Clients Can't Connect
bbarbour
Post by bbarbour » 2020-01-09 22:53
I successfully setup hMailServer for the first time. I setup a couple of email accounts. I'm trying to setup a client in MS Outlook 2013. The client computer connects to the server where hMailServer resides just fine. However, the email account connection fails. See attached Outlook.jpg. Perhaps I didn't fill in the fields correctly? I enter the "full" computer name in "Incoming mail server" and "Outgoing mail server." Is the mailserver domain or SQL database supposed to somehow be included in that path? Is the network domain supposed to be in there? I notices after several attempts the client username and the client computer IP showed up as "auto-ban" so I know it's making contact. I removed the auto-ban and tried again. Also, when running the account test in Outlook, it prompts username and password. Is that username and password for the network domain or the mailserver domain? I assume it was for the mailserver domain but I tried it both ways.
Also attached are screen captures of the SQL database, hMailServer accounts, and the diagnostic results in mailserver. I didn't expect the results to pass because the network is isolated from the internet, but I figured it might turn up something.
Re: Clients Can't Connect
Post by mattg » 2020-01-10 00:44
bbarbour
Post by bbarbour » 2020-01-13 21:14
Thanks, but I already read these. Read my comments following each bullet...
General suggestions
If you cannot connect to hMailServer using your email client, the most likely causes are:
• You have not entered the correct e-mail server host name in the account settings in your email client.....This is possible but not likely since I've been double, triple, and multi checking and retyping everything as I scratch my brain wondering what could I be doing wrong.
• The host name you have entered in your email client does not resolve to the IP address of the computer where the email server is running....Perhaps, but I noticed the client listed in the ban list after too many attempts so I must be making contact.
• A firewall is running which blocks traffic to hMailServer. This can be both software and hardware firewalls. Very often server administrators have not opened up the relevant ports (typically 25, 110 and 143) in the Windows XP firewall....Perhaps this was part on the problem. I did notice the Windows firewall was running. I turned off the firewall and reattempted it. No success. Then I turned the firewall back on but made a rule to exclude port 25 since that's the port my SMTP is using.
• Loopback connections is not enabled in the router, so even though you connect to the correct public IP address and the firewall is opened up, your router won't forward the connection to the mail server since you are connecting from inside the network...If this was the case, won't I be also having other issues such as checking files in and out of Vault?
• hMailServer is not listening on the TCP/IP ports. In most cases, this occurs if another email server is running on the same computer as hMailServer. Often server administrators have choosen to install Microsoft IIS SMTP server and then forgotten about it. Telnet your server on the ports 25, 110 and 143 to check whether another server is listening on them...I did install Microsoft IIS SMTP and assigned port 25. I thought I needed to do this prior to setting up a Mail Server such as hMailServer. Could this be my problem? What is recommended to resolve it? I ran "netstat -ab" and saw the hMailServer was listening on port 25 as it should be.
• Your IP address has been banned. Check whther Auto-ban has been enabled in hMailServer. Also check whether there's an auto-ban IP range matching your IP address....This was a problem after too many failed tries so I removed it and disabled auto-ban.
...Also, Vault failed the email test. See attached screen capture. Perhaps that has some relevance to my problem. Vault and hMailServer are on the same computer.
bbarbour
Post by bbarbour » 2020-01-13 21:20
Should I remove the SMTP feature from the IIS server? Will that resolve my problem? Will I then need to reinstall hMailserver?
Post by mattg » 2020-01-13 23:56
You certainly can't have two server software listening on the same port
If your IIS only listens on port 25 (default setup) then yes, you should uninstall it
No need to reinstall hmailsevrer, but you should restart it
I'm not sure though if that is your problem. If it was, hMailserver would give an error when it started
The page I linked too has six steps at the end of that page, asking you to get some logs, and to post them to this forum
Please enable all logging, try to connect again from autodesk, wait until autodesk gives an error, then show ALL logs created by hMailserver
bbarbour
Post by bbarbour » 2020-01-14 15:21
Attached is my log file (1,2,3 of 6). Also, the only reason I setup SMTP was because I read somewhere I needed to set that up for the email server. Vault is the only application on the server other than a license management utility and hMailServer. Vault setup IIS, but not SMTP. If hMailServer sets up SMTP, then it's not a problem to remove it from IIS. I just don't want to remove it if it'll screw up hMailServer. I know NOTHING about setting up an email server and am just learning as I go.
bbarbour
Post by bbarbour » 2020-01-14 15:24
Attached is my log file (4,5,6 of 6).
Post by mattg » 2020-01-14 15:43
Next time please paste the text from the log, rather than screen shots
In the IP range that covers 192.168.125.208 you have the checkbox 'require SSL/TLS for authentication' checked
please untick that and try again
bbarbour
Post by bbarbour » 2020-01-14 17:04
Here are the IP Ranges.
I unchecked "Requires SSL/TLS for authentication" in LAN IP Range.
It was already unchecked in Internet IP Range.
bbarbour
Post by bbarbour » 2020-01-14 17:07
I tried again and failed. Here is the latest Log file after trying again...
"DEBUG" 6976 "2020-01-14 06:40:43.068" "Creating session 59"
"DEBUG" 6976 "2020-01-14 06:40:43.083" "TCP connection started for session 33"
"POP3D" 6976 33 "2020-01-14 06:40:43.083" "192.168.125.208" "SENT: +OK POP3"
"POP3D" 7844 33 "2020-01-14 06:40:43.083" "192.168.125.208" "RECEIVED: CAPA"
"POP3D" 7844 33 "2020-01-14 06:40:43.083" "192.168.125.208" "SENT: +OK CAPA list follows[nl]USER[nl]UIDL[nl]TOP[nl]."
"POP3D" 6976 33 "2020-01-14 06:40:43.083" "192.168.125.208" "RECEIVED: USER b.barbour"
"POP3D" 6976 33 "2020-01-14 06:40:43.099" "192.168.125.208" "SENT: +OK Send your password"
"POP3D" 7844 33 "2020-01-14 06:40:43.099" "192.168.125.208" "RECEIVED: PASS ***"
"POP3D" 7844 33 "2020-01-14 06:40:43.099" "192.168.125.208" "SENT: -ERR Invalid user name or password. Please use full email address as user name."
"DEBUG" 6976 "2020-01-14 06:40:43.099" "The read operation failed. Bytes transferred: 0 Remote IP: 192.168.125.208, Session: 33, Code: 2, Message: End of file"
"DEBUG" 6976 "2020-01-14 06:40:43.099" "Ending session 33"
"DEBUG" 7844 "2020-01-14 06:40:44.927" "Creating session 60"
"DEBUG" 7844 "2020-01-14 06:40:44.927" "TCP connection started for session 58"
"SMTPD" 7844 58 "2020-01-14 06:40:44.927" "192.168.125.208" "SENT: 220 PEF-SERVER2.pef.us.lmco.com ESMTP"
"SMTPD" 3496 58 "2020-01-14 06:40:44.943" "192.168.125.208" "RECEIVED: EHLO PEFWINDEN"
"SMTPD" 3496 58 "2020-01-14 06:40:44.943" "192.168.125.208" "SENT: 250-PEF-SERVER2.pef.us.lmco.com[nl]250-SIZE 20480000[nl]250-AUTH LOGIN PLAIN[nl]250 HELP"
"SMTPD" 7844 58 "2020-01-14 06:40:44.943" "192.168.125.208" "RECEIVED: AUTH LOGIN"
"SMTPD" 7844 58 "2020-01-14 06:40:44.943" "192.168.125.208" "SENT: 334 VXNlcm5hbWU6"
"SMTPD" 3496 58 "2020-01-14 06:40:44.943" "192.168.125.208" "RECEIVED: Yi5iYXJib3Vy"
"SMTPD" 3496 58 "2020-01-14 06:40:44.943" "192.168.125.208" "SENT: 334 UGFzc3dvcmQ6"
"SMTPD" 6976 58 "2020-01-14 06:40:44.943" "192.168.125.208" "RECEIVED: ***"
"SMTPD" 6976 58 "2020-01-14 06:40:44.958" "192.168.125.208" "SENT: 535 Authentication failed. Restarting authentication process."
"DEBUG" 3496 "2020-01-14 06:40:44.958" "The read operation failed. Bytes transferred: 0 Remote IP: 192.168.125.208, Session: 58, Code: 2, Message: End of file"
"DEBUG" 3496 "2020-01-14 06:40:44.958" "Ending session 58"
"DEBUG" 7844 "2020-01-14 06:40:46.005" "Creating session 61"
"DEBUG" 7844 "2020-01-14 06:40:46.005" "TCP connection started for session 60"
"SMTPD" 7844 60 "2020-01-14 06:40:46.005" "192.168.125.208" "SENT: 220 PEF-SERVER2.pef.us.lmco.com ESMTP"
"SMTPD" 6976 60 "2020-01-14 06:40:46.021" "192.168.125.208" "RECEIVED: EHLO PEFWINDEN"
"SMTPD" 6976 60 "2020-01-14 06:40:46.021" "192.168.125.208" "SENT: 250-PEF-SERVER2.pef.us.lmco.com[nl]250-SIZE 20480000[nl]250-AUTH LOGIN PLAIN[nl]250 HELP"
"SMTPD" 7844 60 "2020-01-14 06:40:46.021" "192.168.125.208" "RECEIVED: AUTH LOGIN"
"SMTPD" 7844 60 "2020-01-14 06:40:46.021" "192.168.125.208" "SENT: 334 VXNlcm5hbWU6"
"SMTPD" 3496 60 "2020-01-14 06:40:46.021" "192.168.125.208" "RECEIVED: Yi5iYXJib3Vy"
"SMTPD" 3496 60 "2020-01-14 06:40:46.021" "192.168.125.208" "SENT: 334 UGFzc3dvcmQ6"
"SMTPD" 7844 60 "2020-01-14 06:40:46.021" "192.168.125.208" "RECEIVED: ***"
"SMTPD" 7844 60 "2020-01-14 06:40:46.037" "192.168.125.208" "SENT: 535 Authentication failed. Restarting authentication process."
