Send mail from Security Camera to gmail via hMailServer
fromPOK
Post by fromPOK » 2020-03-17 23:31
Hello - Newbie to email server setup.
Have security cameras that send email alerts to gmail account.
I did setup a hmailserver with private domain name (not registered) to collect email on the local hMailServer and send it to my private gmail account.
Log shows everything is successful. Nothing lands in my gmail email.
I have no MX certificates as there is no plan to receive email to this hMailServer.
Please help..
Setup Images:
in attachments
LOG:
"SMTPD" 812 60 "2020-03-17 17:13:39.286" "192.168.29.21" "SENT: 220 gsmtp.gg.lcl ESMTP"
"SMTPD" 4028 60 "2020-03-17 17:13:39.302" "192.168.29.21" "RECEIVED: HELO RC80254D865E"
"SMTPD" 4028 60 "2020-03-17 17:13:39.302" "192.168.29.21" "SENT: 250 Hello."
"SMTPD" 812 60 "2020-03-17 17:13:39.302" "192.168.29.21" "RECEIVED: MAIL FROM: <home.gandham@gmail.com>"
"SMTPD" 812 60 "2020-03-17 17:13:39.317" "192.168.29.21" "SENT: 250 OK"
"SMTPD" 808 60 "2020-03-17 17:13:39.317" "192.168.29.21" "RECEIVED: RCPT TO: <ggandham@gmail.com>"
"SMTPD" 808 60 "2020-03-17 17:13:39.317" "192.168.29.21" "SENT: 250 OK"
"SMTPD" 812 60 "2020-03-17 17:13:39.333" "192.168.29.21" "RECEIVED: RCPT TO: <sridevigandham@gmail.com>"
"SMTPD" 812 60 "2020-03-17 17:13:39.333" "192.168.29.21" "SENT: 250 OK"
"SMTPD" 4028 60 "2020-03-17 17:13:39.349" "192.168.29.21" "RECEIVED: DATA"
"SMTPD" 4028 60 "2020-03-17 17:13:39.349" "192.168.29.21" "SENT: 354 OK, send."
"SMTPD" 4800 60 "2020-03-17 17:13:39.364" "192.168.29.21" "SENT: 250 Queued (0.016 seconds)"
"SMTPD" 812 60 "2020-03-17 17:13:39.380" "192.168.29.21" "RECEIVED: QUIT"
fromPOK
Re: Send mail from Security Camera to gmail via hMailServer
Post by fromPOK » 2020-03-17 23:42
More Images
Post by mattg » 2020-03-18 05:28
A couple of things
Your log, shows your server receibeing the message, not forwarding it to gmail
Look for SMTPC lines following that
ALSO
Your internet IP range should not allow external to external without AUTH, or your machine will be abused by spammers
Run this and show the results please
viewtopic.php?f=20&t=30914
fromPOK
Post by fromPOK » 2020-03-18 16:02
here r the diagnostics.. There is no SMPTC keyword in the whole log file. Thanks for your help.
2020-03-18   Hmailserver: 5.6.7-B2425
DOMAINS
   "Domain1.com" - gg.lcx                         Enabled: True
                   Max size of accounts:    0
        Greylisting:     False
IP RANGES
IP: 192.168.29.0 - 192.168.29.255     Priority: 25     Name: home
     POP3:  False                              Antivirus:  False
     External To External -  True              External To External - False
IP: 0.0.0.0 - 255.255.255.255     Priority: 25     Name: Internet
     POP3:  False                              Antivirus:   True !! ANTIVIRUS NOT CONFIGURED !!
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
                     Port: 587                                           Loop limit:           5
                     Con. Sec.: SSL/TLS
  Routes:
    Domain1.com              - S: Remote  R: Remote - Addr: All         (ok)
POP3
 !! Service Not Enabled !!
IMAP
ANTISPAM
DNSBL ENTRIES:
   No 'enabled' entries
SURBL ENTRIES:
GREYLISTING:
  Greylisting:  False
WHITELISTING
   No entries
  Block Attachments: False
SSL CERTIFICATES
   No entries
SSL/TLS
             SSL 3.0 :  False
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
  Paths:-
    Current:  C:\Program Files (x86)\hMailServer\Logs\hmailserver_2020-03-18.log  - !! NOT PRESENT !!
    Error:    C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2020-03-18.log
                        APPLICATION -      .
                        SMTP        -    True
                        POP3        -      .
                        IMAP        -      .
                        TCPIP       -      .
                        DEBUG       -      .
                        AWSTATS     -      .
SYSTEM TESTS
Database type: MSSQL Compact
Backup directory C:\Users\gsbn\Desktop is writable.
HMAILSERVER.INI
Type=              MSSQLCE
Username=
Port=              0
Server=
Internal=          1
Post by palinka » 2020-03-18 16:43
Do routes use SMTPD or C?
I think the obvious thing to do is check your spam folder on gmail.
IF your message was actually sent (and its not yet clear that's the case, although the log appears to have sent it), then gmail is doing something with it. Likely they're marking it spam. Also, its possible they rejected it but you never received a NDR because you don't have an MX. I'm not sure how that would work - whether it would show up in your log or not.
fromPOK
Post by fromPOK » 2020-03-18 17:29
I am trying to use SMTP
Nothing landed in the gmail spam
What's the difference between SMTPD vs SMTPC
Post by mattg » 2020-03-18 23:40
SMTPD is your server receiving a message
SMTPC is your server connecting to another server to send a message out
Please also run the internal diagnostics in hMailserver, and post the results of those
fromPOK
Post by fromPOK » 2020-03-18 23:53
Mattg - Thank you. Here is the log
Test: Collect server details
Test: Test IPv6
Test: Test outbound port
SMTP relayer is in use.
Trying to connect to host smtp.gmail.com...
Trying to connect to TCP/IP address 173.194.207.109 on port 587.
Received: 220 smtp.gmail.com ESMTP c8sm210643qke.90 - gsmtp.
Connected successfully.
Test: Test backup directory
Test: Test MX records
Trying to resolve MX records for gg.lcl...
ERROR: MX records for domain gg.lcl could not be resolved
Test: Test local connect
Connecting to TCP/IP address in MX records for local domain domain gg.lcl...
ERROR: MX records for local domain gg.lcl could not be resolved
Post by mattg » 2020-03-19 06:11
That looks OK
Rename today's log, Enable all logging, force a message send, wait at least 90 seconds, then post all logs created please
fromPOK
Post by fromPOK » 2020-03-20 15:11
Matt - I figured out the issues. Something to do with gmail port 587 vs 465. If I change port to 465.. the program works.
But the debug screen gives coredump with port 465. with 587 I can get proper debug information. Is this a known issue?
Post by palinka » 2020-03-20 15:14
fromPOK wrote:
2020-03-20 15:11
Yes, this is a known issue - only on port 465. You'll have to test it the old fashioned way - by sending a message and checking the other end to see if it goes through.
Post by mattg » 2020-03-21 00:31
fromPOK wrote:
2020-03-20 15:11
That's ONLY for the diagnostics test screen - affects nothing else
For connections to gMail (SMTPrelayer)
465 is SSL/TLS for connection security
587 is StartTLS Required
I see now that you have that wrong in the diagnostics...
