Ip Ranges - Internet config
eliassal
Post by eliassal » 2020-01-08 13:43
I have a question about the default configuration in the IP Ranges for internet
Lower 0.0.0.0 Upper 255.255.255.255
which I understand that any IP on earth can use this mail server.
Since I opened smtp and POP3 ports on the firewall, I started seeing the following log in hMailserver
"TCPIP" 156 "2020-01-07 12:18:47.254" "TCP - 45.148.10.151 connected to 192.168.10.34:25."
"DEBUG" 156 "2020-01-07 12:18:47.254" "Client connection from 45.148.10.151 was not accepted. Blocked either by IP range or by connection limit."
"DEBUG" 156 "2020-01-07 12:18:47.254" "Ending session 172"
"DEBUG" 156 "2020-01-07 12:18:47.347" "Creating session 174"
"TCPIP" 156 "2020-01-07 12:18:47.348" "TCP - 45.148.10.151 connected to 192.168.10.34:25."
Of course I right away blacklisted the IP in the firewall, my question is what made hMailserver refuse the connection and what measures should be implemented on my hMailServer? is it possible to have alerts when this thing happen again from other IPs?
eliassal
Re: Ip Ranges - Internet config
Post by eliassal » 2020-01-08 14:16
subscribed to notification
Post by palinka » 2020-01-08 16:24
It means the connection was rejected by autoban.
Post by mattg » 2020-01-08 16:42
Autoban is NOT turned on be default
Autoban is caused by multiple incorrect guesses at passwords
You could script to be notified, but seriously on my VERY locked down system, there is a new ip about 15 times per day
Welcome to the internet
eliassal
Post by eliassal » 2020-01-08 17:03
Thanks no script available to use? if I should write 1, where it should located and its name?
Post by mattg » 2020-01-08 23:50
How to >> https://www.hmailserver.com/documentati ... ce_scripts
A heap of script samples >> https://www.hmailserver.com/forum/viewforum.php?f=9
I don't remember one that does exactly this though
Post by palinka » 2020-01-09 01:13
If you're using hmailserver 5.7, then you can use OnClientLogon to trigger failed logons (which trigger autobans).
      .Pattern = strRegEx
      .Global = False
      .MultiLine = True
      .IgnoreCase = True
Function NotifyFailedLogon(xUserName, xIPAddress)
	Dim oMessage
	oMessage.From = "Notifier <notify@mydomain.com>"
	oMessage.FromAddress = "notify@mydomain.com"
	oMessage.Subject = "Failed Logon"
	oMessage.AddRecipient "My Name", "myname@mydomain.com"
	oMessage.Body = "Failed Logon at for user " & xUserName & " from IP: " & xIPAddress
Sub OnClientLogon(oClient)
	If oClient.Authenticated Then
		' YAY!
		strRegEx = "@mydomain1.com|@mydomain2.com|@mydomain3.com"
		If Lookup(strRegEx, oClient.Username) Then
			Call SendSMS(SMSNumber, sMSG)
		Call NotifyFailedLogon(oClient.Username, oClient.IPAddress)
	End if
Post by palinka » 2020-01-09 02:02
Oops... Remnants from my own OnClientLogon. Fixed here.
		' YAY!
		Dim strRegEx : strRegEx = "@mydomain1.com|@mydomain2.com|@mydomain3.com"
	End if
Or....
	If NOT oClient.Authenticated Then
	End if