"DEBUG" 3496 "2020-01-14 06:40:46.037" "The read operation failed. Bytes transferred: 0 Remote IP: 192.168.125.208, Session: 60, Code: 2, Message: End of file"
"DEBUG" 3496 "2020-01-14 06:40:46.037" "Ending session 60"
"DEBUG" 7844 "2020-01-14 06:40:46.693" "Creating session 62"
"DEBUG" 7844 "2020-01-14 06:40:46.708" "TCP connection started for session 61"
"SMTPD" 7844 61 "2020-01-14 06:40:46.708" "192.168.125.208" "SENT: 220 PEF-SERVER2.pef.us.lmco.com ESMTP"
"SMTPD" 6976 61 "2020-01-14 06:40:46.708" "192.168.125.208" "RECEIVED: EHLO PEFWINDEN"
"SMTPD" 6976 61 "2020-01-14 06:40:46.724" "192.168.125.208" "SENT: 250-PEF-SERVER2.pef.us.lmco.com[nl]250-SIZE 20480000[nl]250-AUTH LOGIN PLAIN[nl]250 HELP"
"SMTPD" 7844 61 "2020-01-14 06:40:46.724" "192.168.125.208" "RECEIVED: AUTH LOGIN"
"SMTPD" 7844 61 "2020-01-14 06:40:46.724" "192.168.125.208" "SENT: 334 VXNlcm5hbWU6"
"SMTPD" 3496 61 "2020-01-14 06:40:46.724" "192.168.125.208" "RECEIVED: Yi5iYXJib3Vy"
"SMTPD" 3496 61 "2020-01-14 06:40:46.724" "192.168.125.208" "SENT: 334 UGFzc3dvcmQ6"
"SMTPD" 7844 61 "2020-01-14 06:40:46.724" "192.168.125.208" "RECEIVED: ***"
"SMTPD" 7844 61 "2020-01-14 06:40:46.724" "192.168.125.208" "SENT: 535 Authentication failed. Restarting authentication process."
"DEBUG" 3496 "2020-01-14 06:40:46.740" "The read operation failed. Bytes transferred: 0 Remote IP: 192.168.125.208, Session: 61, Code: 2, Message: End of file"
"DEBUG" 3496 "2020-01-14 06:40:46.740" "Ending session 61"
"DEBUG" 7844 "2020-01-14 06:40:47.162" "Creating session 63"
"DEBUG" 7844 "2020-01-14 06:40:47.177" "TCP connection started for session 62"
"SMTPD" 7844 62 "2020-01-14 06:40:47.177" "192.168.125.208" "SENT: 220 PEF-SERVER2.pef.us.lmco.com ESMTP"
"SMTPD" 6976 62 "2020-01-14 06:40:47.177" "192.168.125.208" "RECEIVED: EHLO PEFWINDEN"
"SMTPD" 6976 62 "2020-01-14 06:40:47.193" "192.168.125.208" "SENT: 250-PEF-SERVER2.pef.us.lmco.com[nl]250-SIZE 20480000[nl]250-AUTH LOGIN PLAIN[nl]250 HELP"
"SMTPD" 3496 62 "2020-01-14 06:40:47.193" "192.168.125.208" "RECEIVED: AUTH LOGIN"
"SMTPD" 3496 62 "2020-01-14 06:40:47.193" "192.168.125.208" "SENT: 334 VXNlcm5hbWU6"
"SMTPD" 7844 62 "2020-01-14 06:40:47.193" "192.168.125.208" "RECEIVED: Yi5iYXJib3Vy"
"SMTPD" 7844 62 "2020-01-14 06:40:47.193" "192.168.125.208" "SENT: 334 UGFzc3dvcmQ6"
"SMTPD" 6976 62 "2020-01-14 06:40:47.193" "192.168.125.208" "RECEIVED: ***"
"SMTPD" 6976 62 "2020-01-14 06:40:47.193" "192.168.125.208" "SENT: 535 Authentication failed. Restarting authentication process."
"DEBUG" 7844 "2020-01-14 06:40:47.208" "The read operation failed. Bytes transferred: 0 Remote IP: 192.168.125.208, Session: 62, Code: 2, Message: End of file"
"DEBUG" 7844 "2020-01-14 06:40:47.208" "Ending session 62"
"DEBUG" 7844 "2020-01-14 06:40:47.568" "Creating session 64"
"DEBUG" 7844 "2020-01-14 06:40:47.568" "TCP connection started for session 63"
"SMTPD" 7844 63 "2020-01-14 06:40:47.568" "192.168.125.208" "SENT: 220 PEF-SERVER2.pef.us.lmco.com ESMTP"
"SMTPD" 6976 63 "2020-01-14 06:40:47.583" "192.168.125.208" "RECEIVED: EHLO PEFWINDEN"
"SMTPD" 6976 63 "2020-01-14 06:40:47.583" "192.168.125.208" "SENT: 250-PEF-SERVER2.pef.us.lmco.com[nl]250-SIZE 20480000[nl]250-AUTH LOGIN PLAIN[nl]250 HELP"
"SMTPD" 7844 63 "2020-01-14 06:40:47.583" "192.168.125.208" "RECEIVED: AUTH LOGIN"
"SMTPD" 7844 63 "2020-01-14 06:40:47.583" "192.168.125.208" "SENT: 334 VXNlcm5hbWU6"
"SMTPD" 6976 63 "2020-01-14 06:40:47.583" "192.168.125.208" "RECEIVED: Yi5iYXJib3Vy"
"SMTPD" 6976 63 "2020-01-14 06:40:47.583" "192.168.125.208" "SENT: 334 UGFzc3dvcmQ6"
"SMTPD" 7844 63 "2020-01-14 06:40:47.583" "192.168.125.208" "RECEIVED: ***"
"SMTPD" 7844 63 "2020-01-14 06:40:47.599" "192.168.125.208" "SENT: 535 Authentication failed. Restarting authentication process."
"DEBUG" 3496 "2020-01-14 06:40:47.599" "The read operation failed. Bytes transferred: 0 Remote IP: 192.168.125.208, Session: 63, Code: 2, Message: End of file"
"DEBUG" 3496 "2020-01-14 06:40:47.599" "Ending session 63"
Post by palinka » 2020-01-14 18:00
bbarbour wrote:
2020-01-14 17:07
bbarbour
Post by bbarbour » 2020-01-14 19:49
That worked! Thank you! The Outlook clients can email each other. However, Vault still can't email. See attached error. What does that message mean? No hMailServer log file was generated on the attempt. I thought what if the SMTP port I entered "25" was causing conflict. I assumed it was asking me what port SMTP was on which is 25? ...but what if it's asking me what port I want Vault to be using and it's causing conflict? I don't know what I'm even talking about. Anyway, I changed it to "110" just to try. That time I got a different error and an hMailServer log file was generated....
"DEBUG" 6976 "2020-01-14 09:05:19.367" "Creating session 83"
"DEBUG" 6976 "2020-01-14 09:05:19.367" "TCP connection started for session 82"
"POP3D" 6976 82 "2020-01-14 09:05:19.367" "127.0.0.1" "SENT: +OK POP3"
"DEBUG" 7844 "2020-01-14 09:05:19.382" "The read operation failed. Bytes transferred: 0 Remote IP: 127.0.0.1, Session: 82, Code: 2, Message: End of file"
"DEBUG" 7844 "2020-01-14 09:05:19.398" "Ending session 82"
bbarbour
Post by bbarbour » 2020-01-14 20:01
The error I got when I changed the SMTP port in Vault to "110" is attached below.
Post by palinka » 2020-01-14 21:55
bbarbour wrote:
2020-01-14 19:49
That's not an smtp session. You messed up your tcpip settings, I think. Run this and post the results: https://www.hmailserver.com/forum/viewt ... 20&t=30914
bbarbour
Post by bbarbour » 2020-01-14 22:59
2020-01-14   Hmailserver: 5.6.7-B2425
DOMAINS
   "Domain1.com" - lmxx.pex                       Enabled: True
                   Max size of accounts:    0
        Greylisting:     False
GLOBAL RULES
IP RANGES
IP: 0.0.0.0 - 255.255.255.255     Priority: 20     Name: LAN
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
  Autoban Enabled: False
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
        Loop limit:           5
        Recipient hosts:     15
  Routes:
     No routes defined.
POP3
  No. Connections: 0
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
DNSBL ENTRIES:
   No 'enabled' entries
SURBL ENTRIES:
GREYLISTING:
  Greylisting:  False
WHITELISTING
   No entries
  Block Attachments: False
SSL CERTIFICATES
   No entries
SSL/TLS
             SSL 3.0 :  False
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
  Paths:-
    Current:  C:\Program Files (x86)\hMailServer\Logs\hmailserver_2020-01-14.log
    Error:    C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2020-01-14.log
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -    True
                        IMAP        -    True
                        TCPIP       -      .
                        DEBUG       -    True
                        AWSTATS     -      .
SYSTEM TESTS
Database type: MSSQL
HMAILSERVER.INI
Database folder:
Type=              MSSQL
Username=
Port=              0
Server=            PEF-SERVER2\MAILSERVER
Internal=          0
Post by mattg » 2020-01-14 23:20
bbarbour wrote:
2020-01-14 20:01
Port 110 is standard POP3 port
You still have it set as pop3 in hMailserver
Assuming that your vault is now sending DIRECT to hMailserver without IIS SMTP
Add another UNUSED port there (in TCP/IP ports), remove port 25 if that is your plan, and change your Vault settings to the same custom port
If you will still be using say the pickup directory of IIS SMTP, then change the outgoing port in IIS SMTP to match your hmailserver custom port and leave vault alone
bbarbour
Post by bbarbour » 2020-01-14 23:41
Can I set Vault SMTP to 25 as shown below? If so, than why am I getting that error and it doesn't generate a hMailServer log? Also I attached a screen capture of my SMTP settings in IIS manager. Is that causing a conflict by using port 25? Again, I only set that up because I thought that needed to be setup prior to installing hMailServer. I thought SMTP was a central component installed through the Server Manager and setup in the IIS Manager and used by hMailServer and referenced in the Vault email settings. Therefore one SMTP on one computer with one email server uses one port that I set to 25. Perhaps I'm picturing SMTP all wrong?
