Error when launch WebAdmin
Fasan
Post by Fasan » 2020-05-26 19:27
I downloadet 5.6.7-B2425.16.7z and updated HMS. HMS works fine, but when I launched WebAdmin the browser give the follow error:
The hMailServer version does not match the WebAdmin version.
hMailServer version: 5.6.7-B2425.16
WebAdmin version: 5.6.7-B2425
Please make sure you are using the PHPWebAdmin version which came with your hMailServer installation.
5.6.7-B2425.16.7z contain only 5 files but no WebAdmin. Is there a update for WebAdmin to B2425.16 or what can I do?
Re: Error when launch WebAdmin
Post by RvdH » 2020-05-26 19:41
PHPWebAdmin\include_versioncheck.php
<?php
define('REQUIRED_VERSION', '5.6.7-B2425');
change to
<?php
define('REQUIRED_VERSION', '5.6.7-B2425.16');
Fasan
Post by Fasan » 2020-05-28 11:18
It works, thank you very much! :D
