LOCAL GeoIP Test
LOCAL GeoIP Test
Post by palinka » 2019-10-21 13:12
I use a script called at OnHELO for GeoIP rejection (thanks, Soren!). The script calls ip-api.com, reads the json returned and allows or rejects based on country. I have noticed that sometimes I get mismatch (null) errors on IPs that are clearly in the ip-api.com database. I know this because after looking at the error, I manually try and a result always comes up. Therefore, I believe the errors are caused by network issues due to my crappy ISP supplied router that I do plan on changing.
Anyway, in order to avoid network errors, I am considering creating a local db using maxminds geolite2 csv. Before I spend the time working on that, I was wondering if there is already a solution for LOCAL query for geoip data. The old maxminds COM is no longer supported, but does it still work? My understanding is that the entire db structure (legacy geoip vs geoip2) is different and that's why it does not work/can't be updated/whatever?
I have looked at the geolite2 csv and have a strategy for implementation, but its work... :wink:
tunis
Re: LOCAL GeoIP Test
Post by tunis » 2019-10-21 15:47
I use php with local geoip.
https://github.com/maxmind/GeoIP2-php
Use this vbs code
    ' ### hMailServer GeoAutoban Code
    Function GeoAutoban(oClient)
        Dim oGeoip
        Dim sPort : sPort = Trim(Mid("SMTP IMAP SMTPSSUBM IMAPS", InStr("25   143  465  587  993  ", oClient.Port), 5))
        On Error Resume Next
        With CreateObject("Msxml2.ServerXMLHTTP.6.0")
            .Open "GET", "http://server/geoip.php?ip=" & oClient.IPAddress, False
            .Send
            If (.Status = 200 ) Then
                Set oGeoip = GeoIP(.responseText)
                sRegEx = "(SE|NO)" ' <===== Sweden, Norway
                If (Lookup(sRegEx, oGeoip("countryCode")) = False) Then
                    EventLog.Write(sPort & vbTab & oClient.IPAddress & vbTab & oGeoip("countryCode") & vbTab & oGeoip("countryName"))
                    Call AutoBan(oClient.IPAddress, sPort & "-" & oGeoip("countryCode"), 7, "d")
                    GeoAutoban = True
                EventLog.Write("<OnClientConnect.error> Lookup failed, error code: " & .Status & " on IP address " & oClient.IPAddress)
        On Error Goto 0
    ' ### GeoIP
    Function GeoIP(sGeoIP)
        Dim sCode, sName
        Set GeoIP = CreateObject("Scripting.Dictionary")
        iPos = InStr(sGeoIP,":")
        If (iPos > 0) Then
            sCode = Mid(sGeoIP, 1, iPos-1)
            sName = Mid(sGeoIP, iPos+1)
        GeoIP.Add "countryCode", sCode
        GeoIP.Add "countryName", sName
HMS 5.6.8 B2505.27 on Windows Server 2016 Core VM.
Post by palinka » 2019-10-21 17:54
tunis wrote:
2019-10-21 15:47
How is performance? Are you using a database or it reads a the flat file every time you connect?
Post by SorenR » 2019-10-21 23:09
Well... I downsized to use a simple DNS lookup ;-)
Sometimes there is no country and sometimes there are two countries. I did dig into it a while back. Source data is OK and it appears to be a registration glitch with the local registrars as WHOIS data sometimes show similar discrepancies.
Function GeoLookup(strIP) : GeoLookup = "zz"
    Dim a, element, group, strLookup
    a = Split(strIP, ".")
        strLookup = .TXT(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".zz.countries.nerd.dk")
    group = Split(strLookup, vbCrLf)
    If UBound(group) = LBound(group) Then
        GeoLookup = group(0)
        Exit Function
    If UBound(group) > LBound(group) Then
        For Each element In group
            EventLog.Write( LPad("... GEOLookup", 15, " ") & vbTab & LPad(strIP, 16, " ") & vbTab & LPad(" ", 3, " ") & vbTab & LPad(" ", 16, " ") & vbTab & element )
        Exit Function
    EventLog.Write( LPad("... GEOLookup", 15, " ") & vbTab & LPad(strIP, 16, " ") & vbTab & LPad(" ", 3, " ") & vbTab & LPad(" ", 16, " ") & vbTab & GEOLookup )
Function LPad(str, length, pad)
    LPad = Left(CStr(str) & String(length, pad), length)
" I will initiate self-destruct. " — IG-11.