Post by Dravion » 2020-01-15 00:51
A Email server without Port 25 is completely useless.
127.0.01 is only your local Loopbacl Adapter ab no outside Computer can access 127.0.0.1 from another Computers.
Port 587 and Port 110 POP3 / Imap 143 is required to maje Email Clients work.
Dont install hMailServer if another Email Server is installed allready it will fail.
Forgot IIS Manager, you dont need it to make hMailServer work.
Post by mattg » 2020-01-15 08:25
In your IP ranges, you have created a LAN range 0.0.0.0 to 255.255.255.255 with priority 20
This is the INTERNET range of IP addresses and will override any other IP ranges
On the IP Ranges page in hMailserver push the 'default' button which will set MY COmputer and Internet
Make sure that the 'My computer range' doesn't have 'use sssl to secure the connection' checked - make sure that is UNCHECKED
Try to test again from your vault
Post by Dravion » 2020-01-15 08:52
To make it easy for you
Just reset your ip ranges to normal, this will make sure you can access hMailServer SMTP (25), SMTP (587) and IMAP (143) via
127.0.0.1 and your local ip network card ip addresses (0.0.0.0).
After it, open a Windows Administrator Command prompt and type in
dism /online /enable-feature /featurename:TelnetClient /all
and after it type:
telnet 127.0.0.1 25
hMailServer should respond with a 220 Ready code like this
220 smtp.dravionsrealm.net ESMTP
Now try your LAN IP address
(something like this)
telnet 192.168.x.x 25
If you get a 220 code as response from hMailServer, everything is ok.
PS:
Dont forget to add firewall rules for Ports 25,110, 143 and 587 Inbound and Outbound or its not possible to access hMailServer from
another Computer in your Office.
If you dont know how to do it, follow this hMailServer specific Windows Firewall Guide:
https://www.hmailserver.com/forum/viewt ... 21&t=32867
Post by mattg » 2020-01-15 09:13
Dravion wrote:
2020-01-15 08:52
Nope
That image is TCP/IP settings
I want the default button for IP ranges pressed
Post by Dravion » 2020-01-15 09:36
Correct Mattg.
You also should go to the ipranges section and press the default button there as well, this should do the trick.
Post by jimimaseye » 2020-01-15 10:12
Dravion wrote:
2020-01-15 00:51
No it's not. False.
I had a mail server running for 8 years and didn't receive any live mail on port 25. And sending didn't use port 25 (it sends on a random port bound for port 25 on the receiving server).
(External download. Smtp port 587.)
Post by Dravion » 2020-01-15 10:46
2020-01-15 10:12
Dravion wrote:
2020-01-15 00:51
No it's not. False.
In this case, you run hMailServer not as primary MX.
You should say, you run it with the help of an Relayserver, not as Internet site Mailserver (and this is the primary main purpose of an MTA)
ara
Post by ara » 2020-01-15 11:58
The user name must contain a domain name :D
bbarbour
Post by bbarbour » 2020-01-15 15:20
Dravion and Mattg,
I followed your instructions and restored defaults for both "IP Ranges" and "TCP/IP ports." Then I wrote the Windows Firewall rules as instructed in your link, but I only typed the netsh lines under SMTP and not the Submission, SMTPS, IMAPS, or POP3S because I was unsure if those would apply. Please let me know if otherwise. then I...
and after it type:
telnet 127.0.0.1 25
...and it failed. See attached.
Post by Dravion » 2020-01-15 16:00
Ok, first check, if hMailServer Service is running
1) Open Windows Admin Command prompt and type in
sc query hmailserver
Result should look like this:
SERVICE_NAME: hmailserver
TYPE : 10 WIN32_OWN_PROCESS
STATE : 4 RUNNING
(STOPPABLE, NOT_PAUSABLE, ACCEPTS_SHUTDOWN)
WIN32_EXIT_CODE : 0 (0x0)
SERVICE_EXIT_CODE : 0 (0x0)
CHECKPOINT : 0x0
WAIT_HINT : 0x0
Next check if your Database server is running.
If you can run hMailAdmin, check all boxes for logging and Stop / Restart hMailServer Windows service, take
a look in hMailServers log folder and attach your logfiles in your next reply.
bbarbour
Post by bbarbour » 2020-01-15 16:23
I got these results...
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
Here's my log...
"DEBUG"	6976	"2020-01-15 00:22:08.233"	"Creating session 124"
"DEBUG"	6976	"2020-01-15 00:22:08.233"	"TCP connection started for session 123"
"POP3D"	6976	123	"2020-01-15 00:22:08.233"	"192.168.125.206"	"SENT: +OK POP3"
"POP3D"	7844	123	"2020-01-15 00:22:08.249"	"192.168.125.206"	"RECEIVED: CAPA"
"POP3D"	7844	123	"2020-01-15 00:22:08.249"	"192.168.125.206"	"SENT: +OK CAPA list follows[nl]USER[nl]UIDL[nl]TOP[nl]."
"POP3D"	6976	123	"2020-01-15 00:22:08.249"	"192.168.125.206"	"RECEIVED: USER l.prinkey@lmco.pef"
"POP3D"	6976	123	"2020-01-15 00:22:08.249"	"192.168.125.206"	"SENT: +OK Send your password"
"POP3D"	7844	123	"2020-01-15 00:22:08.249"	"192.168.125.206"	"RECEIVED: PASS ***"
"POP3D"	7844	123	"2020-01-15 00:22:08.264"	"192.168.125.206"	"SENT: +OK Mailbox locked and ready"
"POP3D"	5948	123	"2020-01-15 00:22:08.264"	"192.168.125.206"	"RECEIVED: STAT"
"POP3D"	5948	123	"2020-01-15 00:22:08.264"	"192.168.125.206"	"SENT: +OK 3 3853"
"POP3D"	7844	123	"2020-01-15 00:22:08.280"	"192.168.125.206"	"RECEIVED: UIDL"
"POP3D"	7844	123	"2020-01-15 00:22:08.280"	"192.168.125.206"	"SENT: +OK 3 messages (3853 octets)[nl]1 1[nl]2 2[nl]3 3[nl]."
"POP3D"	5948	123	"2020-01-15 00:22:08.280"	"192.168.125.206"	"RECEIVED: LIST"
"POP3D"	5948	123	"2020-01-15 00:22:08.280"	"192.168.125.206"	"SENT: +OK 3 messages (3853 octets)"
"POP3D"	5948	123	"2020-01-15 00:22:08.280"	"192.168.125.206"	"SENT: 1 611[nl]2 611[nl]3 2631[nl]."
"POP3D"	5948	123	"2020-01-15 00:22:08.483"	"192.168.125.206"	"RECEIVED: QUIT"
"POP3D"	5948	123	"2020-01-15 00:22:08.483"	"192.168.125.206"	"SENT: +OK POP3 server saying goodbye..."
"DEBUG"	6976	"2020-01-15 00:22:08.483"	"Ending session 123"
"DEBUG"	6976	"2020-01-15 00:52:10.164"	"Creating session 125"
"DEBUG"	6976	"2020-01-15 00:52:10.164"	"TCP connection started for session 124"
"POP3D"	6976	124	"2020-01-15 00:52:10.164"	"192.168.125.206"	"SENT: +OK POP3"
"POP3D"	7844	124	"2020-01-15 00:52:10.180"	"192.168.125.206"	"RECEIVED: CAPA"
"POP3D"	7844	124	"2020-01-15 00:52:10.180"	"192.168.125.206"	"SENT: +OK CAPA list follows[nl]USER[nl]UIDL[nl]TOP[nl]."
"POP3D"	6976	124	"2020-01-15 00:52:10.180"	"192.168.125.206"	"RECEIVED: USER l.prinkey@lmco.pef"
"POP3D"	6976	124	"2020-01-15 00:52:10.180"	"192.168.125.206"	"SENT: +OK Send your password"
"POP3D"	7844	124	"2020-01-15 00:52:10.180"	"192.168.125.206"	"RECEIVED: PASS ***"
"POP3D"	7844	124	"2020-01-15 00:52:10.211"	"192.168.125.206"	"SENT: +OK Mailbox locked and ready"
"POP3D"	6976	124	"2020-01-15 00:52:10.226"	"192.168.125.206"	"RECEIVED: STAT"
"POP3D"	6976	124	"2020-01-15 00:52:10.226"	"192.168.125.206"	"SENT: +OK 3 3853"
"POP3D"	7844	124	"2020-01-15 00:52:10.226"	"192.168.125.206"	"RECEIVED: UIDL"
"POP3D"	7844	124	"2020-01-15 00:52:10.242"	"192.168.125.206"	"SENT: +OK 3 messages (3853 octets)[nl]1 1[nl]2 2[nl]3 3[nl]."
"POP3D"	6976	124	"2020-01-15 00:52:10.242"	"192.168.125.206"	"RECEIVED: LIST"
"POP3D"	6976	124	"2020-01-15 00:52:10.242"	"192.168.125.206"	"SENT: +OK 3 messages (3853 octets)"
"POP3D"	6976	124	"2020-01-15 00:52:10.242"	"192.168.125.206"	"SENT: 1 611[nl]2 611[nl]3 2631[nl]."
"POP3D"	6976	124	"2020-01-15 00:52:10.445"	"192.168.125.206"	"RECEIVED: QUIT"
"POP3D"	6976	124	"2020-01-15 00:52:10.445"	"192.168.125.206"	"SENT: +OK POP3 server saying goodbye..."
