Refetch remaining POP3 Mails from external account
LtColDoerk
Post by LtColDoerk » 2019-11-17 14:52
Hi folks,
due to a misconfiguration of hMS, some external POP3 Mails were fetched but not delivered internally. Fortunately my external POP3 fetch was set to "delete after 7 days".
My problem is now, to refetch the missing ones again. Are there any suggestions?
p.s. New mails are fetched normally and delivered to the internal account.
Thanks in advance...
Re: Refetch remaining POP3 Mails from external account
Post by palinka » 2019-11-17 14:57
If you can access it by imap, you can log in to both accounts in Thunderbird and copy whatever you need from one account to the other.
Virinum
Post by Virinum » 2019-11-17 15:53
You could also delete the entries in the database table "hm_fetchaccounts_uids". Then all messages get fetched again.
Post by mattg » 2019-11-18 00:19
Virinum wrote:
2019-11-17 15:53
Sorry, but we do not promote or suggest or support direct database manipulation
This could always create other un-noticed issues
You could delete messages directly using the COM API if you need to force anything
LtColDoerk
Post by LtColDoerk » 2019-11-18 08:22
2019-11-17 14:57
Hello Palinka,
also my idea, but had hoped for a simpler solution.
Thanks for that suggestion anyway!
LtColDoerk
Post by LtColDoerk » 2019-11-18 08:23
Virinum wrote:
2019-11-17 15:53
That sounds perfect for me! I'll try it afterwards.
Best regards.
Virinum
Post by Virinum » 2019-11-18 09:55
I've just tested a simpler way. Delete the external account and recreate it. All entries in the table "hm_fetchaccounts_uids" will be deleted for the external account you delete. After recreating the external account, all messages get fetched again.
I think it's a much better way than manipulating the database. But it was the first thing that came to my mind.
Post by mattg » 2019-11-18 11:52
yes much better idea
The only issue is that some addresses may get duplicate emails if some have already been diverted correctly, as they will also be re-downloaded too.