Post by palinka » 2019-10-22 02:19
2019-10-21 23:09
That's what I do now. I'm getting a bunch of errors that I used to think were missing db info, but now believe are network errors. That's why I want to make it local.
Post by palinka » 2019-10-22 04:33
I'm testing my homebrew maxminds now. It took over half an hour to LOAD the database with 330k records. Actually, I stopped looking - it may have taken an hour. Queries take about a second.
I used powershell to calculate the min and max IP from the cidr given in the maxminds database. The query goes as follows:
"SELECT country_iso_code, country_name FROM hm_geoip WHERE INET_ATON('" & oClient.IPAddress & "') >= INET_ATON(minip) AND INET_ATON('" & oClient.IPAddress & "') <= INET_ATON(maxip)"
I just finished testing the code and just now loaded it into eventhandlers.vbs. Got my first connection which reported correctly. Woohoo!
I still need to automate downloading database updates from maxminds. When I'm done, I'll post here.
Post by palinka » 2019-10-22 04:36
2019-10-21 23:09
Is there a way to pass two variables back to the call? Specifically, I want to pass country code and country name. Or do I need a function for each?
Post by SorenR » 2019-10-22 09:07
2019-10-22 04:36
2019-10-21 23:09
No, all you get is the country code.
You can create your own "Countrycode<->Country" table here --> http://peric.github.io/GetCountries/
Source: https://github.com/peric/GetCountries
tunis
Post by tunis » 2019-10-22 11:45
2019-10-21 17:54
tunis wrote:
2019-10-21 15:47
Preformence approx 10-15ms/request. (in firefox)
I have a centos machine with my webmail and GeoIP installed.
As you see in examples on github it's have the path to geoip databas file.
Post by palinka » 2019-10-22 12:00
Wow that's much faster than I'm getting from mysql. I'll have to rethink the query.
Also, I'm not working with much perfomance in terms of hardware. But still, that's a gigantic gulf of a difference.
Post by palinka » 2019-10-23 04:09
I got it all running. Just posted in the scripting forum.
Queries take about 1.3 seconds on my old-ish office desktop class hardware running win 10 for both hmailserver and MySQL (among other things). But... Its local so there's no worry about network errors anymore.
nitro
Post by nitro » 2019-10-23 09:30
I still use a local database (text file), the performance is good, I only do the search if the authentication failed.
Here the updated database.
https://www.miyuru.lk/geoiplegacy
Here old GeoIpCom.
https://github.com/maxmind/geoip-api-mscom
Copy GeoIpComEx.dll to% windir% / SysWOW64
Run from the command line:
cd% windir% / SysWOW64
regsvr32 GeoIpComEx.dll
Dim geoip
Dim country
Set geoip = CreateObject("GeoIPCOMEx.GeoIPEx")
geoip.set_db_path("c:\Program Files (x86)\hmailserver\geoip\")
geoip.find_by_addr(ip)
country = geoip.country_code
EventLog.Write("IP " & ip & " country: " &country)
If country <> "ES" ....
GeoIP-COM-1.3.zip
GeoIpComEx.dll
(44.2 KiB) Downloaded 83 times
Post by palinka » 2019-10-24 13:40
nitro wrote:
2019-10-23 09:30
Here old GeoIpCom.
Heh.. if i saw this before i probably would have used it. But now I've already got this other project going so I'm going to see it through to completion. Thanks, though!
Post by palinka » 2019-10-27 14:31
This project is done as far as I can tell. I think I got rid of all the bugs. Its working great on my system and its totally automated so updates are just a matter of creating a task in task scheduler.
https://github.com/palinkas-jo-reggelt/GeoLite2MySQL