"DEBUG"	5948	"2020-01-15 00:52:10.445"	"Ending session 124"
"DEBUG"	6976	"2020-01-15 01:22:12.003"	"Creating session 126"
"DEBUG"	6976	"2020-01-15 01:22:12.003"	"TCP connection started for session 125"
"POP3D"	6976	125	"2020-01-15 01:22:12.003"	"192.168.125.206"	"SENT: +OK POP3"
"POP3D"	7844	125	"2020-01-15 01:22:12.003"	"192.168.125.206"	"RECEIVED: CAPA"
"POP3D"	7844	125	"2020-01-15 01:22:12.003"	"192.168.125.206"	"SENT: +OK CAPA list follows[nl]USER[nl]UIDL[nl]TOP[nl]."
"POP3D"	6976	125	"2020-01-15 01:22:12.003"	"192.168.125.206"	"RECEIVED: USER l.prinkey@lmco.pef"
"POP3D"	6976	125	"2020-01-15 01:22:12.019"	"192.168.125.206"	"SENT: +OK Send your password"
"POP3D"	7844	125	"2020-01-15 01:22:12.019"	"192.168.125.206"	"RECEIVED: PASS ***"
"POP3D"	7844	125	"2020-01-15 01:22:12.019"	"192.168.125.206"	"SENT: +OK Mailbox locked and ready"
"POP3D"	6976	125	"2020-01-15 01:22:12.034"	"192.168.125.206"	"RECEIVED: STAT"
"POP3D"	6976	125	"2020-01-15 01:22:12.034"	"192.168.125.206"	"SENT: +OK 3 3853"
"POP3D"	7844	125	"2020-01-15 01:22:12.034"	"192.168.125.206"	"RECEIVED: UIDL"
"POP3D"	7844	125	"2020-01-15 01:22:12.034"	"192.168.125.206"	"SENT: +OK 3 messages (3853 octets)[nl]1 1[nl]2 2[nl]3 3[nl]."
"POP3D"	5948	125	"2020-01-15 01:22:12.034"	"192.168.125.206"	"RECEIVED: LIST"
"POP3D"	5948	125	"2020-01-15 01:22:12.034"	"192.168.125.206"	"SENT: +OK 3 messages (3853 octets)"
"POP3D"	5948	125	"2020-01-15 01:22:12.050"	"192.168.125.206"	"SENT: 1 611[nl]2 611[nl]3 2631[nl]."
"POP3D"	6976	125	"2020-01-15 01:22:12.237"	"192.168.125.206"	"RECEIVED: QUIT"
"POP3D"	6976	125	"2020-01-15 01:22:12.237"	"192.168.125.206"	"SENT: +OK POP3 server saying goodbye..."
"DEBUG"	7844	"2020-01-15 01:22:12.237"	"Ending session 125"
"DEBUG"	6976	"2020-01-15 01:52:13.870"	"Creating session 127"
"DEBUG"	6976	"2020-01-15 01:52:13.870"	"TCP connection started for session 126"
"POP3D"	6976	126	"2020-01-15 01:52:13.870"	"192.168.125.206"	"SENT: +OK POP3"
"POP3D"	5948	126	"2020-01-15 01:52:13.886"	"192.168.125.206"	"RECEIVED: CAPA"
"POP3D"	5948	126	"2020-01-15 01:52:13.886"	"192.168.125.206"	"SENT: +OK CAPA list follows[nl]USER[nl]UIDL[nl]TOP[nl]."
"POP3D"	6976	126	"2020-01-15 01:52:13.886"	"192.168.125.206"	"RECEIVED: USER l.prinkey@lmco.pef"
"POP3D"	6976	126	"2020-01-15 01:52:13.886"	"192.168.125.206"	"SENT: +OK Send your password"
"POP3D"	7844	126	"2020-01-15 01:52:13.886"	"192.168.125.206"	"RECEIVED: PASS ***"
"POP3D"	7844	126	"2020-01-15 01:52:13.886"	"192.168.125.206"	"SENT: +OK Mailbox locked and ready"
"POP3D"	5948	126	"2020-01-15 01:52:13.902"	"192.168.125.206"	"RECEIVED: STAT"
"POP3D"	5948	126	"2020-01-15 01:52:13.902"	"192.168.125.206"	"SENT: +OK 3 3853"
"POP3D"	7844	126	"2020-01-15 01:52:13.902"	"192.168.125.206"	"RECEIVED: UIDL"
"POP3D"	7844	126	"2020-01-15 01:52:13.917"	"192.168.125.206"	"SENT: +OK 3 messages (3853 octets)[nl]1 1[nl]2 2[nl]3 3[nl]."
"POP3D"	5948	126	"2020-01-15 01:52:13.917"	"192.168.125.206"	"RECEIVED: LIST"
"POP3D"	5948	126	"2020-01-15 01:52:13.917"	"192.168.125.206"	"SENT: +OK 3 messages (3853 octets)"
"POP3D"	5948	126	"2020-01-15 01:52:13.917"	"192.168.125.206"	"SENT: 1 611[nl]2 611[nl]3 2631[nl]."
"POP3D"	5948	126	"2020-01-15 01:52:14.120"	"192.168.125.206"	"RECEIVED: QUIT"
"POP3D"	5948	126	"2020-01-15 01:52:14.120"	"192.168.125.206"	"SENT: +OK POP3 server saying goodbye..."
"DEBUG"	6976	"2020-01-15 01:52:14.120"	"Ending session 126"
"DEBUG"	6976	"2020-01-15 02:22:15.740"	"Creating session 128"
"DEBUG"	6976	"2020-01-15 02:22:15.756"	"TCP connection started for session 127"
"POP3D"	6976	127	"2020-01-15 02:22:15.756"	"192.168.125.206"	"SENT: +OK POP3"
"POP3D"	7844	127	"2020-01-15 02:22:15.756"	"192.168.125.206"	"RECEIVED: CAPA"
"POP3D"	7844	127	"2020-01-15 02:22:15.756"	"192.168.125.206"	"SENT: +OK CAPA list follows[nl]USER[nl]UIDL[nl]TOP[nl]."
"POP3D"	6976	127	"2020-01-15 02:22:15.756"	"192.168.125.206"	"RECEIVED: USER l.prinkey@lmco.pef"
"POP3D"	6976	127	"2020-01-15 02:22:15.756"	"192.168.125.206"	"SENT: +OK Send your password"
"POP3D"	5948	127	"2020-01-15 02:22:15.756"	"192.168.125.206"	"RECEIVED: PASS ***"
"POP3D"	5948	127	"2020-01-15 02:22:15.771"	"192.168.125.206"	"SENT: +OK Mailbox locked and ready"
"POP3D"	6976	127	"2020-01-15 02:22:15.787"	"192.168.125.206"	"RECEIVED: STAT"
"POP3D"	6976	127	"2020-01-15 02:22:15.787"	"192.168.125.206"	"SENT: +OK 3 3853"
"POP3D"	5948	127	"2020-01-15 02:22:15.787"	"192.168.125.206"	"RECEIVED: UIDL"
"POP3D"	5948	127	"2020-01-15 02:22:15.787"	"192.168.125.206"	"SENT: +OK 3 messages (3853 octets)[nl]1 1[nl]2 2[nl]3 3[nl]."
"POP3D"	6976	127	"2020-01-15 02:22:15.787"	"192.168.125.206"	"RECEIVED: LIST"
"POP3D"	6976	127	"2020-01-15 02:22:15.787"	"192.168.125.206"	"SENT: +OK 3 messages (3853 octets)"
"POP3D"	6976	127	"2020-01-15 02:22:15.787"	"192.168.125.206"	"SENT: 1 611[nl]2 611[nl]3 2631[nl]."
"POP3D"	6976	127	"2020-01-15 02:22:15.990"	"192.168.125.206"	"RECEIVED: QUIT"
"POP3D"	6976	127	"2020-01-15 02:22:15.990"	"192.168.125.206"	"SENT: +OK POP3 server saying goodbye..."
"DEBUG"	5948	"2020-01-15 02:22:15.990"	"Ending session 127"
"DEBUG"	6976	"2020-01-15 02:52:17.614"	"Creating session 129"
"DEBUG"	6976	"2020-01-15 02:52:17.630"	"TCP connection started for session 128"
"POP3D"	6976	128	"2020-01-15 02:52:17.630"	"192.168.125.206"	"SENT: +OK POP3"
"POP3D"	7844	128	"2020-01-15 02:52:17.630"	"192.168.125.206"	"RECEIVED: CAPA"
"POP3D"	7844	128	"2020-01-15 02:52:17.630"	"192.168.125.206"	"SENT: +OK CAPA list follows[nl]USER[nl]UIDL[nl]TOP[nl]."
"POP3D"	6976	128	"2020-01-15 02:52:17.630"	"192.168.125.206"	"RECEIVED: USER l.prinkey@lmco.pef"
"POP3D"	6976	128	"2020-01-15 02:52:17.630"	"192.168.125.206"	"SENT: +OK Send your password"
"POP3D"	5948	128	"2020-01-15 02:52:17.630"	"192.168.125.206"	"RECEIVED: PASS ***"
"POP3D"	5948	128	"2020-01-15 02:52:17.646"	"192.168.125.206"	"SENT: +OK Mailbox locked and ready"
"POP3D"	7844	128	"2020-01-15 02:52:17.661"	"192.168.125.206"	"RECEIVED: STAT"
"POP3D"	7844	128	"2020-01-15 02:52:17.661"	"192.168.125.206"	"SENT: +OK 3 3853"
"POP3D"	6976	128	"2020-01-15 02:52:17.661"	"192.168.125.206"	"RECEIVED: UIDL"
"POP3D"	6976	128	"2020-01-15 02:52:17.661"	"192.168.125.206"	"SENT: +OK 3 messages (3853 octets)[nl]1 1[nl]2 2[nl]3 3[nl]."
