Wildcard SSL is not working
gnoppix
Post by gnoppix » 2019-12-17 03:41
Premise:
My previous setup was a Comodo SSL Cert for the hMailServer and it was working well. And since we are securing all communications we opted to apply for an SSL Wildcard Cert which *.domain.com.xx. This will include our mail.domain.xx and ticket.domain.xx etc. (please correct me if i'm wrong).
Here's the problem:
1. After doing the same thing i did on the first cert it didn't work.
a. already do the chain cert (same order as the first one ) - fail
2. I used the same private key coming from the server where we created the CSR for wildcard cert. fail
3. I used the same private key that i previously used before in hMailServer - fail
Should i crate a new private key for the wildcard cert ?
Thanks for the usual help.
gnoppix.
Re: Wildcard SSL is not working
Post by palinka » 2019-12-17 03:59
gnoppix wrote:
2019-12-17 03:41
New cert, new key.
Every new certificate requires a new key. My automated renewals create new certs and keys all having the same path\name as the old ones so no action in hmailserver is required other than restarting.
gnoppix
Post by gnoppix » 2019-12-17 05:53
Is it okay to crate a new Private Key in hMailServer then use it together with the wildcard cert?
As mentioned, the CSR was created on another server and not in hMailServer, would there be issues on this?
Thanks for the prompt response.
Gnoppix
Post by mattg » 2019-12-17 06:06
You need the key to match the certificate
It's like a physical padlock and key - they are made to match
Some arbitrary text can't just be used as a key, or they would easily be hacked.
gnoppix
Post by gnoppix » 2019-12-17 10:17
Is there a way to get the private key. As i checked, the one who submitted the CSR to Comodo is not sure if a Private key is created or not.
Any suggestion?
Thanks again. Gnoppix
Post by palinka » 2019-12-17 14:11
gnoppix wrote:
2019-12-17 10:17
Any suggestion?
Fire the guy responsible for messing up your security. :lol:
There is 0% chance a key was not issued with the cert. If you don't have the key you need to do it over again.
Or you could get a free letsencrypt cert and forget Comodo. Plenty of tutorials here in the tutorial section.
gnoppix
Post by gnoppix » 2019-12-18 11:13
Please confirm if i can still use the same private key that i used before since you never have to create one if you already have an existing and working one.
Thanks.
Post by palinka » 2019-12-18 13:34
gnoppix wrote:
2019-12-18 11:13
Thanks.
As long as you're using the certificate that was generated with that key. Then yes.
Every certificate has a key for that certificate only. If you change or renew the certificate, a new key will be generated and the old one will not work.
Virinum
Post by Virinum » 2019-12-18 17:02
You don't need a new key every time you create a new certificate. You can reuse the old key. That's what I'm doing because of my TLSA record for DANE.
For letsencrypt I'm using win-acme (https://github.com/PKISharp/win-acme). And win-acme has the flag "--reuse-privatekey". See here: https://github.com/PKISharp/win-acme/wi ... ine#common
Post by palinka » 2019-12-18 17:14
Virinum wrote:
2019-12-18 17:02
I did not know that. I also use win-acme. Its good to know, although I don't think it has a lot of bearing on hmailserver since win-acme automated renewals create new certs and keys with the same file names as the old ones in the same location. So when hmailserver restarts (reloads the cert/key) it doesn't even know or care that the cert/key are different - only that they work together.
However, the OP actually changed certificates from whatever his old one was to a wildcard cert (not a renewal). Its a completely new certificate that requires a completely new key.
Virinum
Post by Virinum » 2019-12-18 17:23
2019-12-18 17:14
Yes, you're right. I just don't want to change my TLSA-Record every time my cert renews. So that's the reason why I reuse the private key.
2019-12-18 17:14
If the OP still has his old private key he could reuse it. You can use a private key for as many certificates as you want. It's just important that the CSR is generated with this key. win-acme generates this CSR for you.
The "normale" way is: Generate private key -> Generate a CSR with this private key -> let a certification authority sign this CSR
Post by palinka » 2019-12-18 17:25
Virinum wrote:
2019-12-18 17:23
2019-12-18 17:14
Good to know. Thanks for the info!
