemble anything you put on here before... are you just changing settings as you go along ??
what does your SMTP log actually say now regarding sending ?
Post by jimimaseye » 2020-06-04 21:21
....and
wont get you working either.
Post by RvdH » 2020-06-04 21:22
2020-05-27 17:47
All he needed to do was to change the hostname under SMTP settings, as that is the only reason his mail got rejected as shown in the log snip above... even a MX records is not needed as long as otronics.co.uk resolves to a A-Record
otronics
Post by otronics » 2020-06-10 13:28
2020-06-04 21:22
2020-05-27 17:47
What should I change my hostname to?
Using clienthosting.eu generates this lot:
Test: Test IPv6
Trying to connect to host clienthosting.eu...
ERROR: The host name clienthosting.eu could not be resolved.
Post by mattg » 2020-06-10 16:50
In the diagnostic test section leave the domain hmailserver.com
Your hostname is
Settings >> protocols >> SMTP >> Delivery of email >> Local host name
otronics
Post by otronics » 2020-06-10 20:02
2020-06-10 16:50
Your hostname is
Hello.
I guess you meant to change the local host name back to blank.
With no domain selected in diagnostics, it works:
Test: Test IPv6
With my syncback.otronics I have created in hMailServer, this is the result:
Test: Test IPv6
Post by RvdH » 2020-06-10 21:05
Really don't know what you are doing anymore.... you had one simple thing to do
In the first post you stated you never use the hmailserver to receive mail and sorely use it to send mail, why are you so damn persistent to get the diagnostic test to work? (The 'Test MX records' Test is to verify you can receive mail, and guess what...you don't use that!!!)
otronics
Post by otronics » 2020-06-10 21:11
2020-06-10 21:05
In the first post you stated you never use the hmailserver to receive mail and sorely use it to send mail, so why are you damn persistent to get the diagnostic test to work? (The 'Test MX records' Test is to verify you can receive mail, and guess what...you don't use that!!!)
No one has told me about how MX records work until now. I am a beginner.
I assumed 'diagnostics' would be a good place to start to get things working.
I want to send email from my PC to the outside world.
What is this one simple thing I have to do to make it work?
Post by RvdH » 2020-06-10 21:21
otronics wrote:
2020-06-10 21:11
2020-06-10 21:05
otronics wrote:
2020-05-27 17:09
A beginner that has been using hMailServer for years.... :?:
otronics wrote:
2020-06-10 21:11
For real?
otronics
Post by otronics » 2020-06-10 21:44
2020-06-10 21:21
otronics wrote:
2020-06-10 21:11
2020-06-10 21:05
otronics wrote:
2020-05-27 17:09
otronics wrote:
2020-06-10 21:11
For real?
hMailServer was easy to set-up, worked for years and then stopped as we've described and established above.
Yes - there is some kind of DNS issue and I have tried everything above to fix it. How do I fix it?
Post by RvdH » 2020-06-10 22:09
You must be bullshitin me, right?
You identify yourself as 'SERVER' to the outside world, it's a bit hard to get working DNS for something that is not a FQDN...still with me so far?
Therefor I told you (multiple times now) to change your hostname under SMTP settings, and this time not invent another name, but use a name that actually resolves to your ip address! syncback.otronics resolves to nothing, just like 'SERVER'
https://mxtoolbox.com/SuperTool.aspx?ac ... tworktools
otronics
Post by otronics » 2020-06-10 23:24
2020-06-10 22:09
Thank you for your polite reply.
Your 'solution' didn't work but I have figured it out myself.
Post by mattg » 2020-06-11 03:28
otronics wrote:
2020-06-10 20:02
2020-06-10 16:50
Your hostname is
Hello.
No, I did not mean that. I meant what I wrote
I meant that field NEEDS to have the FQDN name placed there
EXACTLY what RvdH has been saying all thread
tunis
Post by tunis » 2020-06-15 11:54
2020-06-11 03:28
otronics wrote:
2020-06-10 20:02
2020-06-10 16:50
Your hostname is
Hello.
You have to change hostname to what it says in the error "cpc123802-trow7-2-0-cust96.18-1.cable.virginm.net"
or ask your ISP to change there dns to your hostname.
Post by RvdH » 2020-06-15 12:08
tunis wrote:
2020-06-15 11:54
2020-06-11 03:28
otronics wrote:
2020-06-10 20:02
Hello.
Ah, yes thats it, nice catch! Missed that piece and the OP never gave answer to and if 217.160.231.117 was the ip actually mailing from
otronics
Post by otronics » 2020-06-16 01:34
tunis wrote:
2020-06-15 11:54
2020-06-11 03:28
otronics wrote:
2020-06-10 20:02
Hello.
Thanks.
This indeed fixed the issue.