"POP3D"	7844	128	"2020-01-15 02:52:17.661"	"192.168.125.206"	"RECEIVED: LIST"
"POP3D"	7844	128	"2020-01-15 02:52:17.661"	"192.168.125.206"	"SENT: +OK 3 messages (3853 octets)"
"POP3D"	7844	128	"2020-01-15 02:52:17.661"	"192.168.125.206"	"SENT: 1 611[nl]2 611[nl]3 2631[nl]."
"POP3D"	7844	128	"2020-01-15 02:52:17.864"	"192.168.125.206"	"RECEIVED: QUIT"
"POP3D"	7844	128	"2020-01-15 02:52:17.880"	"192.168.125.206"	"SENT: +OK POP3 server saying goodbye..."
"DEBUG"	5948	"2020-01-15 02:52:17.880"	"Ending session 128"
"DEBUG"	6976	"2020-01-15 03:22:19.491"	"Creating session 130"
"DEBUG"	6976	"2020-01-15 03:22:19.491"	"TCP connection started for session 129"
"POP3D"	6976	129	"2020-01-15 03:22:19.506"	"192.168.125.206"	"SENT: +OK POP3"
"POP3D"	7844	129	"2020-01-15 03:22:19.506"	"192.168.125.206"	"RECEIVED: CAPA"
"POP3D"	7844	129	"2020-01-15 03:22:19.506"	"192.168.125.206"	"SENT: +OK CAPA list follows[nl]USER[nl]UIDL[nl]TOP[nl]."
"POP3D"	6976	129	"2020-01-15 03:22:19.506"	"192.168.125.206"	"RECEIVED: USER l.prinkey@lmco.pef"
"POP3D"	6976	129	"2020-01-15 03:22:19.506"	"192.168.125.206"	"SENT: +OK Send your password"
"POP3D"	7844	129	"2020-01-15 03:22:19.506"	"192.168.125.206"	"RECEIVED: PASS ***"
"POP3D"	7844	129	"2020-01-15 03:22:19.522"	"192.168.125.206"	"SENT: +OK Mailbox locked and ready"
"POP3D"	6976	129	"2020-01-15 03:22:19.537"	"192.168.125.206"	"RECEIVED: STAT"
"POP3D"	6976	129	"2020-01-15 03:22:19.537"	"192.168.125.206"	"SENT: +OK 3 3853"
"POP3D"	7844	129	"2020-01-15 03:22:19.537"	"192.168.125.206"	"RECEIVED: UIDL"
"POP3D"	7844	129	"2020-01-15 03:22:19.537"	"192.168.125.206"	"SENT: +OK 3 messages (3853 octets)[nl]1 1[nl]2 2[nl]3 3[nl]."
"POP3D"	6976	129	"2020-01-15 03:22:19.537"	"192.168.125.206"	"RECEIVED: LIST"
"POP3D"	6976	129	"2020-01-15 03:22:19.537"	"192.168.125.206"	"SENT: +OK 3 messages (3853 octets)"
"POP3D"	6976	129	"2020-01-15 03:22:19.537"	"192.168.125.206"	"SENT: 1 611[nl]2 611[nl]3 2631[nl]."
"POP3D"	6976	129	"2020-01-15 03:22:19.741"	"192.168.125.206"	"RECEIVED: QUIT"
"POP3D"	6976	129	"2020-01-15 03:22:19.741"	"192.168.125.206"	"SENT: +OK POP3 server saying goodbye..."
"DEBUG"	5948	"2020-01-15 03:22:19.741"	"Ending session 129"
"DEBUG"	6976	"2020-01-15 03:52:21.373"	"Creating session 131"
"DEBUG"	6976	"2020-01-15 03:52:21.373"	"TCP connection started for session 130"
"POP3D"	6976	130	"2020-01-15 03:52:21.373"	"192.168.125.206"	"SENT: +OK POP3"
"POP3D"	7844	130	"2020-01-15 03:52:21.373"	"192.168.125.206"	"RECEIVED: CAPA"
"POP3D"	7844	130	"2020-01-15 03:52:21.389"	"192.168.125.206"	"SENT: +OK CAPA list follows[nl]USER[nl]UIDL[nl]TOP[nl]."
"POP3D"	6976	130	"2020-01-15 03:52:21.389"	"192.168.125.206"	"RECEIVED: USER l.prinkey@lmco.pef"
"POP3D"	6976	130	"2020-01-15 03:52:21.389"	"192.168.125.206"	"SENT: +OK Send your password"
"POP3D"	7844	130	"2020-01-15 03:52:21.389"	"192.168.125.206"	"RECEIVED: PASS ***"
"POP3D"	7844	130	"2020-01-15 03:52:21.389"	"192.168.125.206"	"SENT: +OK Mailbox locked and ready"
"POP3D"	6976	130	"2020-01-15 03:52:21.404"	"192.168.125.206"	"RECEIVED: STAT"
"POP3D"	6976	130	"2020-01-15 03:52:21.404"	"192.168.125.206"	"SENT: +OK 3 3853"
"POP3D"	7844	130	"2020-01-15 03:52:21.404"	"192.168.125.206"	"RECEIVED: UIDL"
"POP3D"	7844	130	"2020-01-15 03:52:21.420"	"192.168.125.206"	"SENT: +OK 3 messages (3853 octets)[nl]1 1[nl]2 2[nl]3 3[nl]."
"POP3D"	6976	130	"2020-01-15 03:52:21.420"	"192.168.125.206"	"RECEIVED: LIST"
"POP3D"	6976	130	"2020-01-15 03:52:21.420"	"192.168.125.206"	"SENT: +OK 3 messages (3853 octets)"
"POP3D"	6976	130	"2020-01-15 03:52:21.420"	"192.168.125.206"	"SENT: 1 611[nl]2 611[nl]3 2631[nl]."
"POP3D"	6976	130	"2020-01-15 03:52:21.623"	"192.168.125.206"	"RECEIVED: QUIT"
"POP3D"	6976	130	"2020-01-15 03:52:21.623"	"192.168.125.206"	"SENT: +OK POP3 server saying goodbye..."
"DEBUG"	5948	"2020-01-15 03:52:21.623"	"Ending session 130"
"DEBUG"	6976	"2020-01-15 04:22:23.288"	"Creating session 132"
"DEBUG"	6976	"2020-01-15 04:22:23.288"	"TCP connection started for session 131"
"POP3D"	6976	131	"2020-01-15 04:22:23.288"	"192.168.125.206"	"SENT: +OK POP3"
"POP3D"	7844	131	"2020-01-15 04:22:23.288"	"192.168.125.206"	"RECEIVED: CAPA"
"POP3D"	7844	131	"2020-01-15 04:22:23.303"	"192.168.125.206"	"SENT: +OK CAPA list follows[nl]USER[nl]UIDL[nl]TOP[nl]."
"POP3D"	6976	131	"2020-01-15 04:22:23.303"	"192.168.125.206"	"RECEIVED: USER l.prinkey@lmco.pef"
"POP3D"	6976	131	"2020-01-15 04:22:23.303"	"192.168.125.206"	"SENT: +OK Send your password"
"POP3D"	5948	131	"2020-01-15 04:22:23.303"	"192.168.125.206"	"RECEIVED: PASS ***"
"POP3D"	5948	131	"2020-01-15 04:22:23.303"	"192.168.125.206"	"SENT: +OK Mailbox locked and ready"
"POP3D"	7844	131	"2020-01-15 04:22:23.319"	"192.168.125.206"	"RECEIVED: STAT"
"POP3D"	7844	131	"2020-01-15 04:22:23.319"	"192.168.125.206"	"SENT: +OK 3 3853"
"POP3D"	5948	131	"2020-01-15 04:22:23.319"	"192.168.125.206"	"RECEIVED: UIDL"
"POP3D"	5948	131	"2020-01-15 04:22:23.335"	"192.168.125.206"	"SENT: +OK 3 messages (3853 octets)[nl]1 1[nl]2 2[nl]3 3[nl]."
"POP3D"	7844	131	"2020-01-15 04:22:23.335"	"192.168.125.206"	"RECEIVED: LIST"
"POP3D"	7844	131	"2020-01-15 04:22:23.335"	"192.168.125.206"	"SENT: +OK 3 messages (3853 octets)"
"POP3D"	7844	131	"2020-01-15 04:22:23.335"	"192.168.125.206"	"SENT: 1 611[nl]2 611[nl]3 2631[nl]."
"POP3D"	7844	131	"2020-01-15 04:22:23.538"	"192.168.125.206"	"RECEIVED: QUIT"
"POP3D"	7844	131	"2020-01-15 04:22:23.538"	"192.168.125.206"	"SENT: +OK POP3 server saying goodbye..."
"DEBUG"	5948	"2020-01-15 04:22:23.538"	"Ending session 131"
"DEBUG"	6976	"2020-01-15 04:52:25.490"	"Creating session 133"
"DEBUG"	6976	"2020-01-15 04:52:25.505"	"TCP connection started for session 132"
"POP3D"	6976	132	"2020-01-15 04:52:25.505"	"192.168.125.206"	"SENT: +OK POP3"
"POP3D"	7844	132	"2020-01-15 04:52:25.505"	"192.168.125.206"	"RECEIVED: CAPA"
"POP3D"	7844	132	"2020-01-15 04:52:25.505"	"192.168.125.206"	"SENT: +OK CAPA list follows[nl]USER[nl]UIDL[nl]TOP[nl]."
"POP3D"	6976	132	"2020-01-15 04:52:25.505"	"192.168.125.206"	"RECEIVED: USER l.prinkey@lmco.pef"
"POP3D"	6976	132	"2020-01-15 04:52:25.505"	"192.168.125.206"	"SENT: +OK Send your password"
"POP3D"	7844	132	"2020-01-15 04:52:25.505"	"192.168.125.206"	"RECEIVED: PASS ***"
"POP3D"	7844	132	"2020-01-15 04:52:25.521"	"192.168.125.206"	"SENT: +OK Mailbox locked and ready"
"POP3D"	6976	132	"2020-01-15 04:52:25.537"	"192.168.125.206"	"RECEIVED: STAT"
"POP3D"	6976	132	"2020-01-15 04:52:25.537"	"192.168.125.206"	"SENT: +OK 3 3853"
"POP3D"	7844	132	"2020-01-15 04:52:25.537"	"192.168.125.206"	"RECEIVED: UIDL"
"POP3D"	7844	132	"2020-01-15 04:52:25.537"	"192.168.125.206"	"SENT: +OK 3 messages (3853 octets)[nl]1 1[nl]2 2[nl]3 3[nl]."
"POP3D"	6976	132	"2020-01-15 04:52:25.537"	"192.168.125.206"	"RECEIVED: LIST"
"POP3D"	6976	132	"2020-01-15 04:52:25.537"	"192.168.125.206"	"SENT: +OK 3 messages (3853 octets)"
"POP3D"	6976	132	"2020-01-15 04:52:25.537"	"192.168.125.206"	"SENT: 1 611[nl]2 611[nl]3 2631[nl]."
"POP3D"	7844	132	"2020-01-15 04:52:25.740"	"192.168.125.206"	"RECEIVED: QUIT"
"POP3D"	7844	132	"2020-01-15 04:52:25.755"	"192.168.125.206"	"SENT: +OK POP3 server saying goodbye..."
"DEBUG"	5948	"2020-01-15 04:52:25.755"	"Ending session 132"
"DEBUG"	6976	"2020-01-15 05:22:27.372"	"Creating session 134"
"DEBUG"	6976	"2020-01-15 05:22:27.372"	"TCP connection started for session 133"
"POP3D"	6976	133	"2020-01-15 05:22:27.372"	"192.168.125.206"	"SENT: +OK POP3"
"POP3D"	7844	133	"2020-01-15 05:22:27.388"	"192.168.125.206"	"RECEIVED: CAPA"
"POP3D"	7844	133	"2020-01-15 05:22:27.388"	"192.168.125.206"	"SENT: +OK CAPA list follows[nl]USER[nl]UIDL[nl]TOP[nl]."
"POP3D"	6976	133	"2020-01-15 05:22:27.388"	"192.168.125.206"	"RECEIVED: USER l.prinkey@lmco.pef"
"POP3D"	6976	133	"2020-01-15 05:22:27.388"	"192.168.125.206"	"SENT: +OK Send your password"
"POP3D"	5948	133	"2020-01-15 05:22:27.388"	"192.168.125.206"	"RECEIVED: PASS ***"
"POP3D"	5948	133	"2020-01-15 05:22:27.403"	"192.168.125.206"	"SENT: +OK Mailbox locked and ready"
"POP3D"	7844	133	"2020-01-15 05:22:27.403"	"192.168.125.206"	"RECEIVED: STAT"
"POP3D"	7844	133	"2020-01-15 05:22:27.419"	"192.168.125.206"	"SENT: +OK 3 3853"
"POP3D"	5948	133	"2020-01-15 05:22:27.419"	"192.168.125.206"	"RECEIVED: UIDL"
"POP3D"	5948	133	"2020-01-15 05:22:27.419"	"192.168.125.206"	"SENT: +OK 3 messages (3853 octets)[nl]1 1[nl]2 2[nl]3 3[nl]."
"POP3D"	7844	133	"2020-01-15 05:22:27.419"	"192.168.125.206"	"RECEIVED: LIST"
"POP3D"	7844	133	"2020-01-15 05:22:27.419"	"192.168.125.206"	"SENT: +OK 3 messages (3853 octets)"
"POP3D"	7844	133	"2020-01-15 05:22:27.419"	"192.168.125.206"	"SENT: 1 611[nl]2 611[nl]3 2631[nl]."
"POP3D"	7844	133	"2020-01-15 05:22:27.622"	"192.168.125.206"	"RECEIVED: QUIT"
"POP3D"	7844	133	"2020-01-15 05:22:27.622"	"192.168.125.206"	"SENT: +OK POP3 server saying goodbye..."
"DEBUG"	6976	"2020-01-15 05:22:27.622"	"Ending session 133"
"DEBUG"	6976	"2020-01-15 05:52:29.250"	"Creating session 135"
"DEBUG"	6976	"2020-01-15 05:52:29.250"	"TCP connection started for session 134"
"POP3D"	6976	134	"2020-01-15 05:52:29.250"	"192.168.125.206"	"SENT: +OK POP3"
"POP3D"	5948	134	"2020-01-15 05:52:29.250"	"192.168.125.206"	"RECEIVED: CAPA"
"POP3D"	5948	134	"2020-01-15 05:52:29.266"	"192.168.125.206"	"SENT: +OK CAPA list follows[nl]USER[nl]UIDL[nl]TOP[nl]."
"POP3D"	6976	134	"2020-01-15 05:52:29.266"	"192.168.125.206"	"RECEIVED: USER l.prinkey@lmco.pef"
"POP3D"	6976	134	"2020-01-15 05:52:29.266"	"192.168.125.206"	"SENT: +OK Send your password"
"POP3D"	5948	134	"2020-01-15 05:52:29.266"	"192.168.125.206"	"RECEIVED: PASS ***"
"POP3D"	5948	134	"2020-01-15 05:52:29.266"	"192.168.125.206"	"SENT: +OK Mailbox locked and ready"
"POP3D"	6976	134	"2020-01-15 05:52:29.282"	"192.168.125.206"	"RECEIVED: STAT"
"POP3D"	6976	134	"2020-01-15 05:52:29.282"	"192.168.125.206"	"SENT: +OK 3 3853"
"POP3D"	5948	134	"2020-01-15 05:52:29.282"	"192.168.125.206"	"RECEIVED: UIDL"
"POP3D"	5948	134	"2020-01-15 05:52:29.282"	"192.168.125.206"	"SENT: +OK 3 messages (3853 octets)[nl]1 1[nl]2 2[nl]3 3[nl]."
"POP3D"	6976	134	"2020-01-15 05:52:29.297"	"192.168.125.206"	"RECEIVED: LIST"
"POP3D"	6976	134	"2020-01-15 05:52:29.297"	"192.168.125.206"	"SENT: +OK 3 messages (3853 octets)"
"POP3D"	6976	134	"2020-01-15 05:52:29.297"	"192.168.125.206"	"SENT: 1 611[nl]2 611[nl]3 2631[nl]."
"POP3D"	6976	134	"2020-01-15 05:52:29.485"	"192.168.125.206"	"RECEIVED: QUIT"
"POP3D"	6976	134	"2020-01-15 05:52:29.485"	"192.168.125.206"	"SENT: +OK POP3 server saying goodbye..."
"DEBUG"	7844	"2020-01-15 05:52:29.485"	"Ending session 134"
"APPLICATION"	3632	"2020-01-15 05:57:17.632"	"Stopping servers..."
"DEBUG"	3632	"2020-01-15 05:57:17.632"	"Application::StopServers() - Removing server work queue"
"DEBUG"	3632	"2020-01-15 05:57:17.632"	"WorkQueueManager::RemoveQueue - Server queue"
"DEBUG"	3632	"2020-01-15 05:57:17.632"	"Stopping working queue Server queue."
"DEBUG"	3632	"2020-01-15 05:57:17.632"	"Interupt and join threads in working queue Server queue"
"DEBUG"	4436	"2020-01-15 05:57:17.632"	"Worker exited in work queue Server queue"
"DEBUG"	6676	"2020-01-15 05:57:17.632"	"Worker exited in work queue Server queue"
"DEBUG"	7336	"2020-01-15 05:57:17.632"	"Worker exited in work queue Server queue"
"DEBUG"	4432	"2020-01-15 05:57:17.632"	"IOService::Stop()"
"DEBUG"	6976	"2020-01-15 05:57:17.632"	"TCP - AcceptEx failed. Error code: 995, Message: The I/O operation has been aborted because of either a thread exit or an application request"
"DEBUG"	4432	"2020-01-15 05:57:17.632"	"IOService::DoWork() - removing Queue IOCP Queue"
"DEBUG"	6364	"2020-01-15 05:57:17.632"	"TCP - AcceptEx failed. Error code: 995, Message: The I/O operation has been aborted because of either a thread exit or an application request"
"DEBUG"	6556	"2020-01-15 05:57:17.648"	"TCP - AcceptEx failed. Error code: 995, Message: The I/O operation has been aborted because of either a thread exit or an application request"
"DEBUG"	3632	"2020-01-15 05:57:17.648"	"Still 1 remaining threads in queue Server queue. First task: IOService"
"DEBUG"	8036	"2020-01-15 05:57:17.648"	"TCP - AcceptEx failed. Error code: 995, Message: The I/O operation has been aborted because of either a thread exit or an application request"
"DEBUG"	6976	"2020-01-15 05:57:17.648"	"Ending session 92"
"DEBUG"	4432	"2020-01-15 05:57:17.648"	"WorkQueueManager::RemoveQueue - IOCPQueue"
"DEBUG"	6364	"2020-01-15 05:57:17.648"	"Ending session 27"
"DEBUG"	6556	"2020-01-15 05:57:17.648"	"Ending session 26"
"DEBUG"	8036	"2020-01-15 05:57:17.648"	"Ending session 135"
"DEBUG"	4432	"2020-01-15 05:57:17.648"	"Stopping working queue IOCPQueue."
"DEBUG"	4432	"2020-01-15 05:57:17.648"	"Interupt and join threads in working queue IOCPQueue"
"DEBUG"	8036	"2020-01-15 05:57:17.648"	"Worker exited in work queue IOCPQueue"
"DEBUG"	6556	"2020-01-15 05:57:17.648"	"Worker exited in work queue IOCPQueue"
"DEBUG"	6364	"2020-01-15 05:57:17.648"	"Worker exited in work queue IOCPQueue"
"DEBUG"	6976	"2020-01-15 05:57:17.648"	"Worker exited in work queue IOCPQueue"
"DEBUG"	3344	"2020-01-15 05:57:17.648"	"Worker exited in work queue IOCPQueue"
"DEBUG"	500	"2020-01-15 05:57:17.648"	"Worker exited in work queue IOCPQueue"
"DEBUG"	6588	"2020-01-15 05:57:17.648"	"Worker exited in work queue IOCPQueue"
"DEBUG"	5684	"2020-01-15 05:57:17.648"	"Worker exited in work queue IOCPQueue"
"DEBUG"	8104	"2020-01-15 05:57:17.648"	"Worker exited in work queue IOCPQueue"
"DEBUG"	7268	"2020-01-15 05:57:17.648"	"Worker exited in work queue IOCPQueue"
"DEBUG"	7860	"2020-01-15 05:57:17.648"	"Worker exited in work queue IOCPQueue"
"DEBUG"	5956	"2020-01-15 05:57:17.648"	"Worker exited in work queue IOCPQueue"
"DEBUG"	3496	"2020-01-15 05:57:17.648"	"Worker exited in work queue IOCPQueue"
"DEBUG"	5948	"2020-01-15 05:57:17.648"	"Worker exited in work queue IOCPQueue"
"DEBUG"	7844	"2020-01-15 05:57:17.648"	"Worker exited in work queue IOCPQueue"
"DEBUG"	4432	"2020-01-15 05:57:17.679"	"Still 2 remaining threads in queue IOCPQueue. First task: <Unknown>"
"DEBUG"	3632	"2020-01-15 05:57:17.945"	"Still 1 remaining threads in queue Server queue. First task: IOService"
"DEBUG"	4432	"2020-01-15 05:57:17.945"	"All threads are joined in queue IOCPQueue."
"DEBUG"	4432	"2020-01-15 05:57:17.945"	"WorkQueueManager::RemoveQueue - Stopped IOCPQueue"
"DEBUG"	4432	"2020-01-15 05:57:17.945"	"WorkQueueManager::RemoveQueue - Erased IOCPQueue"
"DEBUG"	4432	"2020-01-15 05:57:17.945"	"IOService::Stop() - Complete"
"DEBUG"	4432	"2020-01-15 05:57:17.945"	"Destructing work queue IOCPQueue"
"DEBUG"	4432	"2020-01-15 05:57:18.211"	"Worker exited in work queue Server queue"
"DEBUG"	3632	"2020-01-15 05:57:18.211"	"All threads are joined in queue Server queue."
"DEBUG"	3632	"2020-01-15 05:57:18.211"	"WorkQueueManager::RemoveQueue - Stopped Server queue"
"DEBUG"	3632	"2020-01-15 05:57:18.211"	"WorkQueueManager::RemoveQueue - Erased Server queue"
"DEBUG"	3632	"2020-01-15 05:57:18.211"	"Destructing work queue Server queue"
"DEBUG"	3632	"2020-01-15 05:57:18.211"	"Application::StopServers() - Clearing caches"
"DEBUG"	3632	"2020-01-15 05:57:18.211"	"Application::StopServers() - Destructing IOCP"
"DEBUG"	3632	"2020-01-15 05:57:18.211"	"IOService::~IOService - Destructing"
"DEBUG"	3632	"2020-01-15 05:57:18.211"	"TCPServer::~TCPServer"
"DEBUG"	3632	"2020-01-15 05:57:18.211"	"Application::StopServers() - Destructing DeliveryManager"
"DEBUG"	3632	"2020-01-15 05:57:18.211"	"WorkQueueManager::RemoveQueue - SMTP delivery queue"
"DEBUG"	3632	"2020-01-15 05:57:18.211"	"Stopping working queue SMTP delivery queue."
"DEBUG"	3632	"2020-01-15 05:57:18.226"	"Interupt and join threads in working queue SMTP delivery queue"
"DEBUG"	4564	"2020-01-15 05:57:18.226"	"Worker exited in work queue SMTP delivery queue"
"DEBUG"	3268	"2020-01-15 05:57:18.226"	"Worker exited in work queue SMTP delivery queue"
"DEBUG"	6456	"2020-01-15 05:57:18.226"	"Worker exited in work queue SMTP delivery queue"
"DEBUG"	1468	"2020-01-15 05:57:18.226"	"Worker exited in work queue SMTP delivery queue"
"DEBUG"	4624	"2020-01-15 05:57:18.226"	"Worker exited in work queue SMTP delivery queue"
"DEBUG"	4508	"2020-01-15 05:57:18.226"	"Worker exited in work queue SMTP delivery queue"
"DEBUG"	4496	"2020-01-15 05:57:18.226"	"Worker exited in work queue SMTP delivery queue"
"DEBUG"	4488	"2020-01-15 05:57:18.226"	"Worker exited in work queue SMTP delivery queue"
"DEBUG"	4480	"2020-01-15 05:57:18.226"	"Worker exited in work queue SMTP delivery queue"
"DEBUG"	4468	"2020-01-15 05:57:18.226"	"Worker exited in work queue SMTP delivery queue"
"DEBUG"	3632	"2020-01-15 05:57:18.226"	"All threads are joined in queue SMTP delivery queue."
"DEBUG"	3632	"2020-01-15 05:57:18.226"	"WorkQueueManager::RemoveQueue - Stopped SMTP delivery queue"
"DEBUG"	3632	"2020-01-15 05:57:18.242"	"WorkQueueManager::RemoveQueue - Erased SMTP delivery queue"
"DEBUG"	3632	"2020-01-15 05:57:18.242"	"Destructing work queue SMTP delivery queue"
"DEBUG"	3632	"2020-01-15 05:57:18.242"	"Application::StopServers() - Destructing FetchManager"
"DEBUG"	3632	"2020-01-15 05:57:18.242"	"ExternalFetchManager::~ExternalFetchManager"
"DEBUG"	3632	"2020-01-15 05:57:18.242"	"WorkQueueManager::RemoveQueue - External fetch queue"
"DEBUG"	3632	"2020-01-15 05:57:18.242"	"Stopping working queue External fetch queue."
"DEBUG"	3632	"2020-01-15 05:57:18.242"	"Interupt and join threads in working queue External fetch queue"
"DEBUG"	3872	"2020-01-15 05:57:18.242"	"Worker exited in work queue External fetch queue"
"DEBUG"	7908	"2020-01-15 05:57:18.242"	"Worker exited in work queue External fetch queue"
"DEBUG"	120	"2020-01-15 05:57:18.242"	"Worker exited in work queue External fetch queue"
"DEBUG"	8172	"2020-01-15 05:57:18.242"	"Worker exited in work queue External fetch queue"
"DEBUG"	1796	"2020-01-15 05:57:18.242"	"Worker exited in work queue External fetch queue"
"DEBUG"	6112	"2020-01-15 05:57:18.242"	"Worker exited in work queue External fetch queue"
"DEBUG"	3404	"2020-01-15 05:57:18.242"	"Worker exited in work queue External fetch queue"
"DEBUG"	8112	"2020-01-15 05:57:18.242"	"Worker exited in work queue External fetch queue"
"DEBUG"	728	"2020-01-15 05:57:18.242"	"Worker exited in work queue External fetch queue"
"DEBUG"	5768	"2020-01-15 05:57:18.242"	"Worker exited in work queue External fetch queue"
"DEBUG"	3272	"2020-01-15 05:57:18.257"	"Worker exited in work queue External fetch queue"
"DEBUG"	4416	"2020-01-15 05:57:18.257"	"Worker exited in work queue External fetch queue"
"DEBUG"	4420	"2020-01-15 05:57:18.257"	"Worker exited in work queue External fetch queue"
"DEBUG"	2380	"2020-01-15 05:57:18.257"	"Worker exited in work queue External fetch queue"
"DEBUG"	4356	"2020-01-15 05:57:18.257"	"Worker exited in work queue External fetch queue"
"DEBUG"	3632	"2020-01-15 05:57:18.257"	"Still 1 remaining threads in queue External fetch queue. First task: <Unknown>"
"DEBUG"	3632	"2020-01-15 05:57:18.523"	"All threads are joined in queue External fetch queue."
"DEBUG"	3632	"2020-01-15 05:57:18.523"	"WorkQueueManager::RemoveQueue - Stopped External fetch queue"
"DEBUG"	3632	"2020-01-15 05:57:18.523"	"WorkQueueManager::RemoveQueue - Erased External fetch queue"
"DEBUG"	3632	"2020-01-15 05:57:18.523"	"Destructing work queue External fetch queue"
"DEBUG"	3632	"2020-01-15 05:57:18.523"	"ExternalFetchManager::~ExternalFetchManager - Removed queue"
"DEBUG"	3632	"2020-01-15 05:57:18.523"	"Application::StopServers() - Destructing Scheduler"
"DEBUG"	3632	"2020-01-15 05:57:18.523"	"Application::StopServers() - Destructing Rest"
"APPLICATION"	3632	"2020-01-15 05:57:18.523"	"Servers stopped."
"APPLICATION"	3632	"2020-01-15 05:57:21.664"	"Starting servers..."
"DEBUG"	3632	"2020-01-15 05:57:21.664"	"Creating work queue Server queue"
"DEBUG"	3632	"2020-01-15 05:57:21.664"	"Starting work queue Server queue"
"DEBUG"	7692	"2020-01-15 05:57:21.664"	"Running worker in work queue Server queue"
"DEBUG"	6764	"2020-01-15 05:57:21.664"	"Running worker in work queue Server queue"
"DEBUG"	3632	"2020-01-15 05:57:21.664"	"Started work queue Server queue"
"DEBUG"	8144	"2020-01-15 05:57:21.664"	"Running worker in work queue Server queue"
"DEBUG"	3304	"2020-01-15 05:57:21.664"	"Running worker in work queue Server queue"
"DEBUG"	3632	"2020-01-15 05:57:21.664"	"Adding task Scheduler to work queue Server queue"
"DEBUG"	3632	"2020-01-15 05:57:21.679"	"Adding task IOService to work queue Server queue"
"DEBUG"	3304	"2020-01-15 05:57:21.679"	"Executing task Scheduler in work queue Server queue"
"DEBUG"	3632	"2020-01-15 05:57:21.679"	"Creating work queue SMTP delivery queue"
"DEBUG"	8144	"2020-01-15 05:57:21.679"	"Executing task IOService in work queue Server queue"
"DEBUG"	3632	"2020-01-15 05:57:21.679"	"Starting work queue SMTP delivery queue"
"DEBUG"	8144	"2020-01-15 05:57:21.679"	"IOService::Start()"
"DEBUG"	4084	"2020-01-15 05:57:21.679"	"Running worker in work queue SMTP delivery queue"
"DEBUG"	6820	"2020-01-15 05:57:21.679"	"Running worker in work queue SMTP delivery queue"
"DEBUG"	2920	"2020-01-15 05:57:21.679"	"Running worker in work queue SMTP delivery queue"
"DEBUG"	7364	"2020-01-15 05:57:21.679"	"Running worker in work queue SMTP delivery queue"
"DEBUG"	6104	"2020-01-15 05:57:21.679"	"Running worker in work queue SMTP delivery queue"
"DEBUG"	620	"2020-01-15 05:57:21.679"	"Running worker in work queue SMTP delivery queue"
"DEBUG"	7012	"2020-01-15 05:57:21.679"	"Running worker in work queue SMTP delivery queue"
"DEBUG"	4568	"2020-01-15 05:57:21.679"	"Running worker in work queue SMTP delivery queue"
"DEBUG"	3632	"2020-01-15 05:57:21.679"	"Started work queue SMTP delivery queue"
"DEBUG"	6304	"2020-01-15 05:57:21.679"	"Running worker in work queue SMTP delivery queue"
"DEBUG"	5628	"2020-01-15 05:57:21.679"	"Running worker in work queue SMTP delivery queue"
"DEBUG"	8144	"2020-01-15 05:57:21.679"	"Creating session 136"
"DEBUG"	3632	"2020-01-15 05:57:21.695"	"Adding task SMTPDeliveryManager to work queue Server queue"
"DEBUG"	8144	"2020-01-15 05:57:21.695"	"Creating session 137"
"DEBUG"	3632	"2020-01-15 05:57:21.695"	"Creating work queue External fetch queue"
"DEBUG"	6764	"2020-01-15 05:57:21.695"	"Executing task SMTPDeliveryManager in work queue Server queue"
"DEBUG"	8144	"2020-01-15 05:57:21.695"	"Creating session 138"
"DEBUG"	3632	"2020-01-15 05:57:21.695"	"Starting work queue External fetch queue"
"DEBUG"	6764	"2020-01-15 05:57:21.695"	"SMTPDeliveryManager::Start()"
"DEBUG"	6732	"2020-01-15 05:57:21.695"	"Running worker in work queue External fetch queue"
"DEBUG"	6812	"2020-01-15 05:57:21.695"	"Running worker in work queue External fetch queue"
"DEBUG"	5340	"2020-01-15 05:57:21.695"	"Running worker in work queue External fetch queue"
"DEBUG"	6080	"2020-01-15 05:57:21.695"	"Running worker in work queue External fetch queue"
"DEBUG"	4020	"2020-01-15 05:57:21.695"	"Running worker in work queue External fetch queue"
"DEBUG"	6348	"2020-01-15 05:57:21.695"	"Running worker in work queue External fetch queue"
"DEBUG"	8068	"2020-01-15 05:57:21.695"	"Running worker in work queue External fetch queue"
"DEBUG"	4092	"2020-01-15 05:57:21.695"	"Running worker in work queue External fetch queue"
"DEBUG"	5644	"2020-01-15 05:57:21.695"	"Running worker in work queue External fetch queue"
"DEBUG"	7000	"2020-01-15 05:57:21.695"	"Running worker in work queue External fetch queue"
"DEBUG"	3788	"2020-01-15 05:57:21.695"	"Running worker in work queue External fetch queue"
"DEBUG"	612	"2020-01-15 05:57:21.695"	"Running worker in work queue External fetch queue"
"DEBUG"	8144	"2020-01-15 05:57:21.695"	"Creating work queue IOCPQueue"
"DEBUG"	6564	"2020-01-15 05:57:21.695"	"Running worker in work queue External fetch queue"
"DEBUG"	3280	"2020-01-15 05:57:21.695"	"Running worker in work queue External fetch queue"
"DEBUG"	3632	"2020-01-15 05:57:21.695"	"Started work queue External fetch queue"
"DEBUG"	6040	"2020-01-15 05:57:21.695"	"Running worker in work queue External fetch queue"
"DEBUG"	8144	"2020-01-15 05:57:21.711"	"Starting work queue IOCPQueue"
"DEBUG"	3632	"2020-01-15 05:57:21.726"	"Adding task ExternalFetchManager to work queue Server queue"
"DEBUG"	4304	"2020-01-15 05:57:21.726"	"Running worker in work queue IOCPQueue"
"DEBUG"	6532	"2020-01-15 05:57:21.726"	"Running worker in work queue IOCPQueue"
"DEBUG"	6884	"2020-01-15 05:57:21.726"	"Running worker in work queue IOCPQueue"
"DEBUG"	5364	"2020-01-15 05:57:21.726"	"Running worker in work queue IOCPQueue"
"DEBUG"	5548	"2020-01-15 05:57:21.726"	"Running worker in work queue IOCPQueue"
"DEBUG"	4200	"2020-01-15 05:57:21.726"	"Running worker in work queue IOCPQueue"
"DEBUG"	7204	"2020-01-15 05:57:21.726"	"Running worker in work queue IOCPQueue"
"DEBUG"	7732	"2020-01-15 05:57:21.726"	"Running worker in work queue IOCPQueue"
"DEBUG"	5808	"2020-01-15 05:57:21.726"	"Running worker in work queue IOCPQueue"
"DEBUG"	7672	"2020-01-15 05:57:21.726"	"Running worker in work queue IOCPQueue"
"DEBUG"	7924	"2020-01-15 05:57:21.726"	"Running worker in work queue IOCPQueue"
"DEBUG"	6696	"2020-01-15 05:57:21.726"	"Running worker in work queue IOCPQueue"
"DEBUG"	4524	"2020-01-15 05:57:21.726"	"Running worker in work queue IOCPQueue"
"DEBUG"	7692	"2020-01-15 05:57:21.726"	"Executing task ExternalFetchManager in work queue Server queue"
"DEBUG"	6872	"2020-01-15 05:57:21.726"	"Running worker in work queue IOCPQueue"
"DEBUG"	8144	"2020-01-15 05:57:21.726"	"Started work queue IOCPQueue"
"DEBUG"	7848	"2020-01-15 05:57:21.726"	"Running worker in work queue IOCPQueue"
"DEBUG"	7692	"2020-01-15 05:57:21.742"	"ExternalFetchManager::Start()"
"APPLICATION"	3632	"2020-01-15 05:57:21.742"	"Servers started."
"DEBUG"	8144	"2020-01-15 05:57:21.742"	"Adding task IOCPQueueWorkerTask to work queue IOCPQueue"
"DEBUG"	7848	"2020-01-15 05:57:21.742"	"Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG"	6872	"2020-01-15 05:57:21.742"	"Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG"	8144	"2020-01-15 05:57:21.758"	"Adding task IOCPQueueWorkerTask to work queue IOCPQueue"
"DEBUG"	4524	"2020-01-15 05:57:21.758"	"Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG"	6696	"2020-01-15 05:57:21.758"	"Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG"	7924	"2020-01-15 05:57:21.758"	"Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG"	7672	"2020-01-15 05:57:21.758"	"Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG"	5808	"2020-01-15 05:57:21.758"	"Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG"	7732	"2020-01-15 05:57:21.758"	"Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG"	7204	"2020-01-15 05:57:21.758"	"Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG"	8144	"2020-01-15 05:57:21.773"	"Adding task IOCPQueueWorkerTask to work queue IOCPQueue"
"DEBUG"	4200	"2020-01-15 05:57:21.773"	"Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG"	5548	"2020-01-15 05:57:21.773"	"Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG"	5364	"2020-01-15 05:57:21.773"	"Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG"	6884	"2020-01-15 05:57:21.773"	"Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG"	6532	"2020-01-15 05:57:21.773"	"Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG"	4304	"2020-01-15 05:57:21.773"	"Executing task IOCPQueueWorkerTask in work queue IOCPQueue
Re: Clients Can't Connect
Post by jimimaseye » 2020-01-15 19:07
Why are you being advised to check smtp port 25 availability when you are reporting an error about pop3??
Or have i lost something in the thread's forest of text?
bbarbour
Post by bbarbour » 2020-01-15 19:56
I did get a POP3 error when I set the "Vault" Email SMPT port settings to 110 just to see what effect that would have, but the rest of the time I had set the "Vault" Email SMPT port settings to 25 where I thought it should be and I'm getting a different error.
Post by Dravion » 2020-01-15 20:17
bbarbour wrote:
2020-01-15 16:23
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
Here's my log...
Good.
You hMailServer works as expected.
There a connection sessions created and executed without any errors (which means, clients can connect, fetch email via POP3 ect.)
From a technical point of view, your hMailServer works fine.
Post by palinka » 2020-01-15 21:26
bbarbour wrote:
2020-01-15 19:56
Obviously sending email needs to connect to SMTP, so keep the vault settings at port 25.
I would say this problem definitely has something to do with the error: An Attempt Was Made to Access a Socket in a Way Forbidden by its Access Permissions. A quick search brought up this: https://appuals.com/fix-an-attempt-was- ... rmissions/
Most likely cause: AV software interfering with SMTP traffic. IF that's the case then exclude hmailserver service and hmailserver data directory from AV scanning, as well as turning off AV email scanning.
bbarbour
Post by bbarbour » 2020-01-16 22:54
Thank you palinka and everyone who helped me!!!! This is an Anti-Virus issue. Once I turned off the Anti-Virus, everything works! Now to figure out how to setup an omit rule in the scanning.
